Sofirn C8F host. 21700 C8F Available
In such a nice host it’s a shame to not have more regulated output options.
20mm like this? FET + 7135 Driver - 20mm - MTN-20DDm
Mtn also has a 22mm board but then you would have to sand it I guess…
contactcr
Yes.
+1
Just a quick check. Does anybody know if it’s safe buying from AE official store at this point or is it likely I will still receive a light with a dodgy FET? Many thanks.
Ask them before ordering just in case.
Perhaps they will just strip the lights of the faulty driver and replace it, or they’ll just sell them as hosts.
Thanks. Just sent Sofirn a message to their AE store. Will update the thread as soon as I hear back from them.
BTW, does anyone know an EU store that stocks a nice/recommended driver plus a board with LEDs that would fit the host? Cheers.
Received a reply from Qidong Yang:
“Yes,the MOSFET problem has been solved already, the stock now has already improved”.
So it looks like it should be safe to order from AE.
Thanks for checking on this. I wonder when it will be “safe” to order from Amazon to ensure getting the corrected version.
I just got some new FETs from MTN today and swapped it out.
New and old.
I gained 2A more at the tail and 350 more lumens @30s. There is a more instant jump to Turbo as well. I left the stock led wires.
Apparently we need to wait a little bit longer for Amazon. I’ve asked on AE and just got the answer:
“The AMZ not yet, because of the new produce batch is still on its transfer way to USA”
Also they advised to check directly with Amazon for the latest updates.
Did anything ever come of the flat tail with no switch? I assume it never saw the light of say but worth mentioning cause the C8F 18650 was like this.
I haven’t heard anything about it. I doubt they will do a flat tail cap for the 21700 version as the UI has that neat feature that let’s you use the tail switch for tactical use.
You can set your brightness then turn the light off at the tail cap (not the side switch). Then you can use the rear mounted forward clicky in a tactical manner. It’s pretty smart.
If you turn the light off with the side switch, the rear switch does nothing except connect main power. The led stays off. I like it. :+1:
So what you are saying is you are going to convince ToyKeeper to write a special C8F firmware to mimic this momentary mode memory deal so we can have the best of both worlds after replacing the driver or building a host? Sounds good thanks for doing that.
No, the stock driver can do this.
I know that. Jason has talked about the idea of replacing his driver so I assume it would be Narsil/Anduril variant and this is the host thread after all. I bought 2 hosts and 0 stock lights hence the nudge from me.
You assume too much friend. :smiley:
I don’t think NarsilM can remember it’s levels when the main power is removed. RampingIOS/D4 UI seems to remember. I have not tried Anduril yet.
I could see this being a handy feature for a light like the L6, S70 or SP70. I don’t know how difficult the coding would be, though. Maybe I will ask ToyKeeper what she thinks. It may or may not be possible.
With my L6 I had Lexel set up Narsil to go to Turbo when main power was applied. Sometimes this comes in handy, sometimes not. It would be great to be able to switch back and forth.
I think there is still some type of bottleneck in the 21700 driver even with a top notch FET. It seems the 18650 driver can have higher output than the 21700 driver when both use the same 21700 high drain battery.
I’m not complaining though. I measure about 3,000 lumen with the stock battery and my lumen numbers are a bit lower than others. So it should easily do over 3,000 lumen with the new driver (I assume it will match my current driver with the FET I installed).
Maybe Sofirn could increase the led wire guage to get even more output.
LH351D 4000K 90CRI at turn on:
2,803 at 14.xx amps (Samsung 25S 18650)
2,881 at ?? amps (rested 30T 21700)
This is using very long 20 gauge leads. Like 6” long or something in case I needed to re-flash or test. Numbers may not be exact since this is approximating shoe box.
@JasonWW, do you think it’s possible Sofirn to have changed the LEDs from XP-L W2s to a lower bin, which is perhaps why the average lumen numbers are about the same or down, even with an upgraded FET?
No, I’m looking at the amp draws. The 18650 driver is capable of pulling higher amps than the 21700 driver.
Yes, but the forward voltage of the XP-L W2s is lower on average than XP-L V6s, so they can be drawing more current than XP-L V6s. Therefore, the 18650 version, if they have W2s, can be quite a bit brighter as they are drawing quite a bit more current.
Heck, look at @contactr’s numbers. 2800 lumens with 4000k 90CRI LH351D with a 21700 stock C8F is very close to your numbers of the stock C8F with 5000k 70CRI XP-L HDs, which is really strange.
