Checkout does not work, I got “Internal Server Error” message in javascript alert box. Works now.
cool :sunglasses:
A bit expensive but they are difficult to find elsewhere so that is fair enough from a seller’s point of view
:+1: Too bad I already made a few big purchases from you already. I’ll wait for my next purchase to get these and woukd be great if you add these to the soldering options along with the 16mm, 20mm, and triple mcpcb. LHopefully you get some new emitters like more 95cri sst-20 with no green tint
Thanks Ban!
Order is placed (10mm boards are a bit expensive so i ordered a few less than initially planned but still happy to have the option to get them now from you!).
Two for $2.98 isn’t bad. I’ve added some to my cart for my next order.
Site seems to be down with (500) Internal server error.
That's what I'm seeing on my end as well.
Hi
I am doing some minor fixing.
Please try to go again.
Thank you
Ban
Hi Ban, sorry to bug you again but did you already have a chance to find something out or even offer for sale? Thank you!
Hi Lux
I am sorry that i forget to post the link.
I will post the link within 1 to 2 days.
Ban
Thank you Ban! :+1:
Hi Lux
I had posted the P60-TRI driver board on KD.
P2500 20mm 3V - 9V 2.8A 1 cell or 2 cells 5-Mode Driver Circuit Board for KDLITKER P6-TRI
P2500 is for parallel configuration
I3N is three led individual channel (3 negative shared). You need to have the LED PCB that is supported.
If you have any question, please feel free to contact me.
Thank you
Ban
I had not seen those separately operable triple P60’s yet, and with full choice for all 3 leds, pretty cool
Yeah, we had launched a new triple P60 drop-in in recent.
KDLITKER P6-TRI Cree XP-E2 Triple Color P60 LED Drop-in
And we get a BLF member to help to review on that.
The dropin was sent to me by Kaidomain for review. Here's the product's link: KDLITKER P6-TRI The product comes in a simple film canister. [image] The dropin is packaged in a resealable plastic bag. [image] The dropin is quite unique. It comes with an all brass construction and a triple TIR optic. The manufacturer allows the user to individually select the installed XP-E emitters (White / Neutral White / Warm White / Red / Green / Blue / Amber / Royal Blue). [image] Overa…
Enjoy
Thank you very much Ban! :-)
Can you please check the picture of this driver?
It says 2.8A max. Is that correct? So with 9V I could use 3x CR123?
Hi Lux
Sorry for careless mistake on the photo.
This driver board is designed for Cree XP-E2 led, the max . current is around 1500mA
I will correct it tonight.
Thank you
Ban
Hi Lux
Picture is updated.
Yes, you can use with 3 x CR123A battery
Thank you
Ban
Hi Ban,
Thank you so much!
If you ever plan to sell this driver with 16-17mm diameter, I would be glad to hear about it. It would be perfect for a Convoy S2+ triple flashlight.
Cheers,
Thomas
Hi
Will you sell this dropin only shell host ?
Hey Ban.
Some time ago I bought a lot of empty p60 pills. I noticed that the surface on which the mcpcb is sitting isn’t flat.
I admit that I feel a bit cheated, because something that should provide better heat dissipation from the diode in reality is not much better than the classic p60 modules.
I need a lot p60 to finish all my flashlights and I paid a lot.
I’m dissapointed.
