cool mod, zeroflow! Looking forward to the progress.
I need this for my D4S. Looks amazing!
Looks very interesting!
kiriba-ru C8TT triple heatsink head build
Since kiriba-ruâs C8TT head is so unique I wanted unique parts to go with it. I opted for the highest CRI and highest lumens I could manage. LED4Powerâs parts were the obvious choice, constant current + FET + moon + temp + good UI. I donât think either of these guys get enough credit for the awesome stuff they produce.
- LD-B4 (12A CC linear driver) from LED4Power
- 4040 MosX board w/ FET & NTC
- 2x Luxeon MZ 3000K (>90CRI) + 2x Luxeon MZ 5700K (>90CRI)
- LEDiL CUTE-4 optics
- 20G wires throughout + bypasses
Brief tests & observations:
12 Amp Constant Current mode:
- ~2,590lm @@ 30s - VTC6 at 4.xx volts
Direct Drive FET (pulling 28.xx Amps!!):
- ~5,142lm @@ 0s - VTC5A
- ~5,112lm @@ 0s - Samsung 25S
Itâs nuts this thing can suck up almost 30 amps from a single 18650 and still be >90CRI light
Pictures:
Reflow prep station, triple check your datasheets for anode + cathode time, thaw some 63/37
I saw on the datasheet a 7â steel crepe pan was recommended. Yes I seasoned it, no I donât use it for food. ($14 Amazon)
Too much solder paste, story of my life. Plz suck up a bunch when it gets to temp ::crossing fingers::
OK, I can work with that. Must be magic⊠For anyone questioning if you can do this. YOU CAN, itâs night and day obvious that itâs basically aligned and melted. Havenât even touched it yetâŠ
Remember how I said too much solder paste and anyone can do this? Everyone has to start somewhere, time to suck it up and cleanup your (solder) balls.
Time to check your work (fun fact, since LED4Powerâs MosX boards have the FET on them this shouldnât have worked. The modding gods must have left a little charge in the FET for me knowing I have no idea what iâm doing)
I wont bore you with my crappy soldering stories or trying to snake wires all over the place or mixing up FET and Temp wires but lets just say I got it done.
Time for the glamour shots:
will probably change this to a clear anoâd convoy tube some day
tint mixing is the new hotness, get on board. Inspired by maukka tests of two slightly above BBL LEDs mixing into a middle tint below BBL. Also, it just plain looks COOL in moon (<1lm)
showing off her glOw face
and last but not least, obligatory beam shot from a cell phone on auto (youâre welcome)
There is a slight donut which surprised me from a TIR optic. Considering how well everything else turned out, I can look past it. Iâll try a piece of DC-Fix when I get around to it but I suspect I will miss my precious lumens and take it out.
That is so nicely done contactcr! I wonder what that output is?
It would have been an insult to the fine resulting flashlight if you had shown the messy bit with the wire soldering
Btw, you could, instead of buying a clear C8, remove the anodisation with lye.
Thanks djozz. I posted the ouput just before the pictures. Still cant believe it reads over 28 amps at tail. I also ordered the 20 degree medium cute4 optic to see if it removes the hole. Forgot they make a few models.
Edit; realized u might be asking CCT. It feels a hair under below 5K just eyeballing it. Iâll show a 4k and 5k next to it and see
Edit2; itâs closest in tint to a XPL HI U6-4C 4200-4500K
I hoped for lumens, but not everyone has a contraption for measuring that. Based on your 28A tail current and counting in losses from the optic it must be over 5500 lumen
I have too many little projects, but since I have been given one of these C8 heads from Kirabu for checking out, it sounds like I will try to repeat your mod some day!
Ok, so Iâm confused, again. How can LED4POWERâs 12A Constant Current driver deliver 28A at the tail?
Itâs a CC FET+DD FET driver. Truly amazing stuff
djozz, it very well could be higher I adjusted mine down to very conservative factor after comparing with some of your newer tests of Q8 and others but I would hope itâs at least in the ballpark.
Dale, that is the beauty of his MosX setup. Itâs the best of both worlds. In the firmware you can choose the highest mode to be anywhere from 8 to 12A CC for this driver or you can override that and it will use a FET that is on the MCPCB to do direct drive (for the highest mode only).
Check out the data sheet: https://led4power.com/wp-content/uploads/2017/12/LD-4-datasheet-1.1.pdf
Since the FET and Temp sensor are both tied to mcpcb with good thermal path you get really good performance for either mode.
Btw, I checked the color temp and the closest known one I have to it is a XPL HI U6-4C 4200-4500K so it must be closer to 4500K than I originally thought.
I actually have the driver, and several others, just havenât put em to use yet.
Couple weeks ago. Brass switch cover with green tritium vial for my 47's Atom triple and a couple new magnetic holders to keep the DQG Hobi Ti+ Seoul Viosys 365nm UV flashlight, petrol lighter & DQG Ti green laser on my utility keyring.
Just need a red light now :-)
UltraFire UF-10 Luminus SST-20 5000KThis one has had a few different emitters.
Cree XP-L HI v2 1A:
Max â 1120lm/ 406lm - 4.5A
Lux â 29000/ Throw â 340m
Nichia 319AT SM655 D440F2 6500K:
Max â 1036lm/ 392lm - 5.2A
Lux â 17000/ Throw â 260m
Luminus SST-20 5000K L3 DA:
Max â 870lm/ 350lm - 5.3A
Lux - 30500/ Throw 349m
On a whim I pulled parts out of the bin and made a new bait fish fishing light.
Sc02
Green XP-E2
BLF SK68 driver populated with a baby FET on a 7135 pad. E-switch 13 (TomE) firmware.
Horrible tail cap setup replaced with my typical Cu disk / spring press fit in place of the stock crap.
Total spent: zero
Tried an upgrade of the BLF Q8 from the XM-L 4500K to Samsungs LH351D 90 CRI 4000K.
Reflowed those new LEDs
Shiny new screws for the MCPCB
100uF 1206 capacitor to reduce problems with bumps:
And an AR-coated lens
But sadly, it looks like I damaged one emitter somehow.
Strange, since one emitter definately made some troubles when reflowing
My question is: would you replace that LED or just live with it?
EDIT: I forgot I ordered a spare LH351D on a 16mm MCPCB. Everything fixed now.
Interestingly, in the tests with ceilingbounce, it went from around 5500 lm to 6500lm, so that partially damaged LED clearly didn't pull it's weight.
My big advice for everyone trying to reflow such a big MCPCB with a hot air rework station:
Remove any nozzle attachment so you can heat the biggest area and hit it with maximum airflow from below.
Works like a charm.
Also, don't use too much solderpaste, it will only short-circuit.
Since my D4 didnât get much love. I swapped the 219C for SST-20 4000K and put Anduril on it. Much better now! :+1:
P.S.: crx nice and clean as always!
I put SST-20 4000K LEDs in an E2L triple (again). Using a FET+N+1 from Lexel with Bistro HD.
This time they seem to be surviving. The last SST-20âs turned yellow on me after testing a high drain battery on turbo. Maybe my reflow was bad, guess time will tell.
Does about 2,400lm at 0s with VTC6
I also added a clear switch boot and drilled a tiny hole in it for an ice blue trit. Thanks to Dale for showing me this. Just enough glow to see it in a dark room but not enough to bother you and it doesnât drain your battery.
I kind of like how pointy the beam looks in my triple with these LEDs. What do you think? Between these and the LH351D you really have both extremes of beam shape covered.
Any idea what the output is on your D4?
