They’re pure garbage. Trust me, I made the mistake of getting 2 of ’em for mum to use with 3×AAAs.
Aluminum-foil battery tube, rattling zoomie-head, scratchy switch (great if you like Random Modes At Random Times), and so many things wrong with it, that they’re all an abomination unto the LORD.
Take the bux you’d spend on some AT01s, and toss quarters down the sewer instead. It’d be more amusing than dealing with those crappy lights.
Oh, they ain’t even Ultrafire, unless UF completely and totally disavowed even giving birth to those lights, ’cause they’re nowhere to be found on the UF site, and UF even lists their own discontinued lights!
I wouldn’t want to be listed as the baby-daddy, either.
I think the wuben A21 which i just received is going to be hard to beat. It’s not 4200 lumens in my opinion. Closer to 3400-3600 in comoarison to known lights.
Rofis makes a XHP35 light called the MR30. I am anxiosly awaiting mine in transit from Banggood now.
That Rofis MR30 does look pretty nice. But it has some oddities to it that I noticed right away with just a quick look just now. There may be others, but here’s a few I noticed. The charging port doubles as a discharge port for using the light as a power bank. But, the port is Micro USB and it comes with a short adapter cord. In spite of taking 21700 and using XHP-35, it only has a max output of 1600lm. A lot of other lights are well past that level right now. Also, in the freeme GB thread, it is mentioned that the light has two step downs when using “Turbo” mode. :person_facepalming:
Yeah, but 1600lm has been done with 3V emitters by some guys here already, with better throw, no donut hole, etc. Who needs a boost driver and a 12V emitter if there’s nothing to gain (nothing desirable anyway)? IMHO, if it’s gonna be a XHP-35 HI, it ought to get a lot better output to make up for the lack of a nice beam profile. :confounded: And it ought to have thermal management rather than a timed double step-down. :person_facepalming:
Well, in a recent review of that Rofis light, it had a bad tint shift. So, there’s that. But, what I meant was to have a tight beam for better throw. The XHP-35 doesn’t have nearly as bad a cross or donut hole like the 50’s and 70’s do. But still can’t focus a reflector too well, or you’d get a dark spot where the bright spot is supposed to be, because it’s still a quad die with no light being generated in the ‘center’. Anyway, I’m not knocking the XHP-35. I’m saying that it isn’t ‘better’ than some of the 3V emitters, unless you push it well past 1600lm output.
I have received two 21700 lights. I don’t do reviews but I will give my unbiased opinion:
Rofis MR30. I am extremely pleased with this light! I compared to my Nitecore EDC23 (HXP35 HD, 1800 lumen). The Rofis is noticeably brighter and has better throw (XHP35 HI). It is far superior in run-time and seems extremely well made. The power bank feature is nice as well though unlikely I will use it much.
Wuben A21. I just received it and it’s going to a pickup favorite! It’s not 4200 lumens in my opinion. Closer to 3400-3600 (maybe stretching it to 3700) in comparison to known lights. I have not measured output nor have I measured amps to the LED to do the math. I can say that I am very impressed with the controls, charging and the UI. Build quality is excellent. I have purchased two Wuben products in the past and although they were well made, they performed mediocre at best. My experience is Wuben runs current to the LED on the lighter side of max for reliability (one can assume). This light does not fall in that category. 3-5,000 lumens from a XHP70.2 is not pushing the LED to it’s max but is not conservative either. It’s a beast for its size and I’m sure you will like it!
Hi guys , new here. I agree on the A21. Wasn’t too sure about it for the money , but I wanted a 21700 . I really like the beam , it’s impressive for its size. Just bought the Rofis 50 . Haven’t gotten it yet , but I have the 70 , and while it’s sorta just average beam, the side light is pretty cool . The power is nice , but I probably won’t really use it too much. Will most likely get the MR30 also cause I seem to have a problem.
I have another I received about a week ago. The Fitorch MR15. Great beam profile with useful spill and good throw. Nice easy to find front dual front switches (new design). It comes with a nice cell and built in charging which is nice for those of us that have not bought a charger that accepts the longer 21700 cells. The 4 light charge/battery indicator is a nice touch. Great light for $36 with a code!
