Low-cost copper pills, spacers, optics, drop-ins (Updated 23/10/2022))
contactcr that looks really cool. How’s the tint? Does it look below the BBL? Also I heard when you mix two different CCT too far apart in parallel, it can be a problem because their Vf might be very different.
Im guessing slightly under 5k. Ill try to compare to a known 4k and 5k tonight. I dont see any magenta or green so i can only guess it’s close. I have not ever seen either emitter by itself before this so im not sure of that either. First time using MZ.
As for vf hopefully since both are same CRI its close. Plus they can take much higher current in total so maybe that helps too?
I checked the color temp and the closest known one I have to it is a XPL HI U6-4C 4200-4500K so it must be closer to 4500K than I originally thought. This actually makes more sense because if the split was even it would be 4350K but I assume the 5700K contributes a bit more so round up to ~45K?
Yea I would assume since the 5700k is a higher bin. Wouldn’t be surprised if it is more like 4900k. But very nice. I might get one too to tint mix.
Knowing how particular you are about tint and stuff I would not pair de-domed LEDs with Cute 4 smooth spot. I ordered a medium spot replacement optic in the hopes that it will get rid of the donut in the middle.
CUTE-4 optics is unfortunately made only for ancient Cree XR-E led so tir holes are quite far away from pcb surface.Part of emitted light from undomed thin LEDs like MZ doens't hit tir hole (or hits at wrong angle), so there is some lumen loss. Luxeon V + Cute-4 works much better because LED is domed. Cute-3 works nice for all LEDs,including MZ.
I’m interested in a full copper pill for doing a triple convoy S2+ build.
Let me know!!
Im sorry for delays, I know many members are waiting my parts, I rememember each quest and will make all parts Ive promised.
I can roughly estimate sequence of restock:
- copper pills single led S2+ (mtn boost driver compatible)
- custom parts from pm requests, including p60 single led and b158 pills, new design custom retaining rings
  • triple pills and spacers for S2+ (probably next month).
Still need in reviewer of belt grinder parts, open for any help!
me too, plz
How far does the Ultrafire F13 spacer lift the MCPCB above the original emitter shelf?
Okay, I vaguely remember your post asking if anybody wants to make a belt grinder. What is the actual deal? What are the requirements? If I can help, I will be glad to.
Now I’m in need of the full copper pill for the convoy S2+ and the heatsink for the convoy C8. Can you let me know a time frame that they will be ready by?
Triple pills for S2+ wont be available for at least one more month.
C8TT sets are in stock. Spacers for C8 mod will be available from led4power website soon (together with optics, pcbs, leds, drivers etc.) soon.
Following up on this. I ordered a CUTE-4 ~20° medium optic (C10447_CUTE-4-M) instead of the smooth spot ~12° and it got rid of my donut problem entirely. I imagine LED4Power still recommends CUTE3 for dedomed LEDs but this is good if you must have CUTE4. Definitely one of my favorite builds so far.
Are you making the spacers for the C8 mod? Is it going to be copper? Also more interested in a Sofirn C8F 21700 kit since with 6 LEDs, it makes more sense to go with 21700 batteries.
No, no and no.
For sure I will make any part if I see good demand.
But now all this custom 1-2-3pcs orders just cause problems. Sometimes I agree to make a custom part to satisfy a regular buyer, sometimes it causes big delays that is not good for anyone.
CNC made parts - this is what I can provide as good deal. I dont worry about quality and metall stocks (just use full bar and forget about it), you enjoy quality/price ratio.
S2+ single pills are ready.
They have slightly non-standart design (I was not 100% satisfied with current design custom rings, have developed new version that required pill changes) with deeper retaining ring thread. New rings are not ready yet, but you can use them with regular convoy rings or previous custom rings. Havent checked yet but I suppose even convoy rings will allow using 2-side 7135 drivers.
PM sent!
How the hell are you getting 28+Amps on a single 18650 light?
Bypassed everything plus super low vf LED. Each emitter is 4 dies so basically 16 LED. And of course you must use the highest drain 18650s (vtc5a, 20s, 25s, etc)
