Our friend's new store!
$22.83 | Code: GOLDEN
$23.99 | FLASH SALE
$55.08 | Code: GOLDEN
$61.62 | Code: GOLDEN
Hi Freeme,
Is there any chance to get this code for the Nitecore Concept 1 from your webpage alive again? Gearbest offers the Concept 1 but the code from your website does not work.
Cheers, Thomas
[AliExpress - Flash Sale] Sofirn New C8F 21700 Version Powerful LED flashlight Triple Reflector Cree XPL 3500lm Super Bright Torch with 4 Groups Ramping
Price: $30.93 ( usual $41.16 )
Coupon: Store promotion - additional USD$2 OFF (>$25 order).
Store: http://s.click.aliexpress.com/e/KmQ486k
Specification:
- 3* CREE XP-L LED with a lifespan of 50,000 hours
- Working Voltage: 2.8V-4.2V
- Battery Options: One 21700 Li-ion battery or One 18650 Li-ion battery(Suggest 21700 battery)
- Dimension: 149mm (length)*44.6mm (head diameter)
- Weight: 200±2 gram (without battery)
- Flashlight body: Aerospace grade 6061 grade aluminum alloy, CNC manufactured to hard-anodized anti-abrasive finish to get solid built body, anti-crash geometry and better heat exchange.
- Toughened mineral glass lens with AR coating.
- IPX8 Waterproof (submersion up to a maximum depth of 1.5 m underwater for up to 30 minutes).
- Reverse polarity protection from improper battery installation.
- Advanced Temperature Regulation (ATR) technology: ATR will adjust the brightness level automatically when the driver temperature reaches 50℃ (122 °F) to prevent overheating.
- Power Indicator:
- The LED indicator on side switch blinks in green for 5 seconds when turns on.
- LED indicator is Steady Green if the voltage is between 3.4 volt to 4.2 volt.
- LED indicator is flashing Red if the voltage is between 3 volt to 3.4 volt.
- LED indicator is rapid flashing Red if the voltage is between 2.8 volt to 3 volt.
- The flashlight turns off automatically if the voltage is lower than 2.8 volt. Please insert new battery.
TI Pen please
Will find out the updated price for you. [quote=Lux-Perpetua]
Hi Freeme,
Cheers, Thomas
[/quote]
Unfortunately. I was told that they were not allowed for export. I will continue to monitor the situation.
Very quick flash!
It's a 24hrs sale. I will try to get more offer from Sofirn.
20% discount reached.
$22.99 | Code: GBLEDTINISS
$104.27 | Code: BLF
$34.3 | Code: BLF
$185.22 | Code: BLF
$56.96 | Code: BLF
$152.15 | Code: BLF
$33.88 | Code: BLF
Remember to apply store coupon for extra discount.
New ThruNite TC15 XHP35 2300lm LED Flashlight with IMR 18650 Battery included - $49.99 ($59.99)
IMALENT RT35 2350lm Super Bright USB Magnetic Charging LED Flashlight
Price: $94.99 (usual $170.26)
Coupon: GBLED110503
Store Link: https://www.gearbest.com/led-flashlights/pp_009119645975.html?lkid=17055557
Time: 23 days
IMALENT HR70 XHP70.2 3000LM Brightness Magnetic Charging LED Flashlight Hiking Headlamp
Price: $44.99 (usual $89.95)
Coupon: 11.11 EARLYBIRD; 10% deposit required.
Store Link: https://www.gearbest.com/headlights/pp_1848494.html?lkid=17058296
Time: 23 days
Baggood!
good catch, I missed it!
