I’m not sure, just before oktober Barry told me of some production delays because old models needed to be produced first for some sale. At least I did not have a long list of complaints about the SP36, I just asked for a driver retaining ring instead of glue, and for a neutral emitter choice. That would delay it some more but I can imagine that Sofirn will ignore my tips, and then it will still be a nice light.
Thanks djozz for sharing your preview for this flashlight.
Good to see more additions to this format, which seems to be a sweet spot for output vs weight since HaikeLite MT01/MT02
The worst thing I can see happening from putting three new, good-quality cells of the same model into a light like this and handing it to a “muggle” to use and recharge in-light is that they won’t think my own lights are as cool as they used to.
At high charge and discharge currents (much higher than anything in this light) the differences in internal resistance between cells might be enough to cause problems, eventually, but even then the outcome would be accelerated wear on the pack.
At the charge and discharge rates of this light, I wouldn’t even be too concerned about “a 2200mAh store brand protected cell […] put in the light alongside a high discharge 30Q and a 3500mA high capacity cell.” It’d be a stupid thing to do, and wear and tear would certainly be accelerated, but it doesn’t strike me as a dire situation. The 2200mAh’s protection might trip, leaving the 30Q and the high capacity cell to carry the load. More of the load would fall to the 30Q, which is capable of direct-driving 4x XP-L2 emitters on its own, if need be. During charging, the 30Q would draw more of the current, until it didn’t. It wouldn’t overcharge. None of them would.
Safety and caution are important. Making a much bigger deal of something than necessary isn’t cautious and doesn’t serve safety.
Hi, can we use flat top 30q for the flashlight? Or is this a button top cell flashlight?
This is a button top flashlight, but cells with only the slightest protruding top will work.
Thanks. Will need to get 2 sets of button tops for this.
I got a message about the SP36 running too hot with NarsilM, with a request to try to fix it. NarsilM is not maintained any more though, and has no real thermal regulation, so I sent this instead:
http://toykeeper.net/torches/fsm/anduril.2018-10-17.SOFIRN_SP36.hex
I don’t have a SP36 so I had to guess about some config options, but I’m hoping this will work. Is there any chance you could try it?
Thanks for taking the time to adapt Anduril for the SP36. I did not see the overheating problems on my SP36 sample (it is not that different from how a Q8 behaves) but I would not mind Anduril on the SP36
But concerning my flashing skills, they are on pre-historic level. For me to flash the MCU would require lots of time to figure out how to do that on my ancient Mac, reading Hoop’s tutorial, acquire clip and other stuff, and probably an extra brain.
The chance of succes would increase enormously if I sent you the SP36 sample (which would hurt quite a bit and cost me 20 dollars, but for the sake of progress would be ok), or even better if Sofirn/Barry would send you an extra SP36 sample.
The glue could be an issue, and I’m a little concerned about the wire going from a MCU pin to some other parts. Would have to remove that before flashing. But maybe I won’t have to?
It’ll be faster if we don’t have to wait for shipping and such, so I’m hoping Sofirn can test it.
To make my SP36 sample a bit less sample and a bit more useful, yesterday I changed the leds to Samsung LH351D 4000K 90CRI (bought them from led4power). I changed the led wires from 24 AWG to 18 AWG to compensate for the higher Vf of the LH351D compared to the XP-L2’s that came with the sample. I did not bypass the tailsprings.
The light is slightly less yellow than my BLF Q8 with the same leds (those were obtained from AEDe) but nevertheless very comparable: at low level a bit above the BBL, diving just under the BBL at max. Great colour rendering with a nice neutral tint but without the rosiness of the high CRI Nichia 219B.
The output on freshly charged 30Q’s is 4250 lumen at start, 4000 lumen at 30 seconds (corrected to maukka’s calibration). The temperature stepdown (that I had set previously at 60 degrees as measured on the outside of the head) kicked in at 4 minute 40 seconds, so comparable to the XP-L2 situation, the wattage seems to not have changed much.
Nice! I’m jazzed for this light.
Now if it will only come without glue so folks can mod it like you did…
That explains a lot. I haven’t found LH351D to be very good so far, because it’s warmer and greener at the low levels where I use lights. The tint is okay on very high modes, but I almost never use those so it’s not a big consideration. I typically choose emitters based on how they perform at 100 lumens or less.
Too many lights do this, where the tint is only good on high modes:
When playing around with flashlights I’m very picky about tint, but unlike most tint snobs here I prefer the tint on top of the BBL instead of under it.
The 219B sw45 R9080 is nice but I like a bit less rose and a bit more yellow, I like the sw40 R9080 a bit more. On the other hand the LH351D 4000K 90CRI could use a bit more red in the tint (I do not find it obviously green btw, also not at low levels).
But when using a flashlight outside, the precise tint matters much less to me, it must not be too far from the BBL, but I don’t care if it is above or under it. I do see and appreciate the colour rendering however, and this LH351D has plenty of that!
Because of the new 90+ CRI leds in the SP36 sample, its category (3x18650 compact soda can style, over 4000 lumen, high CRI) is now even closer to the ROT66 219B sw45 R9080. The ROT66 will of course be valued higher because of its highly appreciated tint but one of the trumps of the SP36 will be its better throw.
I just compared the throw of the two lights. I set them at close to the same (arbitrary) output (I corrected the throw values for the last bit of difference) and compared throw at 7 meters. It appears that at the same output, the spot brightness (throw) of this SP36 mod is 2.1 times higher.
The throw difference would increase considerably if XP-L Hi leds would be used in the SP36.
_
I checked the charging speed of the SP36 sample, Barry had informed me that it is set at 2A. With a Blitzwolf charger (2.4A max charging according to specs) and a short Blitzwolf USB->USBC cable, I measured 1.65A charging speed when the batteries were at 3.4 V (so 550mA per battery). So a bit lower than 2A but it could be my equipment lagging the speed. Charging completely empty 30Q’s should take about 6 hours at this speed.
@djozz, actually you are probably right.
They said they set the charging rate for 2A at the cell level, not at the USB buck converter level.
That means since the USB charger is outputting about 5V at 1,65A(could be 1,75A if you used an even shorter and thicker gauge USB cable), that would mean the charger is outputting 8,25W, and at 4,2V max charging voltage, that is about 2A to the cells.
TLDR: The cells are being charged at 2A at 4,2V.
[quote=djozz]
The throw difference would increase considerably if XP-L Hi leds would be used in the SP36. :person_facepalming:
Thanks Captain Obvious…
^ thanks Blue, did not think about that.
Of course that is obvious, but I mentioned it to remind that the SP36 can be increased in throw (by a factor 2) by swapping the leds, without loosing too much output, while in contrast the ROT66 does not have that option.
Any more news about this light? Availability? Final specs?
+1, maybe they are busy working on other things. I’m ready to buy one of these. I tried to get this light when it had the HXP 50 but was already discontinued.
