GearVita Daily Deal: Xiaomi Xiaobai Smart 1080P IP Camera - Panoramic HD, AI Humanoid Detection, Remote Alarm
The Olight M2R Warrior flashlight is the new rechargeable dual switch LED tactical flashlight from Olight. This flashlight is equipped with the latest XHP35 HD LED powered by a single high discharge rate 18650 with an output range of 1 to 1,500 lumens. The M2R features a quiet tail switch with minimal noise when being clicked on for tactical purposes. The tail cap of this light can magnetically charge directly through the tail tactical switch. The side switch has a similar operation as the Olight's series flashlights, while the tail switch can be switched between conventional and enhanced tactical operation modes allowing the user to access turbo or strobe with a single click. With its slim head, lanyard hole, and dual direction pocket clip, the M2R Warrior is the perfect tactical light to carry with you on any adventure.
Main Parameters:
LED: CREE XHP-35 HD
Compatible Batteries: 1 x 18650, 2 x CR123A
Light Output: 1,500 to 1 lumen
Throw Distance (Max): 208m
Peak Beam Intensity: 10,880 cd
Waterproof: IPX-8
Impact Resistance: 1.5 meters
Brightness Levels and Runtime:
Mode 1: 1,500~700 lumens - 3 minutes~110 minutes (Turbo mode will lower from 1,500 to 700 lumens after 3 minutes to prevent overheating)
Mode 2: 700 lumens - 2 hours
Mode 3: 250 lumens - 6.25 hours
Mode 4: 60 lumens - 20 hours
Mode 5: 15 lumens - 70 hours
Mode 6: 1 lumen - 25 days
Product Features:
● The body of Olight M2R Warrior features smooth but aggressive matching for just the right amount of grip while maintaining comfort over prolonged use.
● Durable metal tail switch design making the M2R rechargeable directly from the switch with the Olight signature USB magnetic charging cable.
● The tail cap uses a quiet tact switch and the side button is pronounced with a braille marking for ease of use in a dark and tactical situation.
● It only takes a single press of the tail cap switch to access the 1,500-lumen turbo or strobe mode for high stress situations.
● Comes with a high capacity and high discharge rate 3500mAh 18650 lithium-ion battery that supports up to 1500 lumens with long runtimes.
● Compatible with all 18650 batteries (with a discharge current over 6A and protection board) and the Olight micro-dok.
● Slim head design, detachable pocket clip for both carry directions, and lanyard hole for an enhanced and comfortable user experience.
● This flashlight can be turned on/off from either the side or the tail switch, making it adaptable to different operational habits.
● IPX8 waterproof rated for up to 2 meters under water without damage.
The M2R is the perfect carry to bring with you for any situation, no matter be used for tactical, self-defensive or outdoor, it will meet your different demands. It sells for $99.95 on most websites, but applying the coupon code "OLTM2RW" on GearVita, you can get it for only $89.98 and of free shipping: https://gearvita.com/olight-m2r-warrior-led-flashlight-1500-lumens.html
Related product:
https://gearvita.com/olight-m2t-warrior-tactical-led-flashlight-1200lumen.html
The Fenix BC35R is an all-round USB rechargeable bicycle light. The max output is 1800 lumens, making it a tough performer not only for city commuting, but also for country cycling. The innovative cut-off facula line guarantees safer cycling by not dazzling oncoming traffic, whether on foot or in vehicles. The OLED screen displays the current output and corresponding runtime, thus riders are constantly aware of the bicycle light status. The remote pressure switch makes instant operation possible during cycling, and changing road conditions can be abruptly dealt with. The Fenix BC35R bike light has built-in anti-theft protection which smartly monitors users' bicycles. Moving the bicycle will set off an alarm, also helpful when a potential danger or emergency is encountered.
Main Parameters:
LED: Cree XHP50 neutral white LED
Max Output: 1800 lumens
Max Distance: 146m
Output Modes: 6
Impact Resistance:1m
Waterproof: IP66
Batteries: Built-in 5200mAh/3.7V rechargeable battery
Burst: 1800 lumens
Turbo: 1100 lumens ( 2.2h** )
High: 400 lumens ( 6.5h )
Med: 150 lumens ( 12h )
Low: 45 lumens ( 28h )
Flash: 150 lumens
Product Features:
● Cree XHP50 LED offers even and soft neutral white beam - better for color rendering and vision protection.
● Orange-peel reflector makes every corner is clearer to sight and darkness is nowhere to hide.
● Max 1800 lumens output and 146m beam distance, guarantee safe cycling with better vision.
● The rechargeable built-in 5200mAh Li-ion battery offers max runtime of 28 hours. Standard micro USB charging port, charge as you like anywhere.
● Anti-glare cut-off facula line for safer cycling.
● Equipped with extra remote pressure switch - conveniently select desired output and activate.
● The user-friendly OLED screen displays current output and corresponding runtime, thus user is constantly aware of the bicycle light status, making the rider well-prepared for on-going riding trip.
● Intelligent anti-theft protection funtion smartly monitors bicycles, once the security key is removed, moving the bicycle will set off a piercing alarm.
● The functional switch will flash red when the runtime of low output level is less than 10 minutes.
● Overheat protection - The light will accumulate a lot of heat when working on Turbo mode. The light will automatically step down to a lower brightness level to reduce the temperature, but turbo mode can be reselected.
● Low-voltage warning - When the voltage level drops below a present level, the bicycle light is programmed to step down to the next lower brightness level until low output is reached.
● Quick-release light mount.
● High-strength aluminum body.
● IP66 rated dustproof totally protected against dust and foreign objects, waterproof can withstand heavy rain and splashing.
Applying the coupon code "FNBC35R", you can buy this bicycle light of $99.88 on GearVita. Grab your BC35R and don't miss the opportunity to have fun riding: https://gearvita.com/fenix-bc35r-led-bike-light-1800lm.html
Related products:
https://gearvita.com/fenix-bc30r-led-bike-light-1800lm.html
https://gearvita.com/fenix-bc30-led-bike-light-1800lm.html
Acebeam EC50 Gen III flashlight is updated version base on early one, now equipped with a powerful CREE XHP70.2 LED and powered by 1 * 26650 rechargeable Li-ion battery, max output 3850 lumens beam throw 326 meters, compact size and lightweight is for convenient operation. Also redesigned massy bezel must be your super personal body guard in daily use to outdoor and professional use while a simple press on the side switch is all you need to select output.
The body of EC50 Gen III has been knurled with a diamond pattern to make longterm use less harmful to the skin on your hands. The vents on the sides of the head to make sure the LED and circuits don't overheat are fewer but wider. The strike bezel has also been given a larger form this time, giving it a bit more heft than previous versions. It is the brightest EDC flashlight integrates high performance and long standby time, adventurers and flashlight enthusiasts are very excited for the release of the Acebeam EC50 Gen III.
Main Parameters:
LED Type: CREE XHP70.2 LED with a lifetime of 50,000 hours
Power Source: 1 * 26650 battery
Maximum Output: 3850 lumens
Max Beam Throw: 326 meters
Max Runtime: 50 days
Peak Beam Intensity: 26500cd
Waterproof: Standard IPX-8 (2 meters)
Impact Resistant: 1.2 meters
Output Levels and Runtime:
Firefly: 1 lumen ( 50 days )
Low: 200lumens ( 14 hours )
Mid: 1000lumens ( 2.8 hours )
High: 1800lumens ( 1.2 hours )
Turbo: 3850lumens ( 2 mins + 1.1 hours )
Strobe: 1800lumens ( 2.2 hours )
Product Features:
● Latest CREE XHP70.2 LED with amazing 5000K tint.
● Max output is a staggering 3850 lumens with a beam distance of 326 meters.
● Aircraft-grade aluminum body structure.
● Ultra-clear tempered glass lens with anti-reflective coating.
● Premium type III hard-anodized anti-abrasive finish.
● Smooth reflector gives perfect beam and throw.
● Tactical diamond knurling makes longterm firm grip easy on the hands.
● Streamlined body design.
● Easy to use side switch interface.
● Intelligent circuit board design for maximum performance and long run time.
● Digitally regulated output maintains constant brightness.
● Over-heat protection to avoid high-temperature of the surface.
● Reverse polarity protection prevents damage from improperly inserted batteries.
● Low battery indicator will flash when voltage down to 3V.
● Micro USB chargeable, plug USB cable directly into light to charger.
● Waterproof to IPX8 standards.
With unstoppable power like that, this flashlight is perfect for just about anything that will come up in everyday use. Great for typical chores where you need a light or even late night navigation, the EC50 Gen III is the ultimate light utility for most users.
It is on sale at the GearVita at a cost of $114.99, but if you enter the coupon code "ABEC50", the price will drop to only $102.99. Otherwise, the coupon code is valid until Oct 20th: https://gearvita.com/acebeam-ec50-gen-iii-led-flashlight-3850-lumen.html
Related products:
https://gearvita.com/acebeam-ec65-4000lm-rechargeable-flashlight.html
https://gearvita.com/acebeam-k30-led-flashlight-5200lumens.html
The Sunwayman C41CT flashlight is a compact and powerful EDC light featuring a stylish design. Weighing less than 4 ounces and measuring just 4.33 inches long, this flashlight is easy to store in your kitchen drawer or carry with you wherever you go! The torch's unique body is constructed from aerospace aluminum alloy and comes with a unique wavey knurling for a secure grip, also it is completely waterproof, so it's safe to use in any weather conditions. The Sunwayman C41CT can be powered by either a pair of CR123As or a single 18650 and can even be recharged internally when equipped with a 18650. When charging, the side switch doubles as an LED power indicator, letting you know when it's fully charged. The flashlight can emit up to 1000 lumens of light, provide up to 60 hours of runtimeand can produce a total of 6 outputs to cover any lighting needs.
Main Parameters:
LED: CREE XM-L2 U3
Color BIN: Cool white
Power Source: 1 x 18650 or 2 x CR123A
Max Output: 1000lm
Peak Beam Distance: 307 meters
IPX Rating: IPX-8 (waterproof and submersible up to 2 meters)
Impact Resistant: 1 meter
Outputs Mode:
Turbo - 1000 lumens
High - 580 lumens ( 150 mins )
Med - 130 lumens ( 800 mins )
Low - 16 lumens ( 3600 hours )
Two Hidden Modes: Strobe and SOS
Product Features:
● High quality LED of CREE XM-L2 U3, with lifespan up to 50,000 hours.
● Rugged anodized aluminum body is waterproof.
● Unique wave knurling provides secure grip.
● High-powered LED and smooth reflector provide maximum throw.
● Pair of tactical outputs for emergency situations.
● Easy-to-use pushbutton side switch lets you effortlessly cycle through outputs.
● While equipped with 18650, light is internally rechargeable through micro-USB charging port.
● Side switch doubles as LED power indicator, flashing green while light charges, glowing solid green when fully charged.
● Constant current circuit, uses one single 18650 battery or two CR123A batteries.
● The circuit CPU will detect automatically when the battery voltage lowers to 2.8V and the white light will flash slowly five times and turn off to protect battery.
● Reverse polarity protection prevents damage caused by improperly inserted batteries.
● Tail-stand capable, can be used as a lamp.
● Waterproof accords with IPX-8 standard.
● Memory funtion, the last mode used will be memorized for next time use.
Compact and versatile, the Sunwayman C41CT rechargeable LED flashlight is a powerful light that features all the qualities in a top EDC. Take the coupon code "SWMC41CT" before Oct 20th, get this top EDC flashlight from GearVita with the coupon price of $45.99: https://gearvita.com/sunwayman-c41ct-led-flashlight-1000lm.html
Related products:
https://gearvita.com/sunwayman-g20c-tactical-led-flashlight-1000-lumens.html
https://gearvita.com/sunwayman-c23c-multi-functional-flashlight-1000-lumens.html
Mi IR night light is equipped with an infrared motion sensor with up to 120-degree and 7-meter motion detection range. Using advanced photosensitive sensor and human infrared sensor technology with anti-infrared interference function, the sensor instantly reacts to the movement and turns on the light. It will last 15 seconds after you walk out of the sensing area. The Mi IR light is powered by batteries and making it a low power consumption, energy-saving and environment-friendly device.
Product Features:
● Extraordinary Sensing Function
120-degree sensing angle and sensing distance is 5 to 7 meters. Adopting light-sensitive and body infrared induction technology, the light can turn on automatically in the dark environment, 15 seconds duration, with anti-infrared jamming function.
● Two Brightness Modes
There are two brightness modes to switch: with 0.7 lumens mode and 3.8 lumens mode, you can adjust the brightness according to your needs.
● Extremely Low Power Consumption
Powered by 3 x AA battery, free you from socket trouble. The choice of ultra-low power consumption of the sensing program ensures only 0.25mW power consumption when in standby mode. 0.7 lumens mode can be used for about 12 months, 3.8 lumens mode can be used for about 6 months time.
● Safe Environmental Material
Selecting environmental-friendly ABS material and high-density polyethylene material, the light has a small body with flexibility, which is more durable, practical and safer.
● No Socket Constraint
With 3m glue on its back, you can stick it on wardrobe, stairs, bedside, etc. And it has an adjustable hook, provides brightness for you anytime.
● Soft Warm Light
2700K color temperature without visible strobe lights, protect the vision of your eyes especially your baby's eyes.
● Cool Lampshade
Total reflection structure of fish scales, can make the light equably reflect to the diffusion shell, provide a good visual experience for families.
● Freshnel Ultra-thin Lens
Equipped with a Freshnel ultra-thin lens which enhances the performance of the sensor.
● Minimalist Design Adds Unique Flavor to Life
The light adhering to minimalist design style, external soft round design encounters silkily-touching edge, easily matches with a variety of furniture style.
When talking about an ordinary night lamp that turns on when motion is detected, it wouldn't gain much attention from most human beings. Fortunately this is not just a night lamp running on AA batteries, it is an original Xiaomi Mijia night light! Never bump your foot in the middle of the night again for it can be put anywhere in your home. Apply coupon code "MIYSENSOR" on GearVita to get this night light with the price of $7.99: https://gearvita.com/xiaomi-mijia-yeelight-sensor-night-light.html
Related products:
https://gearvita.com/seenda-dual-usb-port-wall-charger-with-led-light.html
https://gearvita.com/official-international-version-yeelight-ylfw01yl-smart-atmosphere-candela-light-support-bluetooth-control.html
Sunwayman C22CC is an inventive flashlight, which uses the 18650 battery, the two lights equipped can work as well as simultaneously. C22C comes with charging instructions and low voltage protection, full care of flashlight "heart" to make it healthy. The main light can be controlled by a button, it's easy to operate and hand feel smooth. Unique side light can be used as a corner lamp which is full of yellow ray, so it is suitable to read at night or at camping. The head of Sunwayman C22CC flashlight is designed with multi-slot to make it cool, so that effectively increase the cooling effect. The charging's design of flashlight's tail is hidden in extreme to make the whole flashlight more beautiful and easy to use. The stainless steel attack head is located in the tail, and install a quick hole, so it can be connected to universal tripods quickly to meet various function's request.
Main Parameters:
Emitter: Cree XM-L2 U2 LED(primary), Cree XP-G2 R5 LED(side)
LED Lifespan: 50,000 hours
Estimated Usage Time: 42 hours
Luminous Flux: 820 lemens
Beam Distance: 310 meters
Battery: 1 x 18650 or 2 x CR123A or 2 x 16340
Waterproof: IPX-8 (waterproof and submersible up to 2 meters)
Impact Resistant: 2 meters
Output Modes and Runtime:
● Primary Light
Turbo (820 lumens) - 3 minutes
High (510 lumens) - 2 hour and 10 minutes
Mid (130 lumens) - 10 hours
Low (35 lumens) - 42 hours
Strobe
SOS
● Side Light
High (160 lumens) - 5 hours
Mid (46 lumens) - 13 hours
Low (16 lumens) - 68 hours
Product Features:
● Main light Cree XM-L2 U2 LED, side light Cree XP-G2 R5 LED, with a lifetime of up to 50,000 hours.
● High quality metal smooth reflector for main light maintains great throw diatance and spread with an ideal beam pattern, able to generate an 820 Lumen beam that can reach over 1000 feet away.
● Special secondary side LED produces up to 160 lumens of soft white light for close-range lighting.
● Aerospace-grade aluminum body with military-grade Type-III hard anodized finish, stainless steel retaining ring on the top to prevent any ingression of water and dust.
● Ultra-clear tempered glass lens is both impact and scratch resistant.
● Single pushbutton side switch uses optical lens to access all outputs.
● Stainless steel crenulated tailcap used as glass breaker, self-defense tool.
● Tail with three feet design, also used as tripod mount for hands-free illumination.
● Use one single 18650 lithium battery or two CR123A/16340 lithium battery for constant current circuit and constant brightness.
● Micro-USB charging port underneath tailcap for recharging battery internally (18650 and 16340 only).
● LED power indicator above side switch glows when charging, flashes when fully charged.
● Inverted on the plane to be used as candle lighting.
● Precision IPX-8 waterproof design, can continue to light under 2 meters.
● Stainless steel clip, can be linked to clothing at any time, flexible and more use.
● Flashlight tail UNC 1/4'' screw hole, can be installed directly on most of the equipment used.
Applying the coupon code "SMWC22CC" when checkout on GearVita before Otc 24th, you can get this flashlight at the final price of $39.99: https://gearvita.com/sunwayman-c22cc-rechargeable-led-flashlight.html
Related products:
Convoy S2+ flashlight is a powerful and cost-effective LED torch and used for many outdoor applications. It supports up to 1000 lumens output with the use of a 18650 Li-ion battery. Constant current circuit ensures constant output, with its ultra-long shooting function, its lighting range is about 50-100 meters. Moreover, it also has mode memory function, low voltage protection and battery reverse protection function.
Main Parameters:
Emitters: Cree XM-L2 U2
Lumens Range: 500-1000 lumens
Luminous Flux: 940 lumens
Circuitry: 2.1A
Color Temperature: 6500-7000K
Mode: Two kinds of mode - .three modes: low 5%-mid 50%-high100% and five modes: low 5%-mid 50%-high100%-Strobe-SOS
Power Source: 18650 battery
Beam Distance: 50-100m
Impact Resistance: 1.5m
Product Features:
● High Performance
Adopting XM-L2 LED light, with up to 1000lm high brightness and long service time, to light up your way in the dark.
● Two Group Modes Choice
Two kinds of mode group, group 1 (Low - Mid - High - Strobe - SOS) and group 2 (Low - Mid - High) to meet your different demands.
● Mode Memory Function
Convoy S2+ can memory the mode next time when turn on for more than three seconds. If less than 3 seconds, it will goes into next mode.
● Low Voltage Protection
When the voltage of battery is 2.9 - 3.1V, the flashlight flashes 2 times/sec with low brightness for alarm.
● Battery Reserve Protection
If your battery is reversed, it will not bright only, do worry about battery or circuit.
● Premium Material
Adopting high quality aluminum alloy material, durable and stable.
● Widely Applicable
Idea for cycling, hiking, camping, fishing, working, repairing and other outdoor activities.
Get this LED flashlight from GearVita for multiple use, it is perfect for working, outdoor camping, emergency, repairing, and daily use: https://gearvita.com/convoy-s2-led-flashlight-cree-xm-l2-u2.html
Related products:
https://gearvita.com/convoy-s3-xm-l2-led-flashlight.html
https://gearvita.com/convoy-t2-led-flashlight-320lumens.html
Hey Cathy does Gearbita offer free shipping ?
I was looking at the mijia motion detection lights on sale for 7.99$ but saw shipping was another 6$ Which makes it no longer a great deal
The Sunwayman C45CT flashlight is the powerful thrower searching flashlight. Wavy knurling design body ensures the light is easy-gripped. Charging Indicator Lamp cleverly built in the user-friendly side switch covered by sub-transparent rubber cap. The tail of the flashlight is ingeniously designed to be used as an emergency spike.
Main Parameters:
Emitter: Cree XM-L2 U3 LED
Max Output: 1000 lumens
Runtime: 60 hours
Beam Range: 450 meters
Power Supply: 1*18650 battery or 2*CR123A(16340) batteries
Light Color: Cold white
Working Voltage: 3.7V
Waterproof: IPX-8
Turbo: 1000 lumens
High: 580 lumens ( 150 mins )
Mid: 130 lumens ( 800 mins )
Low: 16 lumens ( 3600 mins )
Product Features:
● High quality LED of Cree XM-L2 U3, with lifetime up to 50,000 hours.
● Powered by single 18650 battery or two CR123A(16340) batterries to provide constant current circuit.
● Max runtime up to 1600 mins, with the reflector of big diameter, Sunwayman C45CT is capable of reaching up to 450 meters effective range.
● One single switch provides access to all functions.
● Four brightness levels and two special functions available.
● Constructed from aero grade aluminum alloy with HAIII military grade hard-anodized finish.
● Wavy knurling design body ensures the light is easy-gripped.
● Memory function, the last mode used will be memorized for next time use.
● USB charging system, charging indicator lamp cleverly built in the user-friendly side switch covered by sub-transparent rubber cap.
● Low-voltage indication, the circuit CPU will detect automatically when the battery voltage lowers to 2.8V and the white light will flash slowly five times and turn off to protect battery.
● Electronic reverse battery protection effectively protects the flashlight circuit.
● Indicator lamp for charging is built inside the side switch, it turns on in green and flash when it's under charging, constant green when charging finishes.
● Twisting the rear part of the tail cap leftwards to use it as an emergency spike to break glass when needed.
● Waterproof in accordance with IPX-8.
Purchase this flashlight of $49.99 on GearVita with the coupon code "SMWC45CT" when checkout, the deadline is Oct 26th: https://gearvita.com/sunwayman-c45ct-led-flashlight-1000lm.html
Related products:
https://gearvita.com/sunwayman-c22cc-led-flashlight-820lumens.html
Convoy S10 flashlight comes with stainless steel and aluminum alloy material which is durable and practical. Loaded with18650 battery, it also features with adjustable brightness and low voltage protection function. When the voltage is 2.9-3.1, the flashlight will flash twice a second at a low brightness.
Main Parameters:
Light Source Brand: Cree
Light Source Model: XM-L2
Light Source Bin: T4-7A / T6-4C / T6-3B / U2-1A
Color Temperature: 3000K / 4200K / 5000K / 6500K
Light Color: Warm White / Neutral Light / Natural Light / White
Driver: 7135*8
Power: 11W
Voltage: 4.2V
Max Brightness: 1000 lumens
Modes: 1%-10%-100%
Waterproof Rating: IPX6
Product Features:
● High-quality tainless steel and aluminum alloy material, durable and practical.
● Waterproof to IPX-6 standard, available in all weather conditions, don't worry about the rainy days anymore.
● As long as a cigarette, Convoy S10 only takes up a little space in your bag, compact and small size for easy carrying.
● 10W strong power light with 6500-7000K color temperature, suitable for gambling stone jade identification.
● Powered by 1 x 18650 battery.
● Memory function, when the flashlight is on over 3s, the current mode is in memory.
● Low voltage protection, when the voltage is 2.9-3.1, the flashlight will flash twice a second at a low brightness.
● Stainless steel head, durable and shock resistant.
● Level-3 oxidation treatment shell.
● Battery reverse protection, battery will reverse, do not worry, no problem will occur.
There are four options for you to choose from on GearVita, T4-7A, T6-4C, T6-3B, U2-1A, all of which can enjoy a discount of $3 with the coupon code "CVS10" when you checkout. The following is the price after the discount:
T4-7A - $14.99
T6-4C - $14.99
T6-3B - $13.99
U2-1A - $12.99
Product link: https://gearvita.com/convoy-s10-led-flashlight-1000lm.html
Related products:
https://gearvita.com/convoy-s9-xml2-flashlight-580lm-natural-light.html
https://gearvita.com/convoy-s2-led-flashlight-cree-xm-l2-u2-7135-6-2-mode-groups.html
The Klarus XT32 flashlight is specially designed for tactical and hunting. Using a US CREE XP - L HI V3 LED lamp beads with a max output of 1200 lumens and a long lifespan of 50000h, it has two settings - classic tactical setting and hunting setting, and 6 brightness modes to meet your luminous needs. This flashlight uses 2 × 18650 lithium-ion battery or 4 × CR123A battery which is easy to buy to eliminate travel troubles in charging. Equipped with a lanyard and a holster, it's easy to carry.
Main Parameters:
Emitters: Cree XP-L HI V3
LED Lifespan: 50000h
Luminous Flux: Max 1200lm
Luminous Intensity: Max 250000cd
Power Source: 2 × 18650 or 4 × CR123A
Working Voltage: 5.0 V-12.8V
Six Outputs:
Turbo (1200 lumens) - 3 hour runtime
High (400 lumens) - 7 hour runtime
Medium (100 lumens) - 34 hour runtime
Low (20 lumens) - 120 hour runtime
Strobe (1200 lumens) - 6 hour runtime
SOS (100 lumens) - 102 hour runtime
Two Programmable Settings:
Tactical Setting: One-touch turbo, one-touch strobe
Hunting Setting: One-touch turbo, one-touch low
Product Features:
● Cree XP-L HI V3 LED, max brightness up to 1200 lumens.
● Precision manufactured reflector with optimized design for extended range illumination, improved spotlight performance, max beam distance up to 1000 meters, exceeds current industry level.
● Patented dual tactical tail switch and side switch design to meet different user need, easy and intuitive operation.
● Two programmable settings and six brightness modes.
● Perfect for hunting, hiking, camping, search and rescue operations and more.
● Newest ITS intelligent temperature protection system, monitors internal temperature and adjust output for maximum brightness, protects LED and internal components to ensure safety, stability, optimum performance, and user comfort.
● Lock-out function of the side switch prevents accidental or unnecessary activation.
● Intelligent capacity indicator monitor remaining battery capacity anytime.
● Front and rear mounted springs protect against shocks and drops.
● Aerospace aluminum alloy construction, CNC precision machining, mil-spec HAIII anodizing, rugged and anti-abrasion.
● Hardened and AR-coated lens, anti-abrasion and high light transmittance.
● Waterproof IPX-8 ( underwater 2m ), suitable for rainy weather.
This particular flashlight has a 1000 meter range, is programmable, and has a host of other features that make it really stand out from your average searchlight. This flashlight is really excellent for outdoor activities such as hunting or search and rescue or even professional work. It's really quite versatile and can be used in a myriad of situations. Get Klarus XT32 of $89.99 by appling the coupon code "KRXT32" from GearVita, it's definitely powerful enough to get the job done: https://gearvita.com/klarus-xt32-led-flashlight-1200-lumens.html
Related products:
klarus xt12gt
klarus xt11x
The Xiaomi Mijia 1S Walkie Talkie is packed with some powerful features – a huge 10km range, 8 days of standby time and up to 17 hours of talk time, GPS positioning and even an FM radio function. It has a detachable antenna for easy storage and has a micro-USB port for charging that can also be powered with a power bank. It supports the Very High Frequency (VHF) range spanning from 136MHz to 174MHz, also comes with support for the Ultra High Frequency (UHF), i.e. the frequency range between 403MHz and 470MHz. Xiaomi walkie talkie can be used almost anywhere, including metropolitan areas with a high degree of radio interference. On top of that, the device comes with support for FM Radio, allowing you to tune in to your favorite radio stations, also capable of location sharing.
Product Features:
● 41% thinner than last generation, 43% lighter, built-in back clip, one hand handling.
● Not only support 3.5mm earphone port, but support Bluetooth headset with dual mode Bluetooth chip.
● Micro USB charging port, no need to worry about loss of charger, convenient and practical.
● Quick to form a team, once one starts a team, the others can click to join the team without putting complicated frequency.
● Location share function, in the range of calls, it can check the location of teammates by the screen or App even there is no Internet.
● 2190mAh big capacity battery, micro-USB charging design.
● Long time to use, 8 days stand-by time,17 hours for normal use.
● Auto detection function during charging, prevent the risk of overcharge, over discharge, over voltage and other issues.
● FM radio function, it can search channel in 87 - 108MHz, providing entertainment apart from communication, but the talking between walkie talkie have priority when listening to radio.
● Digital filtration, good talking effect even in various complicated environment.
● In order to achieve clearer and louder call sound, the speaker has a speaker volume that is 65% larger than the effective radiation area of the previous generation. The maximum volume is increased by 162%, and in a noisy environment, good call performance can still be maintained.
● Sending voice without pressing talking button when your volume is reached to a certain level,free your hands.
● Suitable for two-way communication from different locations.
● A maximum power of 3W and a call distance of 1-5 kilometers in order to meet the call needs in a variety of scenarious.
● Comes with UHF frequency range of 403-470MHz, and VHF frequency range of 136-174MHz., give it the ability to be used in a densely populated area as well as in the wild where there is little or no obstruction to the radio waves.
● Comes in black and white colors with along with handy display and some buttons on the surface for controlling the device.
Applying the coupon code "MIJIA1S" when checkout on GearVita, you can get this Mijia 1S walkie talkie with the price of $41.9: https://gearvita.com/xiaomi-mijia-1s-smart-walkie-talkie.html
Related products:
xiaomi smart walkie talkie
xiaomi mijia d301 walkie talkie
Lumintop Tool AA 2.0 is a portable mini AA flashlight, which is the upgrade version of bestseller Tool AA. With the incredible handy and compact size, it emits a max output up to 650 lumens with the compatibility with one 14500 rechargeable Li-ion battery. Four output levels for various lighting demands, and additional Strobe for emergency situations. The included diffuser makes it best for reading, campings and so on by creating a soft and pleasant beam. There are two tail versions for options, tail switch and magnetic, capable for tail standings to serve as a candle or magnetic suctions on a metal surface for different position lightings. Two positions body clip offers various wearing manners, such as clip on your pocket or on a cap to free your hands. Tool AA 2.0 is essential for camping, touring, home using, gifts, EDC gears, and emergency lightings.
Main Parameters:
LED: Cree XP-L HD LED
Power Source: 1 × AA or 1 × 14500 rechargeable Li-ion battery
Max Output: 650 lumens
Peak Beam Intensity: 3420cd
Peak Beam Distance: 127 meters
Waterproof: IP68
Impact Resistant: 1.5 meters
Output and Runtime:
● Powered by 14500 Li-ion Battery
Low: 16 lumens ( 37hrs )
Med: 85 lumens ( 6hrs 9mins )
High: 360 lumens ( 1hr 19mins )
Turbo: 650 lumens ( 33mins )
Strobe: 360 lumens ( / )
● Powered by Alkaline Battery
Low: 3.7 lumens ( 2.5 days )
Med: 25 lumens ( 11hrs 50mins )
High: 140 lumens ( 49mins )
Turbo: 220 lumens ( 21mins )
Strobe: 140 lumens ( / )
● Powered by Ni-MH Battery
Med: 25 lumens ( 12hrs 30mins )
High: 140 lumens ( 2 hrs 33mins )
Turbo: 270 lumens ( 43mins )
Product Features:
● Utilizes XP-L HD LED with a lifespan of 50,000 hours.
● Powered by one AA or one 14500 rechargeable Li-ion battery.
● Two ways to select outputs: Tail switching or twist the head.
● Four output levels plus Strobe with max 650 lumens output.
● Mode memory function recalls the last use output when turning on next time.
● Super long runtime up to 2.5 days in Eco mode.
● The optional magnetic tail cap is capable for tail standing to serve as a candle.
● Light-weight and compact, best for EDC use.
● Made of aircraft-grade aluminum alloy, premium type Ⅲ hard-anodized anti-abrasive finish, toughened and wear-resistant.
● IP68 rated dust-proof and waterproof, submersible to 2 meters.
Applying the coupon code "LMTAA2" on GearVita, only $18.99 needed, you can get this best-selling mini AA flashlight: https://gearvita.com/lumintop-tool-aa-2-0-flashlight-650-lumens.html
Related products:
lumintop odf30c
lumintop gt mini
The Imalent MS12 is one of the latest and brightest torches, also known as "the king of light". It is powered by 12 American Cree XHP 70 LEDs and can produce fan cooled 53000 lumens with a max beam distance of 913 metres. Built in high power cooling fan, silent, waterproof, heavy wind, which is a perfect combination of great energy and technology.
MS12 is extremely compact and comfortable to hold, utilizes 6 side lights for camping, fishing and more other outdoor lighting experience. It features Imalent's signature high-grade side pressure switch, this ergonomic design provides an unprecedented level of grip. Eight output levels ensure long runtimes with low or high output in any situation. The "hide strobe" feature keeps you safe by starting quickly at critical moments.
Main Parameters:
LED: Cree XHP 70 LED
Power Source: Built-in Li-Ion battery pack
Max Output: 53000 lumens
Peak Beam Intensity: 208000cd
Peak Beam Distance: 913 meters
Light Temperature: 6000 - 6500K
IPX Rating: IPX-8
Output and Runtime:
Turbo: 53000-15000 lumens ( 3+78mins )
High Ⅲ: 30000-15000 lumens ( 4+80mins )
High Ⅱ: 15000 lumens ( 1hr 36mins )
High Ⅰ: 7500 lumens ( 2hrs 45mins )
Middle Ⅱ: 3800 lumens ( 5hrs 45mins )
MiddleⅠ: 1900 lumens ( 11hrs 10mins )
Middle Low: 900 lumens ( 22hrs )
Low: 300 lumens ( 55hrs )
Product Features:
● Utilizes 12 pieces of American XHP70 LEDs, Imalent MS12 LED Flashlight comes with a lifespan of up to 5000 hours and a maximum output of 53000 lumens.
● Built-in self-testing intelligent charging circuit which is convenient, fast and safe.
● Eight power levels which can be changed quickly with instant turbo available.
● Six battery capacity indicators around the flashlight head, 360-degree shows the capacity any time.
● High efficiency constant current circuit maintains consistent brightness.
● Features a lock and unlock function. With the flashlight off, press the switch button 3 times, the red indicator will flash twice to indicate the flashlight is locked. Press the switch button 3 times again, the green indicator will flash twice to indicate it is unlocked.
● Built-in thermal control module automatically adjusts the brightness output to keep the unit from overheating.
● Combination of toughened ultra-clear mineral anti-reflective coated glass.
● Aluminium orange peel reflector.
● Aerospace-grade aluminium alloy body, wear-resistant Type Ⅲ hard-anodized surface treatment.
● Waterproof to IPX-8 standard (2 meters submersible)
Learn more about it on GearVita, if you are interested in it and want to bring it home, remember to use the coupon code "IMMS12" to get the $100 discount, which will give you a lowest price of $389.99 compared to any other websites. And when you received your MS12, it will bring you absolute shock in the night: https://gearvita.com/imalent-ms12-led-flashlight-53000-lumens.html
Related products:
nitecore concept 2
nitecore tm10k
The Imalent RT35 flashlight has a maximum output of 2350 lumens from the Cree XHP35 HI LED and is powered by 4 x 18650 Li-ion batteries. Offering excellent output and an incredible throw up to 1338 meters, the torch is the ideal searchlight for applications requiring a far throwing beam.
The RT35 features innovative magnetic charging, simply attach the included cable to the magnetic plate on the side of the torch to recharge the batteries. Removing the requirement for an external charger makes the torch more portable and allows for quick and convenient charging on the go.
Five output levels, ranging from 50 to 2350 lumens, and a hidden Strobe mode ensures you can have a long runtime with low output or high output when required, so you can prepare for your night time outdoor adventure well in advance. The RT35 is fitted ith a user-friendly side pressure switch to operate the output selection. Tucked neatly below the switch are three multi-functional charging indicators which flash red when the battery voltage is lower then 3.2V and change from red to green when the batteries are fully charged at 4.2V.
Main Parameters:
LED: Cree XHP35 HI LED
Power Supply: 4 × 18650 battery
Beam Distance: 1338 meters
Peak Beam Intensity: 449000cd
Max Output: 2350 lumens
Waterproof: IPX-8 standard
Impact Resistant: 1.5m
Output and Runtime:
Turbo: 2350-1500 lumens ( 8+162min )
High: 1500 lumens ( 3h 45min )
Middle: 750 lumens ( 6r 10min )
Middle Low: 350 lumens ( 12h 45min )
Low: 50 lumens ( 60h 162min )
Product Features:
● Utilizes one American XHP35 HI generation LED, with a lifespan of up to 50000 hours and a maximun output up to 2350 lumens.
● Built-in safety self testing intelligent charging circuit, convenient, fast and safe.
● Exquisite, powerful, extremely long throw at over 1300 meters.
● Built-in intelligent temperture control module can automatically adjust the brightness output.
● Built-in magnetic charging, higt grade and portable.
● 6 levels which can be exchanged quickly and instant turbo.
● Battery capacity indicators besides power switch, shows the capacity any time.
● High efficiency caonstant current circuit will maintain constant brightness.
● Combination of toughened ultra-clear mineral and anti-reflective coating glass.
● Aluminium OP reflector.
● Aerospace-grade aluminium alloy body, wear-resistant Type III hard-anodized surface treatment.
● IPX-8 standard waterproof (2 metres submersible).
● Built-in multi-functional charging incicators.
▹Function 1- Lower power warning:
When the battery voltage is lower than 3.2V,the red indicators will turn on.and if users try to activate turbo mode,the red indicators will flash three times to remind users battery too low to activate it.
▹Function 2 - Charging:
The indicators will be red when it is charging and turn green when it is fully charged to 4.2V.
This light is incredible for spot lighting and adventure sports requiring a long distance throw. With the coupon code "IMRT35" of GearVita, you can get this throw king of $74.95. Look at it, you will find out the discount is super: https://gearvita.com/imalent-rt35-led-flashlight-2350lm.html
Related products:
nitecore concept 2
imalent ms12
IMALENT DX80, "The End of Darkness", is a rechargeable LED flashlight with intelligent design that focused on maximum brightness and runtime that can be applied to all kinds of environments. Its 8 pieces of American Cree XHP70 2nd generation LED make it capable of a max output of up to 32000 lumens. With its advanced circuit design, the OLED display can show the output, voltage and modes, the ease of use that this brings for outdoor activities will change your world. It allows you to plan effectively, and lower the risk of ever running out of light in the dark.
Main Parameters:
Emitter Type: Cree XHP70.2
Light Color: White light
Battery Configurations: Built-in 8pcs 3000mAh battery pack
Luminous Flux: 32000 lumens
Max Range: 806 meters
Color Temperature: 6500K
Waterproof: IPX-8 waterproof 2 meters
Output and Runtime:
Turbo: 32000-7000 lumens ( 3+100min )
High: 13000-7000 lumens ( 8+122min )
Middle High: 13000-7000 lumens ( 2h 25min )
Middle: 5000 lumens ( 5h 40min )
Middle Low: 500 lumens ( 40h 46min )
Low: 120 lumens ( 168h )
Product Features:
● Utilizes 8 pieces of American Cree XHP70 2nd generation LEDs, with a lifespan of up to 50000 hours and a maximum output of 32000 lumens.
● The shot distance is up to 806 meters with wide beam range.
● The multi-functional OLED display can show various parameters and settings.
● Built-in battery pack includes 8pcs 3000mAh 18650 Li-ion batteries with high discharge performance.
● High efficiency constant current circuit will maintain constant brightness.
● Anti-reverse battery protection.
● Intelligent temperature control, when the body's temperature is up to 50 Deg.C, the LED display flashes 8 times for 30s to give a warning. It will also automatically adjust the current to keep the flashlight to work under 50 Deg.C for long time.
● Low power warning, when the battery voltage is under 13V, the battery symbol will flash 10 times per minute to remind user to change or replace the battery.
● Ultra clear toughened glass lens, the light transmission is up to 99pct with scratch and impact resistant.
● Waterproof level up to IPX - 8 ( 2m submersible ) the flashlight can work normally even in heavy rainstorms.
● 1.5m impact resistant.
● Tail stand function.
IMALENT DX80 can be used in all kinds of situations, such as adventuring, search and rescue, night fishing, industrial use, etc,. Applying the coupon code "IMDX80" on GearVita, you can get $120 discount, it will definitely become your good helper: https://gearvita.com/imalent-dx80-led-flashlight-32000-lumens.html
You may like:
xiaomi mi pad 4 plus 4g review
xiaomi mi box s tv box global version review
The Xiaomi FZ101 flashlight features with 3 adjustable brightness levels and 2 function modes of Strobe and SOS. With zoomable function, it can provide you with most suitable light, meeting your various needs of lighting, such as night camping, running, observation or exploration and more. Premium aluminum alloy body provides a long service life.
Main Parameters:
LED Lifespan: 50000 hours
Brightness Range: 500 - 1000 lumes
Typical Luminous Flux: 672 lumens
Light Range: 365 meters
Beam Power: 10W
Color Temperature: 5500 K
Battery Capacity: 2600mAh
Waterproof Standard: IPX-6
Product Features:
● Lightweight Mini Design
With its mini size, it is portable for you to bring it outside.
● Aluminium Alloy Shell
Minimalist design, full of texture. The body is made of premium aluminum alloy, lightweight and durable for use.
● Max 1000 Lumens Brightness
With high brightness, meets your various needs of lighting, such as night camping, running, observation or exploration and more.
● 5 Modes Dimming and Zoomable Design
With 3 adjustable brightness levels and 2 function modes of Strobe and SOS, as well as the zoomable function, it can provide you with most suitable light.
● 2600mAh Large Capacity Battery
Comes with a 2600mAh large capacity battery, bringing you a lighting endurance up to 2375mins, longer working time and power bank discharge time.
● USB Rechargeable Function
No need to remove the battery repeatedly. With the USB Type-C charging port, providing convenient and fast charging for you.
● Unique SOS Mode
It is unique with the SOS mode. Press the function button to send a distress signal, quite practical.
Applying the coupon code "MiFZ101", you can get this Xiaomi zoom flashlight with the price of $27.99 from GearVita: https://gearvita.com/xiaomi-fz101-zoom-flashlight-1000lm.html
In addition, there is the Black Friday promotion on our website now, prices are very affordable, you can go to see: https://gearvita.com/black-friday-sale
You may also be interested in:
xiaomi mi portable mouse
xiaomi 70 minutes wifi car dvr
Lumintop EDC01 is a mini keychain LED pocket AAA flashlight which emits a max 120 lumens with Cree XP G3 R5 LED by a single AAA flashlight. Four color options, tail standing ability, twisty switch operation, mini in body size, IP68 rated protection, EDC01 is the best for your every day carries, as well as a multi-function lighting tools.
Main Parameters:
Emitter Type: XP-G3(R5) LED
Max Output: 120 Lumens
Range: 37m
Peak Beam Intensity: 553cd
Battery Configurations: 1 × AAA battery
Working Voltage: 0.9-1.5V
Waterproof: IP68, underwater 2m
Output and Runtime:
Low: 5 lumens ( 36h )
Med: 32 lumens ( 4h )
High: 120 lumens ( 30min )
Product Features:
● Utilizes Cree XP-G3 (R5) LED with 50,000 hours lifetime.
● 3 modes with a max 120 lumens output and an up to 36 hours run-time.
● Runs on one always available AAA Ni-Mh or Alkaline battery.
● Compact and light-weight design, easy to carry.
● High-efficiency digitally regulated circuit maintains constant brightness.
● Bead surface optical lens for soft and balance beam.
● Glow-in-the-dark O-ring and optional diffuser easily locates the light in the dark.
● Simplify twisty switch makes it easy access all modes.
● Capable of standing up on a flat surface to serve as a candle.
● Make of aircraft-grade aluminum alloy with wear-resistance painting.
● IP68 rated protection, impact resistance to 1.5 meters.
Four colors optional of on GearVita, blue, pink, purple and golden, the exquisite package fits for applications such as gifts, EDC, tools etc.: https://gearvita.com/lumintop-edc01-mini-flashlight-120-lumens.html
Hot sale products:
oneplus 6t 256gb
yi 4k action camera floating grip
Xiaomi Yeelight YLDP06YL smart light bulb paints your home with colors anytime and anywhere, see the world in a new light. Provides light together with comfortable experience, it is a warm bulb with proper brightness could be used for reading, party and also help you get rid of the tired with soft light.
It supports WiFi control and brightness adjustment via the companion APP. The smart bulb comes pre programmed with over 16 million colours and different tones of white. Not only does this smart bulb has endless amounts of colours to choose from, you can sync the lights with your favorite music.
Product Features:
● Plug and Play
No hub required, just connect the bulb directly to your WiFi at home.
● Complete Control
Control your lights from anywhere using your smartphone and Yeelight APP ( download from Apple Store or Google Play ).
● Vast Color Options
Match any occasion with the 16 million colors and adjust the brightness as well as color temperature from warm white ( 1700K ) to daylight ( 6500K ).
● Sync Lights with Music
Syna the lights to your favorite song and explore how lights change with rhythm, spice up your party or holiday decoration with changing colors.
● Voice Control
Control your lights hands-free with Amazon Alexa and Google Assistant.
● Long Lifespan
With the brightness of 800 lumens in just 10W, the bulb provides you with 25000 hours of high-quality luminance and loyal companion.
● Energy Saving
Reduce energy use up to 83 percent without brightness or quality loss compared to a 60W incandescent bulb.
● Compatibility
Compatible with Android, iOS, Amazon Alexa, Google Assistant and IFTTT.
Play with light, you can choose from different colors to match the light to your mood. One color, one mood. GearVita provides E26 and E27 options, let you experience different atmosphere everyday: https://gearvita.com/xiaomi-yeelight-yldp06yl-smart-light-bulb-10w-rgb-wifi-control.html
You may also interested in:
best xiaomi huami amazfit bip smartwatch
best xiaomi redmi note 6 pro
This Xiaomi Mijia Yeelight Sensor Light adopts professional optical design and its soft light protect eyes from dazzling at night. With infrared sensor technology, the light turns on in the dark when it is detected a movement at a side margin of 2-3 meters or a distance of 5-7 meters, and after 15 seconds when you leave the sensing area, the light turns off automatically. Built-in 750mAh lithium battery, capable of running for more than 120 days at auto mode after fully charged.
Product Features:
● Easy to Install
▹ Suspension: Open the rear hook, Hang it in any position you need, easy and practical to operate.
▹ Pasteability: Tear the adhesive tape on the back and stick the light in any corner you need , such as hallways, stairs, lockers, headboard and entrance.
▹ Magnetizability: The product has a built-in magnet, can be adsorbed on the surface of a refrigerator or other magnetic access furniture.
● Long Operating Time
With a built-in 750mA high capacity lithium battery, charged by USB port once it can be used up to 120 days, it frees you from frequent charging problems.
● Human Body Infrared Sensor
120 degree detection angle, 5-7 meters detection distance on the front, 2-3 meters on the side. With the advanced photosensitive function, the light will turn on automatically in a dark environment.
● Two Lighting Modes
▹ Detection Mode: with a photosensitive and infrared human body sensor, the light comes on when people close and turn off when people are remain for 15 seconds.
▹ Constant Lighting Mode: clearly illuminate your night without pressure to find items at night.
● Warm White Light
Use of 2700K warm light, comfortable and warm light color temperature. Professional optical design, away from the reflection, do not disturb the night sleep in the family.
The intimate functions are placed in the yeelight sensor light with the distribution of soft petal-style light, built-in Fresnel lenses and photosensitive sensor. The price on GearVita is also very intimate, only at $15.19. Simple design that matches various decorations for the home, it is not only a light, but a perfect decoration: https://gearvita.com/xiaomi-mijia-yeelight-sensor-light.html
Hot sale products:
xiaomi yeelight yldp06yl smart light bulb
xiaomi mi 8 pro 128gb
