10AIEVT9 Amazon US
the promotional code you entered is not valid.
10AIEVT9 Amazon US
Pls use this coupon code A3H90R6604ZOS5 and purchase from the follow links:
Thanks
code doesn’t work for me
Nope me iether
+3
If you don’t mind me asking as I didn’t see it posted anywhere, what percentage off is the code or what’s the discounted price?
Still not working.
code still not working.
x3
Code no werk……
^ Works! 10%
Tried to order but got this message:
We are unable to ship non-digital items from amazon.com to Australian shipping addresses.
Please choose a shipping address that is not in Australia to proceed. Some restrictions may still apply depending on the item.
And it’s not on Amazon AU
10% off
Use this coupon code and ourchase from the follow links.
10YXIFDL in follow link:
Doesn’t ship to Australia
The moment of truth has finally come. I just bought the new C4 charger to find out if my largest 21700 would fit or not fit? Eventually, they did fit. Even the Acebeam 21700 5.000mAh with protection circuit and button top (74.8mm in length) slipped easily into the C4. There are about 3mm left. The charger comes without the "brick" a.k.a. external power supply. Instead Miboxer provides a standard AC cable (90-240V) with mickey mouse connector to connect it directly to the wall socket. For those who want to connect the C4 with 12V DC one needs to have an appropriate external power supply.
The only downside I have discovered so far is that it can only charge 2x 26650 at once. The charging bays are too narrow to fit 4x 26650 side by side.
Thanks for your support.
Yes, the new C4 can max charge 2pcs of 26650+2pcs of 18650 battery together.
Our new model C4-Plus can charge 4pcs of 26650 together and also can charge the 21700 battery with protect board.
You can check the follow link to know the details:
That is exactly what I want! When C4-Plus will be available?
It will be available on Amazon at the middle of November.
