I haven’t disliked or even clicked it so if you see several I guess that is a heads up that I may not be the only one with this view. I could care less where you are from and would stand up for you in that regard. Some of the best contributors on this forum are from Europe and I absolutely support them. You just come across as very arrogant. I could even look past that (see Tom Tom) if your posts were occasionally well written, educated and informed but they tend not to be so here we are.
I’m glad ROT66 chose the 3A tint. I’ve seen some B & C tint 5000k that has yellow. I would consider 4000k - 5000k NW as long as it is on or below the BBL (A and D tints). If you look at 4000k 219B 9080, E21A, or Cree 5A and 5D tint, there’s no yellow and at night time, when your eyes are adjusted to WW 3000k ceiling fixtures, these tint looks pure white and actually a bit on the cold side.
Newlumen, thanks for those beamshots. Those 6500k CW looks like NW in those pics, very nice. The SST-20 and XP-L HI looks the same. Even the tint on the 4000k Samsung looks almost the same as the other two.
Ideal if you’re a one torch guy, I have 80…
It’s getting a chore to set temp control, bypass the ceiling mode which shouldn’t be default, disable the flashy modes, set the desired moonlight level. It’s getting to the point you accidentally press X number of times trying to do something and you have to re-read a 50,000 word User Manual to undo a cock-up.
Thanks JasonWW it worked. Thanks to everyone else for the helpful info. It ramps up much higher now. When I did 1 click for moon mode, it is a little brighter on the lowest setting and the flickering stopped. What's interesting is that turbo is still not as bright as my first rot66 xpl hi, maybe about 25% less bright. I'll put it down to the emitters themselves and call it a day.
I have about 60 but this is my first Anduril. I think it's a bonus to have so much room to customize the settings as much as one would want to. Not everyone has the same needs for a flashlight.
I’m kinda indirectly saying I love it but I had to reshoot my D4S YouTube video as I realised I was presenting Turbo as 80% power!!! and believe me my vids take some making.
I love a variable ceiling but it needs to be disabled from off and desperately needs to be able to be set easier. You should tap 10 times, the light buzzes, ramp up to set max, the light buzzes ramp down from your choosen max to set min. Leave buzzing on the min setting prompt for 4 secs if you want a 1 level light.
Newlumen (thank you) included a ‘correction key’ for us.
The window in the background, on the other side of the fence, features varied levels of luminosity.
If an attempt is made to balance the levels, we can see more rose/pink/magenta in the lowest CRI emitters (SST-20). In comparison, the 3A pooch pic is more neutral, and the Samsung has a typical hue.
I had not seen it. Thanks, very helpful. And thanks Mitosis for identifying a fix.
Loosened screws, pressed in batts, tightened screws. A simple fix.
I hadn’t seen how low parasitic drain from the Auxillary LEDs takes the battery voltage. Has that been measured, and is it safe since it can’t fit cells with a PCB? Thanks
The default configuration in Anduril sets the ceiling to the highest regulated level, which on most models is level 125 of 150. This can be changed to whatever you want though, and regardless of the value it uses, true turbo is still available by doing a double click while the light is on.
I’ve heard a few people report that, but I’m not sure what exactly causes it. The only time I’ve seen the lowest level flicker was on the first FW3A prototype, and swapping out a 7135 chip fixed it. I haven’t seen any flickering on any of my Fireflies lights though.
Another way around it is to set the lowest level a bit higher. Using level 3/150 should work.
To configure the ramp to go from 3/150 to 150/150…
Turn the light on.
Click 4 times.
Light blinks once, then stutters. Click 3 times during the stutter to set the floor to 3/150.
Light stops, pauses, blinks twice, then stutters. Click 1 time to set the ceiling to 150/150.
Then just wait for it to fall out of ramp config mode.
The stepped ramp also has a third option, to set the number of steps.
It’s 150 levels, not 250. Same as Narsil. This number was chosen because Tom wanted the full ramp to take 2.5 seconds from one end to the other, and the light’s timer runs at 62 fps (0.016 ms per tick), so that works out to about 150 frames or 150 steps.
I’m still trying to find the reason why some units flicker on the lowest level and some don’t. It may be that one of the 7135 chips isn’t quite right, or maybe there’s some electrical noise somewhere causing interference, or maybe things were flashed with the wrong fuse values, or maybe there’s some sort of weird timing interaction between the PWM cycle and the ADC cycle, or … I don’t know. But I haven’t been able to make any of my Fireflies lights flicker like that, so I haven’t been able to test theories.
I have seen some odd behavior on the aux LED board though, during specific parts of the ramp. So I think there may be some sort of feedback going on which is weak enough that it only affects the most sensitive parts at only a few specific levels. But I don’t have an electrical scope to look at the behavior of that in detail.
