But I suspect some automated algorithm is observing this, re-pricing based on recent past orders, and oscillating wildly, with no (sensible) human in the loop.
Interesting times. And pick up your “bargains” whilst you can.
But don’t forget it is still a sh(it) torch, meaning sh (dont talk about it) and (it) meaning a complex UI. Nothing more.
You could do much better, for just a few dollars more.
Tom Tom, I can understand that you feel frustrated about this flashlight and how things went south in the past between CPF Italia, Banggood, Manker and Jaxman. However, I would greatly appreciate it if we all could focus on the technical aspects of the Cometa, it's great benefits regarding the low price and how any potential flaws can be identified and rectified. In my humble opinion and without any offence, griping over and over again about the past, the price fluctuations on Banggood or why one should not buy this light distracts a bit from finding out how to get the best out of this light.
For the Problem of Driver shelf oversize on Pill,with risk of short.
We can try to screw a P60 brass on the cometa pill instead the stock ring,
then put the driver
hope will fit.
So far, I noted following issues that one should take a look at before actually using the Cometa:
Short circuit risks:
solder joints on LED aluminum board (potential for bad solder jobs)
sharp edges on the pill that might damage the insulation of wires
insulation disc on the rear side of the pill is crucial as the outer rim of the pill might cause shorts when in contact with the positive pole of the battery
driver pocket / driver shelf oversize (approx. 19-19.5mm) while pass thru hole is about 17.8-18mm => 17mm driver can be moved over enough to short out on one of the SMD’s or positive lead
MCPCB isn’t screwed or glued => risk of board-rotation and shearing-off of leads when tightening the cover => Fix: tighten the MCPCB by mounting two screws onto it
Operational malfunctions/ flaws:
Turbo drops out to moon after exactly 10 seconds => Fix: adding a 5 Ohm resistor between led+ and both C1 and D1 or set off the temp / heat setting
Rattling inside the head due to zoom mechanism => Fix: still in clarification / adding high-viscosity lubricant, o-rings or kapton tape might help
If there's anything more to consider or if something needs to be corrected in my above mentioned points, I'll be glad to collect any further input and summarize it here.
Tom Tom, enough already. You have made your points. Stop calling name on Cometa most people here enjoy having. The groupbuy was a mess, don’t blame the flashlight. I bet you don’t buy from Banggood anymore, but that’s your decision.
I think on some drivers the turbo step down because the programed temp is to low?
Also i never heard about the LED rotating its common for zoomies to not have the MCPCB screwed down by actual screws. This system is what is used on most zoomies?
Most likely someone have tighten the alu. disc too much and rotated the MCPCB. Outcome of this MCPCB rotation was either scratched alu disc and shorted with MCPCB solder blobs, and/or led wires get cut by sharp edges of the brass pill and shorted too.
It should have been hold down by two screws to avoid this, but manufacturer cut cost on these screws and tapping.
I bought 2 this time round and 1 on original group buy , added some thermal grease to MCPCB then kapton tape over solder joints.
After this it works great for what it is, it is a cheap zoomie with good performance. I have yet to see anything throw like this for £12 inc battery ,Tom Tom if you know of anything that can out flood and out throw this for £12 ($15USD) inc battery please let us all know.
Yes it’s not a torch for everyone but for them who will do very basic mods, it’s a great torch at a great price.
I just got 2 cometa’s today and everything that was wrong with them has been fixed in some way or another. There is a plastic insert on the head side of the battery (well made, milled plastic insert) and what is normally the reflector (don’t know what it is called) has been milled for relief of the solder blobs. Solder work is perfect also. For $15 or $16 these are a bargain if you like zoomies. I’ll try and post pics later.
Wow, guess it’s a good thing I bought 3 of them, they are only 49% off now at $47.99 each. Normal price is $96.00 at Banggood. How much were they during the initial group buy? I wasn’t apart of this fabulous forum then.
Only because some fat-fingered idiot, or automated script, pressed the wrong buttons.
Now corrected.
Good luck to those of you who snapped a “bargain”. Maybe even with some “free” cells.
Yes, I am just a tiny bit jealous. But also glad that I missed this. Life is too short to be fixing these shoddy knock-offs up, when you could do so much better, but by all means crack-on, those of you who have time on your hands, and are really cheap.
Edit: “Nevermind the Quality, Feel the Width.” An oblique reference.
I’m out of this thread now, you will be pleased to hear.
