My second Q8 just arrived. This one has some minor imperfections in its anodization (e.g. cooling fin has obviously touched something hard) and threads must have been greased with something “sandy” as it sounds terrifying when unscrewing the head from the tube. I guess I need to clean those threads and relubricate them with nyogel. So, certainly it will not end as a shelf queen. Apart from that it’s a great flashlight and works properly so far.
What has also come to my attention is something strange to me. Maybe some of you guys can doublecheck with your Q8s if this is absolutely normal and the same with every Q8. When I look into the reflector from a centered position I see that the outer rim or this “black gap” between reflector and bezel ring is differently wide, see picture below. I’m not sure if this can be fixed or if it need to be fixed at all as I did not see any influence on the light beam so far. Both my Q8s look very much the same i.a.w. this gap. Unfortunately, I did not manage to take a real good picture to show the effect but I hope it still indicates what I meant to say.
Try breaking the bezel loose enough, but don’t remove. Then remove the (2) screws the hold the driver to the head, remove the driver, the wires are long enough to access the back of the driver so it shouldn’t be a problem. to drop the driver a bit. Look inside the head. There are (3) screws the hold the reflector to the mcpcb to the head, loosen them, don’t remove them. Now tighten the bezel, it should center the reflector, then go back and tighten the (3) screws gently, evenly, in stages, reassemble the driver. I have had mine apart several times, it works for me… good luck.
Anybody have a picture of the driver in the Sofirn Q8 specifically the MOSFET? Or know the number on the Q8 FET? I modded Q8 and also changed the stock mosfet to a Infineon FET, never paying attention what the stock FET was. But I have a used one laying here and I don’t know if it was from the Q8 or the C8F 21700. Wondering if Sofirn used the same FET in both lights?
My first reaction is they have to be different since the Sofirn Q8 performs exactly as it should. Here are my two lights. They are similar, but not the same.
I looked at Sofirns store where they sell the driver and it clearly shows 2 different FETs in the pictures, but I can’t read the writing on them.
Not keen on soldering a set of high quality springs into my brand new Sofirn Q8, I decided to try an old fashioned spring bypass. Not from the top of the springs to the tailcap switch (which does not exist). Instead I put in four 20 AWG leads from the top of the springs to where the base plate is screwed onto the body. Four leads may seem a bit crowded but there is a lot of space between the springs. The eyes at the end go around the screws between base plate and body. This increased output from about 90 kCd to 92.8 kCd (30sec).
To compensate for the fact that the eyes on the leads add an extra mm distance between baseplate and body, I swopped the standard Ø2.5*4mm screws with longer ones from my spare parts can.
For obvious reasons (visibility) the picture above shows only one bypass.
Jason, “2D030L” is the pertinent labeling, the other is manufacturing codes… to the best of my knowledge. Insomuch as these 2 you show are indeed the same MOSFET.
Oh yeah, I forgot to mention those screw sizes were for the original Thorfire Q8. But they should be the same for the Sofirn Q8. I added an edit to the post above to reflect this.
I wrote ‘standard Ø2.5*4mm screws’ which means that the lenght of the thread is 4mm. A bit short IMHO. But then again: I come from the world of powerplants. Everything under M6 is focussing on not shearing off bolts.
Don’t worry, the inner threads in the body stretch far enough for a few extra mm.
I really like this Sofirn Q8. Nice pure white beam, no ugly tint shift. Shot taken with my Galaxy S9 camera. Pitch black outside, no street lights, no moon.
If I remember well, he is using an ULcp AR lens, which is more efficient that the stock one, along with BeCu springs bypassed, and a pure copper plate holding the springs in place.
I think he also replaced the FET with a slightly lower resistance one(not too sure though), and swapped the 18AWG power wires for 16AWG.
I looked through all his posts in the modding thread. The lens and copper spring disc didn’t do much. The spring bypass was about 1200. Brass screws about 300. These got it up to about 7000. I didn’t see a number broken out for the mcpcb wires.
The other mods he’s mentioned were XP-L2 emitters on Sinkpads and A20DP FET. That’s the parts, and there’s also the mods to the head.
