ENEDED
Interested thanks :+1:
Interested
Interested.
Will there be two different battery tubes, one for 2x 26350 and one of 2x 26650? If so, will the SC04 come with both tubes like the SC26? Even haikelite.top would not reveal any information about that.
I’ve been wondering the same thing and said so in the other thread.
It's a bit early now. I am sure they will disclose more details when things are firm.
Sign me up please! :smiley:
Interested!! IN
Send us your address and contact, and I will send you a sample for free.
mee too …? :smiley: if you are in contact with Dale send him best wishes, my “late” MT09R’s GnB are my secret treasures and still work fine
The emitters can produce that much light - only just in high-CRI, but they can. The ROT66 is direct-drive and limited by the emitters’ forward voltage. The SC04 uses a buck driver and a battery configuration that’s always well over the forward voltage, so it can drive the emitters much harder in theory.
I also tend to assume listed output from Haikelite is a wish rather than a spec until a third-party test shows otherwise.
Uhmmm… wut? Are you serious?
(… And why is my name green on the list… :smiley: )
Yup, it is just a small perk for HKL fans and as contributor.
I´m interested too
interested
Interested
Interested only, if SST20-WxH (95 CRI) is used, but if so, then definitely interested!
interested
Why not put just a single SST-40 in a large head? I want a thrower with one of the smaller emitters (XPG3, etc)
BTW guys, this light will also support 21700 cells.
