Yeah by default the Anduril UI shipping with the Fireflies seems to ramp up to the maximum regulated ouptut, which caught me off guard as well. When the light is on, you can double click to get to max output.
The lowest output on my Anduril using SST20s flicker a litlte bit too. None of my Narsil ones flickered.
Anduril doesn’t do it on every model of light; although it seems that at least one version does on this one. It’s not hard to prevent for normal use; just set a ramp floor of 3. I haven’t done that, because the lower floor, even with a flicker, is very low indeed.
From on, click 4 times, it will flash once, then begin fluttering. You want to click the number of levels (1-150 steps, ignore that the video says 250 steps) that you want the floor and then don’t do anything for about 2 seconds. So probably click it 1 (lowest level) to maybe 3 times. This will set the floor or moonlight to 1 of 150, 2 of 150, 3 of 150 etc…
Then it will blick twice and begin fluttering again. Now you can set the ceiling. It starts at the highest 150 and you can click the number of steps LESS you want. If you want the ceiling at step 130 of 150 you will click 20 times. Click once to stay at 150.
After not doing anything for a few seconds it should blink 3 times and begin fluttering again. Now you click the number of “stepped” levels you want, such as 3 or maybe 6, etc… After not doing anything for 2 seconds it leaves the Config mode.
You would think someone that reviews flashlights would at least give a reason for such a statement but alas I am not surprised. Wont be viewing this one either because of the way you present yourself on the forum.
Anduril does by default, at least the latest builds Toykeeper has described, have the ramp ceiling set to a lower level - for the ROT66 builds, I think she said the maximum regulated level, so it will be lower for the 219B version than the others.
I suppose whether that’s desired is personal preference, but fortunately, it’s configurable.
The flickering on minimum mode is most likely a combination of how specific 7135’s and specific emitter copies work together. They have a minimum where they don’t function consistently, which has been known about on BLF for years. Some samples are bound to just have a slightly higher minimum threshold and need the floor set higher.
I haven’t disliked or even clicked it so if you see several I guess that is a heads up that I may not be the only one with this view. I could care less where you are from and would stand up for you in that regard. Some of the best contributors on this forum are from Europe and I absolutely support them. You just come across as very arrogant. I could even look past that (see Tom Tom) if your posts were occasionally well written, educated and informed but they tend not to be so here we are.
I’m glad ROT66 chose the 3A tint. I’ve seen some B & C tint 5000k that has yellow. I would consider 4000k - 5000k NW as long as it is on or below the BBL (A and D tints). If you look at 4000k 219B 9080, E21A, or Cree 5A and 5D tint, there’s no yellow and at night time, when your eyes are adjusted to WW 3000k ceiling fixtures, these tint looks pure white and actually a bit on the cold side.
Newlumen, thanks for those beamshots. Those 6500k CW looks like NW in those pics, very nice. The SST-20 and XP-L HI looks the same. Even the tint on the 4000k Samsung looks almost the same as the other two.
