Oh boy, consider me another new signup who is totally sold on one of these. Got myself a BLF A6 to replace an ageing Fenix PD30 (had enough of RCR123As…) and now I’m hooked. Add me to the list please!
Hope everyone is doing good, definitely haven’t changed my mind about this project! I’ve started building a collection of diffusers instead of buying other lanterns. I’m only buying one, this one.
Hi, #9 checking in! I haven’t been around here much lately, but still excited about a good lantern. I skimmed over the last several pages of the thread, and I’m a little concerned about apparent increases in the complexity of this light. Of course I don’t mind if there are options to ramp tints, brightness, mode groups, or whatever; customizability is cool. But simple operation is a VERY important point for me, and indeed one of the things that initially attracted me to this project. Will we be able to let someone borrow this lantern without a lengthy tutorial? IOW is there a “dummy mode” interface that lets someone turn the thing on or off, maybe easily toggling/ramping brightness? I just don’t want to have to write instructions on the light before letting my wife or kids use it…
Really not criticizing; I just don’t remember enough about different drivers to know what’s involved in this one, and I didn’t see a clear explanation of updated plans for operation/interface.
Ok I’m intrigued enough and, after Ottawa’s recent power outage, I’m in need of something that can keep us well lit playing cards and board games with friends for a few nights.
That’s all people need to know to use it. Eight words.
If you’re concerned about people getting into weird modes, you could put the lantern in muggle mode first, where it can’t do anything except the basics.
Interesting, not been reported here. I got stuck in Ottawa for two weeks in the ’90s with a big ice-storm. And no power. Even in the city. Helped my counterpart to keep his home running (generator running 24/7 and the sump pump to keep the basement dry)
Oh, he lived three miles up his own road (or drive as we would call it here). A bit extreme, but he had two jeeps and a big thing with a bull-dozer blade on the front. His daughter was a bit mad (one of the jeeps showed the sideways scars from some hits, but usually got lifted up again, usually, no questions asked)
I have two on order already, 688 and 689. I’ll try and read through the last 30ish pages of posts shortly, after being away for a while.
But. If you can switch to USB-C with a sane charging rate, I think it’s an excellent idea. I’m not interested in a frying-my-batteries rate. Just something that will use the future-proof interface for charging. If it costs a few dollars, fine by me.
I didn’t see what the expected cost is anywhere. But odds are, I’ll take at least two more. If it helps in getting an overall better price, put me down for 4 total for sure. Whatever it ends up being is fine.
Great work, take your time. I’d rather have an ultimate lantern than a faster shipping lantern.
Larry
Edit: I noticed you were going to try and open up other battery options. Awesome! I’m an EE/ME though, and I know that complexity truly sucks. 18650s are great. Others can be slightly better. Don’t hose this up trying to have too many power options. The perfect 18650 lantern is a remarkable achievement on its own.
18650 batteries are good, but the new and slightly larger 21700 cells are rapidly gaining popularity and can store up to 40% more energy (probably even more in the future as they seem to become the new standard). Also they are the same length as protected 18650s so that the only thing that we would need to change to be able to use them (at least the unprotected ones) is to make the battery tube a little wider, which isn’t adding much completely in my opinion.
Well, that’s only for one cell. According to Engineering Toolbox, in order to increase from the standard 4x 18650 tube to a 4x 21700 tube would take an increase of about 7mm in diameter. Not that it’s a big deal. For a lantern that will pretty-much always be left tail-standing, never meant to be hand-held, it can be a lot wider anyway. But, I’m hoping that’s a consideration for Mark II. This lantern is based on the existing Q8 design, so it will be Q8 sized.
Might be a stupid question as I am new here but why isn’t this driver going to be a buck boost? I think I under stand how the 7135s are being PWM switched directly and additive so you are only switching one on and off at a time but the design of 7135s is inherently inefficient compared to an actual buck-boost driver. With all the machining and materials involved is it such a big cost adder to switch to a buck-boost driver? It seems to me that with a lantern, run time is more important then with a flash light so efficiency, especially at low levels of output is important. I’d be willing to pitch in developing such a driver but its been a few years since my job required designing PCBs and programming micro controllers. Don’t get the wrong impression I just have been exclusively buying only constant current lights for a few years because I was worried about eye strain and like the idea of high efficiency. I’m hoping if this lantern keeps the 7135s there will be a mode without PWM and 4 brightnesses with each step turning on a new chip.
Currenly, the 4x7135+4x7135 driver is well understood and can be easily implemented with tint ramping. Actually, it has already been done.
About PWM, the PWM on Anduril/NarsilM drivers is so high that literally no humans can actually even perceive it.
What you are requesting is quite hard to do. That would require a new driver, which would be easy with a switch mode power supply, but not 7135s. Only 100% full power with both tints, and 50%/CCT can be activated without PWM. Unless I’m wrong.
Finally, it’s because of cost and time to market. We don’t want to rise the final price of the lantern by too much, and we don’t want to push our deadline further. We are predicting to start production hopefully a few weeks before Christmas.
