Did you purchase through Neal’s site or Lumintopinline? By the way, Neal is tops and really helped me out. Shipping from him was perfect in speed and tracking info.
I actually ordered a few of these and they came in the other day. I plan to use them in an MT09R so I can compare them to the 80CRI LED’s I have been using.
Hope both packages (conversion kit and batterie carriers) will be shipped.
My light is still waiting for upgrade…
I´m very late, but would it be possible to design a battery tube and carriers for 20700 / 21700 batteries.
Original tube is very thick-walled. So a thinner wall would maybe enable a bigger inner diameter of tube…
For 20700 cells you’d need to increase the inner diameter 5mm and 21700 would need 7mm. I don’t think there is any way they could do this without redesigning the lower head plus making a new battery tube, carriers and tail cap. I don’t see them doing this.
Thanks…
Maybe I would like to use LiPos instead of 18650er LiIons.
I´ve ordered a short tube, and a colleague has drilled me some coupler.
He will drill me also a coupler/extension which I can screw between short tube and original (long) tube.
So I will get a 300mm Tube…
Maybe he can drill a new tube for me and some adapter…
Original has about 46mm inner diameter.
New should have +7 = 53mm. With an 55x5Tube it should work… only flight of fancy… ;).
This light will remain 18650 but there is another light in the works that I have been debating between 21mm and 18mm cells.
My biggest worry is that the 21mm cells will make the battery tube too thick for some to easily grip. I have large hands and find the current GT grip comfortable but much larger and it would quickly become hard to hold for any length of time.
I figure those with smaller hands could already be at the point of hard to hold as is.
Maybe with the next one they can make a factory handle which is removable easily with one screw if don’t need.
Or put in a fan as Acebeam (Sorry…Just kidding )
Putting an Acebeam type fan would not be a bad idea. It should be relatively cheap to make and gives us an affordable option for active cooling. I wouldn’t mind 4x20700 or 8x20700 cells. People seem to be ok with the Imalent MS12 and R90C.
Then jump right to 21700. You can fit 20700 if you have that but you can’t fit a 21700 to a 20700 space. Either way it is too thick to hold the tube in hand so why not?
I’m with TA, the battery tube is big enough with 4 x 18650. I have big hands too & bigger is just not practical IMO.
BUT, if the powers that be decide to make the jump…… no sense in jumping halfway. Jump all the way and go with 21700. Might as well… both 20700 & 21700 are to big, so might as well go all out so the carriers could hold either one.
I will keep all of these comments in mind on the 21700, I am smack in the middle and don’t know what to do about the cells on this future light. I can see both sides.
Also, I might not be around for awhile due to a lightning strike on the ATT hub for the whole north Texas area:
I will try to catch up when my internet is restored.
What is the energy density of current cell formats? Which one gives the best ratio of energy stored considering its volume? We could always go bigger than 21700, it is already too big for normal use. Why not 26650 or even 32650 cells?
