Wow I’m very excited for this. It’s like a Emisar D4 angle light.
I’m curious, if I put a 40T or 30T in there, will it push too much current for the 219B? How many amps does it take to be harmful to the 219B?
I wouldn’t recommend running it on turbo for long. The 219B emitters have higher Vf than 219C, so they won’t allow as much current to pass… but they also can’t stand anywhere near as much current. So I’m not really sure what to expect.
It might be a good idea to artificially lower the FET power on the 219B version, but it’ll require some testing to figure out if that’s necessary… and I’m not really set up for that kind of testing.
With most direct-drive lights, the emitters and batteries are chosen so the battery’s voltage sag and the emitter’s Vf curve will intersect at a safe point. But when using stronger cells or weaker emitters or lower-Vf emitters, things get tricky.
Are xpl hi and 219B the only emitters available?
I don’t really know what emitters will be used.
However, the ones I’ve seen are 219B and SST20.
Product listed.
Product listed.
Nice, and lots of emitter options, including SST20 10W NW 4000K CRI95. Definitely going to try that.
http://www.ff-light.com/index.php?route=product/product&product_id=54
Freeme, please update my interest to two lights, thanks!
The new details looks great. I thought I had posted interested before.
2 please… YES THATS TWO PLEASE
Prolly mentioned, gonna have battery available for purchase?
Interested
Interested!
Interested. If I didn’t already say so. :person_facepalming:
Product listed.
gogogogogo
coupon
5000 lumens? Wow! That’s quite a powerhouse on your forehead. I hope all the mass in the head soaks up a lot of heat.
I’d bet that a few of my night mountain biking friends would appreciate that kind of power. They ride year-round. It would be great in the winter with the cold keeping the light from stepping down too quickly.
If you’re looking for a right angle light, this one looks to be top of the heap. Even without the HI leds, 2500 lumens is nothing to sneeze at.
I am interested too.
Interested
interested
Very interested. Anybody with experiece with the sst20 cri95? How does it compare to the 219b or 219c at 4000k?
Beam profile is throw-ish in optics. Broad but focused hotspot, very subtle cool band around edge of hotspot. Tint from factory will be slightly green from factory, but with a minus green filter it’s perfection. Deep red rendering is off the charts, better than 219B R9080. Even without the minus green filter, wood tones look great, but with a minus green filter, nothing does it better.
interested in this….
and this, except I’ll mount the solar panel on the underside of the brim so the PL47 can power it’s own cooling. :student:
