Smallest 18350 light?
Wuben website says 16340 and no mention of 18350 compatibility. Diameter of 21mm makes me think it’s unlikely it will accept 18350.
55 grams. :smiley:
Certainly not new, but I didn’t see it on the list yet:
NiteEye Eye10.
Not the smallest @ 80mm x 24mm, but it’s a cool little rotary that will take 18350s. :beer:
Dough! Yeah, 16340 only, just like the Jet-II. Was thinking for some reason it took an 18350, too.
I know I got something that takes an 18350, but Hell if I can recall what.
[quote=freefly]
I agree. Eye10 is the same as the RRT-01 except there are 11 detents on the Eye10 ring. I like detents, they allow repeatable light levels, the infinite RRT-01, can never be set to the same level twice. And the Eye 10 is still available, the RRT-01 is no longer for sale new.
Anyone know the lightest headlamp / right-angle 18350 or 14500 light?
Oddly it’s hard to find a body lighter than the h03 at 44g, and that’s for an 18650!
Would like to bring overall weight down though and use a 14500 or 18350 instead as the battery.
I don’t know about the weight but last time I was on the Illumn site they had the Thrunite TH20 on sale for $25. It takes a 14500 I believe.
if you add the 45gm for an 18650, that H03 comes to 89 grams
the 18350 Armytek Tiara (48gm), plus an 18350 (21gm), totals 69 grams
Highly recommended: Armytek modded to High CRI from Clemence
Here is a post about the quad E21A mod
and a pic of some of Clemences Quad E21A 2000k, being tested in a light of mine (not a Tiara)
not exactly “B”LF, eh?
I like my TH20, but from what I have read it is not very light compared to other headlights. Don’t have any specific data for comparison, I am sure Thrunite has the weight listed on their website.
Maybe this ?
Ran across this. Andrew and Amanda have the Nitecore EC11 on sale for $39.00 right now. Don’t know for how long.
I’m sure someone could easily make a flashlight as small as the lux-rc minion.
All it takes is a small cylinder with the LEDs on the driver PCB and a piece of glass.
No optics or anything, just a mule.
Using flat LEDs like XP-L HIs or black flats could reduce the height even further.
But for some reason nobody does it. :frowning:
If only they made a version of the S Mini sized for 18350. Le sigh.
A nice challenge for CRX !
:smiley:
Smallest 18350 light I’ve made was the copper & aluminium triple with FET driver & tail clicky.
Length – 60 mm
Width – 25 mm
Weight – 97 grams (with cell)
Max – 1400lm
10/11/2018
1/6/2019
update, I disagree with my former self
I tried an Eye10 and the detents are inconsistent and not spaced to my liking
it has given me a new appreciation for my RRT-01 smooth ramping dial… maybe I should try some hi cap IMR 18350… hmm
I think one of these protected button tops might be good… the flat top version does not work in the RRT-01
pic is a link to review
Can anyone confirm if these fit the RRT-01? (not too long?)
they are for sale here:
Probably too long. I made a custom flat top protected for my 01, very tight fit.
I had to grind the tail pin down and alter the RvPo ring to make it fit.
I could be wrong though, would be best if you could measure somehow with the cells you have and thin spacers?
darn
Protected Keepower, length: 39 mm
Protected Fenix 16340, length: 34 mm
maybe I need to go to the store and try the cell out in my RRT-01 before I buy it…
