Will that head/bezel fit on my S42S body?
If so, I’m in for sure.
Interested
code and price added to the OP ;)
mails to the people on the list will be sent now
Thanks, ordered
My resolve crumbled, ordered one. Very happy with the plain S43 I received yesterday. With USB charging, might be able to offload to someone.
thanks guys!
I ordered mine. But, why did it say Pre-Order? Then, on the final order confirmation screen, it said it would be shipped Oct 19, which is today.
Danm your codes…! :smiling_imp:
I could have resisted $29. :person_facepalming:
chinooker, I know what you mean.
i made a short review:
and some stills and detail shots:
ASTROLUX S43S preview
the box
whats inside
Astrolux S43S
Astrolux S43S (charger side)
nice lettering
Astrolux S43S
beautiful copper head
notice the "thumb pocket"?
cool fins
charging port closed
charging port open
USB Type B port
sealed flap
flat
not easy to open accidentally
the hot quad - 4x Cree XPG3
TIR lens behind protection glas lens
bezel removed
under the hood
under the hood
nicely cut threads
the optics
glase lens is AR coated
tailcap thread for "attack pin"
lanyard hole
double springs to reduce resistance
short (18350) cell tube
S43S in short configuration
is there 18650 tube for this light?
its delivered with the 18650 tube; the 18350 is optional
Since deciding not to buy anything incorporating micro USB about half year ago I haven’t been that tempted…
My hatred for this connector is only a tad smaller then for mini USB Hopefully S44 will not be as outdated in this matter.
Might snap though…
Martin, Will S41/S42 body lego with S43’s head & tail cap?? Will 106xx Carclo Lens fits S43?
BG says opposite.
1 x Astrolux S43S 4x XP-G3 or Nichia 219C Copper 18350 Flashlight (Without 18650 body tube)
My A6/S41 18650 body is slightly shorter but does lego with S43 n tail cap
WOW - i totally missread that!
you are right...
and i tested the S41 body+tailcap and it worked .
not sure - Astrolux´ lens only has 2 legs
Am I correct in thinking the aluminium S43 has a single spring on both ends? It does about 10A.
This S43S seems to have a button on the driver and double springs on the tail cap. It pulls 15A.
I guess they bumped up the power due to the copper head.
S43 is button head too, dual spring tailcap
Can you please Martin to find out if a tube from Astrolux S1, S41, S42 can be used for Astrolux S43.
He said in post #26 that S41 does work:
