I don’t have the equipment to measure amps.
I’m waiting for my Nightwatch heavyweight XHP70 light to come from Enogear and see if the NA40 tube fits. That would add USB charging to that light.
If you ever want to:
For tail cap amp draws, all you need is a $30 UNI-T UT210E clamp meter. That's the model a lot of BLF folks use due to the big Group Buy back in 2016.
The process looks like this.
The UT210E can also measure voltage.
my NA40 pulls nearly 15A with fresh 26650 cell, so my wild guess is about 5000lumen
the light is also equipped with temprature control, because the turbo last much longer when using this light under water
For anyone who is waiting for this light, available stock is coming back on Taobao on 10th Oct 2000h, beijing time.
Anyway, more details and more pics can be found in the Taobao item’s review section, which number 410 reviews.
Yes, that’s probably the reason why folks aren’t getting much comfortably above 4000 lumens, much less hitting 6000 lumens.
A single cell gunning 6000 lumens at very high amps is going to place a lot of stress and emphasis not only on the 1 x 26650, but also on the springs, the cleanliness of contact points, all the components in the power path.
You cannot use the Keeperpower 26650s, they are like mid current cells only.
The best Keeperpower 26650 vs Liitokala INR26650 @ 20A “only”. I think we need to look at 30A (see subsequent posts).
And this is the VTC5A vs Liitokala INR 26650 @ 30A. Sony VTC5A wins
To get the absolute best measurements at start-up or within 1-20 seconds, i guess you’d need the true heavy hitters.
Bring out the Samsung 20S INR (Vapcell 2000mAh black)
Samsung 20S vs Sony VTC5A @ 30A. No contest.
Yep. To get this power out of a single cell, it is imperative to reduce resistance as much as possible.
The biggest one here is the spring. Why aren’t they using dual BeCu springs, or at least, a coated spring? Uncoated copper alloy springs will develop oxides on the layers overtime, boosting contact resistance, and creating hot spots, and boosting the voltage loss even further.
That means even if they are using the highest conductivity BeCu C17500, performance will get worse over time.
Look at djozz’s test on the SST-40. In the best scenarios, cooling and excellent bins, it needs 6A per emitter at 2000 lumens. If you want 6000 lumens OTF as measured in all of our ceiling bounces/lumens tubes/integrating sphere, you’d need much more after factoring all the lens losses, driver losses, heat etc.
Probably need 2400 lumens in dijozz’s test if there is a 17% loss to 2000 lumens OTF, thus 9A per emitter.
I am guessing 27-30A at the tailcap is gonna be needed, a fair bit of which is really heat and not lumens. Don’t even dream about efficiency once comfortably past 6 amps per emitter.
Definitely 12awg copper bypass for this jobbie, just strip the insulation and do it. Enjoy the smoke if the light does puff though.
Hmm 12AWG bypass over 1cm.
At 0,052mOhm of resistance, wouldn’t you be trying to pull, at 3,6V average voltage, about 69 000A if there were not other resistances in the circuit, including the cell?
Yeah. Maybe you’d kill the emitters if there was a 6000mAh version of the Samsung 30T and bypasses everywhere.
Seriously just look at other “6000 lumens” lights measured in our ceiling bounce/tubes/spheres, like our ubiquitous BLF Q8 with 4 x XP-L.
Of course 4pcs of XP-L (at 1500 OTF lumens) is going to be much more efficient than 3pcs of SST-40 (at 2000 OTF lumens each). But even so, we are talking like about 25 amps for the 18650 in 4P config? Or is it closer to 30 amps?
This is a 30A light, if you wanna do 6k OTF lumens, low 20-ish if you want to gun at 5k OTF.
LOL…… We need to get the bottleneck out from the tail-end for sure.
Actually thinking about that, we use 2.5mm diameter copper wires here for our 240AC. That’s thicker than 12awg. More like 10awg.
Just thinking of a very common and convenient source. And seriously speaking, the 10awg stuff that some electricians source for is sucky……that’s why some of our local setups with air conditioner wirings doing higher currents might cause degrade and subsequently cause fires over time etc.
Besides, if it were a real 6000 lumen light, wouldn’t it be trying to pull something upwards of 80W?
It would be more efficient than an Emisar D4 of course even at that level, but it would throttle very quickly still.
Yeah, talking about the throttling and “heat soak”, i’m really trying to get myself away from lights that are super turbo pocket rockets.
Simply coz we do not get snow here and it’s near constant 29-31 deg C nights.
Hmm……just realised that this one has USB-C.
It might still be “practical” in the real world. A 5-20 seconds burst, then charge 2-5 minutes with a powerbank, then 5-20 seconds burst. Look at the above various batt discharge graphs plots @ high current and how it slides down as to why this is so. Even a VTC6 is doable. Such high-drain cells are able to accept relatively high currents till the very end so it’d be relatively fast top-ups.
For those flashaholic meetups thingys……you know what i mean?
And it would be especially nice for people having winter conditions.
131mm x 41mm head package. Empty weight 213g as per Taobao listing.
Lets face it, there are so many people here in BLF owning MT09R (multiples even) with TA driver and that’s also around this level in terms of current consumption.
So to be very fair to the light and maker/modder, quite “workable” and “practical”, if you can get it from TB direct, one for the collection at that price, perhaps.
Dollar per lumen is actually similar to the MT09R.
There are Samsung 20S for sale in TB, batt pulls……seemingly legit from end-user testing, 7 milli ohms. Seller tested 6 milliohms on the YR1030 tester. So the whole thingy is definitely doable from start to finish.
Don’t think this has been posted here or in other threads discussing this……
For the record. I presume that this is legit. Using the Nightwatch 4800mAh 35A store battery.
No mention of ambient temp or what, actually i believe it might be cooled in a certain way as i certainly won’t be able to get my BLF Q8 doing this, no way at all.
It’s obviously actively cooled.
SST40s have very low forward voltages, especially in parallel, and this curve follows the battery’s voltage gradually going down.
Yep, practically direct drive in Turbo. Relies on the small resistance naunces in the batt, driver, soldering points, springs w bypass etc.
