I had a similar experience a while ago with my first firmware for momentary switches. The light sometimes turned on when my hand came close. I suspected spikes caused by static electricity which triggered the interrupt on the port where the switch is connected to. So I added debouncing code after wakeup which actually cured this problem:
NarsilM has some de-bouncing. Instead of using the pin change interrupt, it polls the switch on each WDT tick. This avoids most of the noise. Then it requires a steady state for at least N ticks before considering the button state changed. However, it looks like the duration is only 1 tick for button press (activates on first cycle), and 4 ticks for button release, using only one measurement per tick… so it could possibly trigger if the timing lined up exactly wrong.
Anduril has a different style of de-bouncing, because two of its hardware targets have very noisy switches — FW3A and lightsabers. The lightsaber switches in particular bounce for a really long time. At first it used the pin change interrupt, but that proved too noisy even with pretty strong debouncing, so now it polls via WDT. But when it polls, it waits for 32 consecutive identical values measured about 0.063 ms apart (stable for 2 ms). This seems to work pretty well even on the noisiest switches I’ve tried.
My dad was a mechanic and our neighbor bought an early VW, which he bragged about its good mileage incessantly.
My dad snuck out every other night for a few weeks and would pour some gas into the lil uberbug. (gas was way cheaper then)
Well, the guy was gushing ’n raving at his phenomenal mileage.
Actually, i’m pretty happy with the thermals of my 219b version. Depending on the ambient temperature, I can get a bit above or below the max 7135 level without being uncomfortable to hold. That’s a pretty usable level; i think i’ll be using it a lot at that level.
TK gave me a good idea that actually hadn’t occured to me. I set the stepped ramp to have two modes, one at 65 and one at 115, so that I can quickly set it to exactly 1x7135 or max 7135, and then turn it back to regular ramping mode after. (It does go to 1x7135 when you unscrew and rescrew the batteries, but this is faster.)
This was around 40 years ago though when mileage in a truck was nothing near 20 mpg in the first place. Plus… the guy I’m speaking of was basically just an obnoxious braggart…. about pretty much anything he owned. His was always better than yours kind of guy. :person_facepalming:
He was not the sharpest pencil in the box either, somewhat gullible too.
Oddly… he was a bit more ‘humble’ after this though.
He was never told about it either.
IIRC we got him up to about 41 mpg and down to about 3 mpg over the course of many weeks. The dealership thought he was a nut case…. cause he told the story to them.
Oh yeah… he even got a locking gas cap during this time. It didn’t bother us at all. One of our close friends was locksmith…. we just had him come over one night & make us a key to the gas cap.
Reset the maximum ceiling by pressing once and just cleaned all the contacts inside and on top of the carrier as well as the spring inside the head, but no difference. Then I swapped the carrier and batteries from my brighter rot66 but that didn't do anything either. I just emailed Jack, maybe he has an idea what is going on. Somehow I'm convinced there is a fix for this.
Interestingly enough, I went for a walk in the park tonight to show off my mateminco mt70 plus to my wife and of course if failed to turn on! Confused for a little while and then decided to clean all contact points inside and outside of the carrier as well as the head spring and it fired up. Amazing that an almost invisible amount of grease can shut the light down. I understand that it should be weaker but the light wouldn't even turn on and the breathing switch was dead until I cleaned everything up.
Try this, remove the tail cap and carrier, make sure the battery tube is screwed in all the way in. Then install the carrier and tail cap.
If the battery tube is not screwed all the way in, the tail cap threads might bottom out and and not push the carrier against the head with sufficient force. You might be borderline with the carrier just barely touching and a little grease might be causing a big problem.
I’m not sure what is going on with the ROT66. Are both lights using the xpl-hi?
Ok, that didn't work, but you just gave me an idea, thanks!!!! I reversed the battery tube and tightened it all up and it's just as bright as the first one I've noticed throughout the threads that you never seem to give up on ideas, thanks man, really appreciate the help.
Interesting, I wonder if the battery tube threads on the ROT66 are cut slightly deeper on one end?
There is another fix people have used on the big Mateminco lights which is make a thin spacer to put between the carrier and tail cap. Some early model MF01 had slightly too long battery tubes, or too short carrier, so even with the battery tube and tail cap fully tightened the carrier did not touch. A spacer in the tail cap pushes the carrier forward. Try that on the MT70.
Maybe these ROT66 have a similar issue where the threads are cut differently, etc… and it prevents the carrier from pushing hard against the head.
Will measure in the morning as there must be a slight difference in thread length. Not really sure why it would make a difference though as the battery tube would still be the same length? Anyway, it worked and bright as the sun now.
Would you know if the inside of the tail cap is used as a ground to the carrier on the MT70 Plus? It's anodized on the inside, so I'm guessing it can't be and I could use a plastic spacer maybe to try it out.
There’s no power going through the battery tube or tail cap on any of the Astrolux MF lights (MF01, 2, 4, 4S) which includes the Mateminco versions. They all use the same 6v carrier as well.
Both positive and negative go straight from the carrier to the head of the flashlight.
Thanks for your input. This isn’t the sort of light that I would use for camping or other important roles so I’m not overly concerned about its reliability, but I’ll definitely be keeping an eye on it and not leaving batteries in it long term.
Using an aluminum spacer may create a new path for the negative to flow through the battery tube and tail cap. That should be okay, but you might not be able to lock out the light. I would recommend using either a paper or plastic spacer.
You should be able to manually lock it out by twisting the battery tube or tail cap. I do this with all my e-switch lights. There’s no chance of it accidentally turning on as well as no power drain at all.
