Sofirn C8F host. 21700 C8F Available
So what can we do about this giant retaining ring? Think i can grind it down at an angle on the inside edge to fit a driver with 7135 on the bottom?
Also mind the other side of the driver: the edge on which the driver rests is wide too and may touch driver traces and components.
I have a 20mm lexel driver so it might be ok on that side but this is a good point. Overly complicated driver shelf and Alu ring. Almost better to use 17mm and spacer
Sure.
Any suggestions for a 17mm constant current driver that works with an E-switch? I’m really interested in this host…
Use fet+1x7135 driver with no parts on spring side.
In such a nice host it’s a shame to not have more regulated output options.
20mm like this? FET + 7135 Driver - 20mm - MTN-20DDm
Mtn also has a 22mm board but then you would have to sand it I guess…
contactcr
Yes.
+1
Just a quick check. Does anybody know if it’s safe buying from AE official store at this point or is it likely I will still receive a light with a dodgy FET? Many thanks.
Ask them before ordering just in case.
Perhaps they will just strip the lights of the faulty driver and replace it, or they’ll just sell them as hosts.
Thanks. Just sent Sofirn a message to their AE store. Will update the thread as soon as I hear back from them.
BTW, does anyone know an EU store that stocks a nice/recommended driver plus a board with LEDs that would fit the host? Cheers.
Received a reply from Qidong Yang:
“Yes,the MOSFET problem has been solved already, the stock now has already improved”.
So it looks like it should be safe to order from AE.
Thanks for checking on this. I wonder when it will be “safe” to order from Amazon to ensure getting the corrected version.
I just got some new FETs from MTN today and swapped it out.
New and old.
I gained 2A more at the tail and 350 more lumens @30s. There is a more instant jump to Turbo as well. I left the stock led wires.
Apparently we need to wait a little bit longer for Amazon. I’ve asked on AE and just got the answer:
“The AMZ not yet, because of the new produce batch is still on its transfer way to USA”
Also they advised to check directly with Amazon for the latest updates.
Did anything ever come of the flat tail with no switch? I assume it never saw the light of say but worth mentioning cause the C8F 18650 was like this.
I haven’t heard anything about it. I doubt they will do a flat tail cap for the 21700 version as the UI has that neat feature that let’s you use the tail switch for tactical use.
You can set your brightness then turn the light off at the tail cap (not the side switch). Then you can use the rear mounted forward clicky in a tactical manner. It’s pretty smart.
If you turn the light off with the side switch, the rear switch does nothing except connect main power. The led stays off. I like it. :+1:
So what you are saying is you are going to convince ToyKeeper to write a special C8F firmware to mimic this momentary mode memory deal so we can have the best of both worlds after replacing the driver or building a host? Sounds good thanks for doing that.
No, the stock driver can do this.
I know that. Jason has talked about the idea of replacing his driver so I assume it would be Narsil/Anduril variant and this is the host thread after all. I bought 2 hosts and 0 stock lights hence the nudge from me.
