Wow the X70 throws farther and also more floody than the MS12 by a pretty good margin! I wonder if it’s because the flashlights were not aimed consistently. But if it is indeed a fair comparison, the X70 is much more powerful than the MS12. In some of those pics, it even throws almost as well as the R90C.
sorry,i dont have the link to the mod.i just know it because someone want to modify ms2010 and send ms2010 to the seller in taobao and change LED into xhp35hi. 贴吧404
this is the link(comparing ms12,x70)(sorry for my bad English)
Take a look at a computer cpu cooler ;). There is a lot of science behind them but there design let you understand it easily.
They dont have a lot of mass, instead they have a lot of surface area.
Cooling isn’t about mass, its about transfering the heat away from the source and being able to get rid of it quickly.
If you look at a cpu cooler, they have a solid base plate. Not to add mass as they are mostly not that big but to have an as big as possible contact plane with the cpu.
To move the heat away they, nowadays, rely on the use of heatpipes. They are far more effective than using conduction trough solid mass.
Quote from Wikipedia : “The effective thermal conductivity varies with heat pipe length, and can approach 100 kW/(m⋅K) for long heat pipes, in comparison with approximately 0.4 kW/(m⋅K) for copper.”
If you can not get rind of the heat quickly, like in a flashlight, then adding mass will help to create a buffer. More mass means able to ‘absorb’ more heat.
Moral of the story, the best cooling possible in a flashlight is having a fan directly on a cooling fin structure at the bottom of the shelf.
Are you sure? Look at the first comparison, the X70 illuminates all of the houses the entire width of the photo, whereas the MS12 only illuminates the houses at the center. In the second comparison, the X70 illuminates a much wider patch of trees than the MS12. The X70 looks alot floodier to me, which seem to make sense given the smaller head size.
Indeed the X70 does throw farther and looks more floody according the pics. I ordered both lights. Will definitely compare them to see which one is the best.
