They shrink a bit after the first few full compressions so even though they may look big once you realize that it may not be as big of difference as it seems.
Yeah. The small ones do more plastic deformation than the large ones since their wire gauge/diameter ratio is higher, meaning they are stiffer, and require more force to compress to the same height, meaning a higher potential for plastic deformation.
The large ones have no problem with deformation though. I produced them at 13mm since I knew it was going to deform at first compression, and testing them revealed I was right to go from 12mm to 13mm, as the spring lost about 1,0mm.
They did not lose any more height after that, even after 20 full compressions.
TLDR: Big spring is better than small spring in terms of mechanical strength.
Regardless, like hank@ Emisar mentioned in a thread about his the deformation happens once and then it’s pretty well set. It’s fine since both springs were designed knowing it would happen.
When doing bypasses, do you think you’d still get a bit more performance from these springs instead of stock? I just got a light from Dale (DB Custom) in which he replaced the tail PCB with a sheet of copper, put the large springs from this sale on that, then also wire-bypassed the springs!
If you are bypassing the springs anyways I doubt you would notice the difference with using these springs on a pure output basis unless the light is pulling something like 30-40A.
Now these springs are nice and springy and a good size, so in some lights it is worth swapping them out just for that. (the L6 for example, this might allow it to use the shorted 26650 cells without breaking contact if dropped)
Thanks Texas_Ace! :student: :+1:
Oh.
About bump resistance, I can easily say that the Q8 now never turns off with the new dual springs.
No matter how much pressure, or how much “bump force” apply, the light does not turn off momentarily. Which is very nice.
There are also two other advantages to using copper alloys for springs:
1. Bypassing these springs and soldering them is so much easier than regular steel springs because of the lack of chromium oxides.
2. If the bypass fails on a light that use 2S+ battery configs, the spring will still be working quite well and won’t get incredibly hot, and most people won’t notice the difference at all.
Got mine today. They look great. I plan on using the small ones to replace qlite driver springs and the large ones for most tails.
Thank you BlueSwordM for putting these together for us.
Got the springs today. Thanks!
Nice
Got mine as well. Thanks Blue Sword!
Mine also arrived yesterday. Thanks again BS. They were well bondage wrapped.
Mine arrived today
shipped 2018-10-09
postage stamp 2019-10-11
arrived 2018-10-17 in Germany
Envelope was unharmed
My tape wrapped envelope came today, Its spring time.
When will the general orders start receiving PMs about payment and shipping?
Oh yeah. Will be getting some other people.
I have to pick up steam though. Next week will be a doozy, as I will send out PMs and ship out as many orders as possible to get them out because of a rumor at Canada Post.
Inquiring minds want to know, what is the “rumor at Canada Post”??
Basically this:
I’ll start PMing as many people as possible now so I can send shipments tomorrow and Friday in time.
Thanks for the info Blue…. :+1:
I used one of my small springs on one of Lexel’s 2S 8Amp buck drivers. Before I had some ghetto tail switch mods for bump protection plus a brass button on driver side. Was able to remove the brass button and tail switch mods in place of the single small spring on driver side and it works nicely.
