I’ve been wondering the same thing and said so in the other thread.
It's a bit early now. I am sure they will disclose more details when things are firm.
Sign me up please!
Interested!! IN
Send us your address and contact, and I will send you a sample for free.
mee too …? if you are in contact with Dale send him best wishes, my “late” MT09R’s GnB are my secret treasures and still work fine
I highly doubt this can make anywhere close to 5000 lumens with only 4 SST-20. Even the ROT66 9x SST20 95CRI only makes 5000 lumens and the 9x SST20 66CRI makes 7000 lumens.
The emitters can produce that much light - only just in high-CRI, but they can. The ROT66 is direct-drive and limited by the emitters’ forward voltage. The SC04 uses a buck driver and a battery configuration that’s always well over the forward voltage, so it can drive the emitters much harder in theory.
I also tend to assume listed output from Haikelite is a wish rather than a spec until a third-party test shows otherwise.
hIKARInoob:Sign me up please!
Uhmmm… wut? Are you serious?
(… And why is my name green on the list… )
Yup, it is just a small perk for HKL fans and as contributor.
Uhmmm… wut? Are you serious? (… And why is my name green on the list… )
I´m interested too
interested
Interested
Interested only, if SST20-WxH (95 CRI) is used, but if so, then definitely interested!
interested
Why not put just a single SST-40 in a large head? I want a thrower with one of the smaller emitters (XPG3, etc)
BTW guys, this light will also support 21700 cells.
There will also be a high CRI version available for anyone wanting to know.
I’m interested. Thanks.
Interested
Thanks for the additional info BlueSword.
Add me to the list now.
