Fireflies ROT66 Flashlight
Going back to posts from a couple of days ago…… My light had the flickers at the low end of ramping. I fixed it: The contact between the battery cage and the head had a tiny bit of thread grease on it. Used a Kleenex to clean it. Problem has never returned.
I'm still convinced that something is not right with my ceiling. I click 4 times, let it flash once and then it flutters, so I set my floor at 1 then after after about 2 seconds I let it blink and then do nothing so that it can set the ceiling to max brightness, but it's still quite a bit less bright than my first rot66. Is there anyway to go past the ceiling that is set in Anduril? Or, is there a way that I can get NarsilM into this flashlight and see what happens? It could be possible that Anduril is somehow limiting max output when compared to NarsilM..... just a guess.
I have a light colored marble floor in our hallway and it's great to do a ceiling bounce. The Anduril rot66 shines the marble floor quite a bit dimmer off the ceiling bounce compared to my NarsilM light. It's almost as if the wow factor is missing.
If you do nothing for the ceiling it does not change. You need to click once to get the max ceiling.
Clicking once for the floor setting will give you the lowest floor. Clicking once for the highest ceiling level will give you maximum ceiling.
I’m kind of wondering if there might be a cell in backward or something. Or maybe a chip on the driver lets current through while it’s off. It’s hard to say.
Thanks! That’s useful to know!
If you don’t press anything, it won’t change the value. Pressing nothing is how you tell it to leave the values unchanged.
Yes. While the light is on, double-click. This bypasses the ceiling and goes to full power.
If you do that and it’s still not as bright, there’s probably a physical issue like dirty contacts or weak batteries or something, instead of a configuration issue.
I tried cleaning the top of the cage, but no luck. Still gets some flicker. Have to look at it this weekend to hypothesize about that.
I tried that too, but still the same.
Tried on click to set max but still quite a bit dimmer than my other rot66. When I get back home this evening, will do a good cleaning of all the contacts and give it another try.
You can also try swapping the heads on your lights too. Leaving the batteries and everything the same. See if the problem gets transferred
Sooo… I think my ROT66 is possessed.
Came home last night to find it had turned itself on while sitting on a shelf. There’s no way it was on when I left as all other lights in the house were out making it really obvious. Just sitting on a shelf all by itself and turned on with no interaction from anything. The voltage was still 3.7 so it can’t have been on for too long and it was war but not uncomfortably hot so at least thermal management was doing its job.
Has this happened to anyone else? Anybody familiar with the firmware/hardware have an idea how it would be possible?
I’ve never heard of that with any light. Weird.
like to buy a second one, but i think the threads are low quality ,the tube must be a litlle bit thicker ( also better for heat dissipation) to make the threads deeper. Also the ring to put the lanyard i think is very thin (metal on metal) better is a nylon lanyard. And final i like to see a better holster.
Than for shure i buy a other one mmm maybe two :person_facepalming: , for the rest i like so much this light.
Someone can inform me witch throw farther the sst 20 or the XPL hi?
i have the one with aux leds, with NarsilM ( I think bought it in september) mine english is not so good to understand the manual.
I want to chance the moonlight (higher) someone can explane me in simple words to high up the moonlight?
Agreed, but at least that part could be replaced. I think this is the same. Can you confirm?
https://www.amazon.com/CAMVATE-Connecting-Adapter-Fasten-Handle/dp/B01DC0ATFK/
Do you mean the moonlight level that you turn on from the off position?
It should be set to 3 out of 7. This can be changed to a 4, 5, 6 or 7 to make it brighter.
Or do you mean the lowest part of the ramp? This can not be changed in NarsilM.
Try my video about changing the menu settings.
If your in ramping, you go into the menu (this might require 8 seconds or 16 seconds), wait for 2 fast and 2 slow blinks, then click maybe 5 or 6 times. Make sure they are fast clicks and you see the confirmation blink with each button press. Then let it exit the menu on its own.
Thats scary… which state do you live?
Thanks, it works the moonlight is 2 steps higher…. only i dont get the strobe mode anymore….i did something wronge
Thanks, i think so on the FF its way to thin …
