Test/review of LiitoKala INR26650-50A 5000mAh (Black)
Due to the popularity of the LiitoKala 26650 cells it may be possible that some AliExpress sellers are selling sub-par products: PLB factory rejects or even cells from another manufacturer. There is people reporting cells with different weight and capacity, even the top looks slightly different. Beware.
AliExpress does not have proper customer protection policies, at least not against li-ion cell fraud. It can be risky buying this stuff from there.
Look:
Good (blue) and bad (black). In HKJ's reviews (blue, black) measured cell weight was 95.3 and 95.7g, 0.4g more for the latter because of the sticker.
LiitoKala either went downhill or was bad to start with in this respect, or is being faked by AliExpress sellers. They've used/use the bait and switch tactic.
As an example, take a moment and see the actual cell prices other retailers ask for LiitoKala cells: FastTech and GearBest. The difference is huge.
volchyonok, my advice for you is to buy the Lii-40A cell, based on Lishen LR21700SA cells. Or get these cheap BAK 18650 rewraps. They're more than adequate for an e-bike, no problem with power output because your cell pack is big. Just be cautious and do your figures for up to 35W/cell with the Lii-40A/LR21700SA cells, and maybe ≈25W/cell for the EAIEP BAK 18650 rewraps. Better safe than sorry. Fraud with li-ion cell sales seems to be mostly focused on high discharge cells, thus one problem less for you.
If, for example, you aim to feed a 48V electric motor, plese bear in mind the actual voltage output from the battery reduces with load because of cell internal resistances. So, instead of 13S I would go 14 or 15S, depending on battery width too (number of cells in parallel).
For example, 90 pieces Lii-40A cells can be configured 15S6P, a pack which can deliver up to 3150W average guaranteed, thus going nicely strong for 1000 - 2000W of 48V electric motors and related electronics. Or 120 pieces of the aforementioned BAK 18650 cells in 15S8P.
The battery pack peak power output cannot harm the motors or electronics, they just make use of what they require. However, if your cell pack cannot deliver enough power output problems can arise.
Cheers :-)
I was under the impression that the Liitokala black cells had been superseded or replaced by the new 5100mah blue cells. Same for the older 5000mah blue ones. It looks like the old blues ones are still being sold by Fastech. Maybe old stock?
Also, ten months ago when I ordered my black Liitokala, from the same store we mentioned earlier, it seemed to ship from Egypt to the US instead of China and it took about 5 weeks. Maybe it went from China to Egypt then to US? Kind of strange.
I just bought some Aspire 4300mah a few days ago. I may also try the Shockli 5500mah. I may not buy any more Liitokala until we get some more tests or verify they are not cheap fakes. Just my opinion.
Superseded? :-D
These 5100mAh cells with a big sticker above the wrap God knows where they come from. Under “Products -> LiitoKala Battery” on their chinese web site that thing is nowhere to be found, so probably some sort of fake and/or bait and switch stuff from immoral AliExpress sellers.
Probably the cells are decent, but there are already many reports of sub 5000mAh capacity and inconsistent quality on cells which were tested above 5000mAh at 1C discharge (per Power Long Battery OEM specifications) by HKJ.
Give me those old style PLB wrapped cells with transparent LiitoKala tag any day.
Cheers :-)
Lots of people measured this new blue 5100mah and got capacity readings of over 5000mah to maybe 5200mah. So who knows. ???
I guess I need to buy a scale so I can measure any new batteries. Lol
volchyonok, you can cancel an AliExpress order for at least until the seller has your shipment ready. If not sure, cancel such order. You can ask the seller your concerns, and it may serve you for a dispute later if the product is not right.
Cheers ^:)
That don’t sound good…… :frowning:
LoL fellows, sellers sell what the consumer demands! :-D
Don't be unnecessarily judgemental my dears, if there is happy people buying UltraFake UFK18650-99FK cells let them live their happiness. They may believe ignorance is happiness or sort of, which of course is bad. :facepalm:
If you wanna be certain that your cells are genuine you can also look here volchyonok: https://eu.nkon.nl
There are some first brand 18650 cells with nice price to energy density and discharge/power output ratios: LG INR18650-M26, Panasonic NCR18650PF or even the Samsung INR18650-29E.
Cheers :-)
Do you seriously believe that elements with a maximum current output of 8A or even 10A can be useful to me for such a heavy consumer as electric transport? The best out of 18650 is the Panasonic PF-2900, but they need too many pieces (in the “P”) for the 14S battery, otherwise they will soon feel something like this -
Lots of high capacity/low drain 18650’s works fine for Telsa. Even using their Ludicrous mode. So why not a bicycle?
Now they insisted on another and persuaded all reputable manufacturers to release the new standard 20700 and 21700. Ask them why it was necessary to reject the “best” 18650, especially today when there is a large selection of updated versions of this old form factor?
If I make a lot of “P”, then the battery will be even harder, and there is no room for so many 18650. In addition, 18650 does not like charging currents more than 300-500mA, so the charging process will be too long. I have already received my device with a charge current of 2A. Some people in the reviews said that this device actually has 2.4-2,5A. Such output currents will very quickly kill 18650. Even for 26650, it is desirable to use a charge of no more than 1A. For conventional (low-current) 26650, even a charging current of 750mA is generally better. And now I have 2A, so there’s not even a talk about any 18650.
No, nothing was rude at all. No apology is necessary. :slight_smile:
I was agreeing with you that the seller who sells those 18650 batteries does not sound like a good one.
We all know that capacity 18650 battery does not exist. They are fakes.
I hope you have sucess finding the battery you need… Real ones and not fakes. :slight_smile:
0K, let me get this straight and sorry if it may sound rude.
First of all, what is the e-bike target power requirement and what is the allowable maximum battery weight?
An e-bike is not a @#$%ing drill or any other power tool in which top power output cells may be required due to battery size constraints!
If I am to build an e-bike, I select a battery big enough to provide me with at the very least adequate runtime even if not charging the battery to max.
Let's say I need to power a 1000W e-motor plus management electronics. 3x 40-packs of these inexpensive cells do it with ease. 120 cells of that class means 1200+Wh of energy in 6Kg of battery weight. Even if we are to consider their discharge rate to just 8A/25W per cell (according to personal tests of received fake cells which totally look and capacity perform like these my measured average internal resistance out of 4 samples was 35.4mΩ, this is good for at least 10 to 12A given their capacity), 120 cells at 25W each cell is 3000W, and this is a conservative figure. You could power two 1000W e-motors with such a pack a still have plenty of surplus.
And with regards to available energy, ≈10Wh/cell × 120 cells = 1200Wh, this allows the e-bike to cruise at 1000W for more than an hour. This is great runtime given pack size and cost. And by the way, at 1KW you'll be cruising fast.
The Golisi 4300mAh cells are expensive and less energy dense. What's the point? Let that stuff there for vapers.
I can say this louder but maybe not clearer. Now please go spend your money in what you think/believe is best for you and know yourself. Good luck.
Cheers :-)
What they choose today is irrelevant. It could be political or financial reasons.
The fact is that the older style battery packs work well.
If you want to buy batteries based on the charger you have then that is a different situation. Why did you not lead with this info. High drain cells are the way to go.
There is no need to shout loudly, because I agree with you in many respects. Naturally, 4300x3 = 12 (Ah) and this is really a bit. According to measurements from Mooch, the total capacity may be even less, about 11Ah. Also, the elements of Golisi, even though they are among the most high-current, the recommended charge current is less than 2A (2A is the maximum allowable current for Golisi). However, although despite all my explanations above, even if this choice looks strange, the most important thing is different now. That is, the elements I ordered and paid for by the Golisi S43 26650 turned out to be authentic and not too old (expired).
2A charging current will not kill a good 18650 cell, even if average drain! They're specced to be drained safely and without much stress a ≈7+A/2½C and you think 2A is too much charging current? @#$% @ #@%$& @% &@#@%$! :facepalm:
Not because a manufacturer tells you this or advices you that those things are the only way or absolute truth in any way! They have their own interests and customer satisfaction is maybe just as prioritary as the amount of money customers make 'em earn without posing too much trouble.
Get a bigger battery at the right price per piece.
I'm done with this.
Cheers ^:)
Originally posted on Sun, 10/21/2018 - 10:54. Tiny fix.
Really? Only about 0.5C? Seems quite odd. I can not find any datasheet for the S43. I assumed it would be at least 1C.
In thinking about charge speed, you could also do the same as Tesla and drill battery packs, Etc and only charge the batteries up to about 4 volts. Just stick to the faster CC constant current type charge cycle. Avoid that time consuming constant voltage cycle that also adds extra stress to the battery. You will get much faster charging and extended battery life.
Do not just think, but I know it. High charging currents have come up with for those who have little time, but a lot of money. In addition, changing batteries to others requires not only new costs, but also a lot of time for rework. The situation becomes more complicated even when the battery is not factory-made, but self-made.
For the sake of interest, you can ask questions to manufacturers Shockli, Golisi and many others (if they answer you at all). Ask them why 18650 is not afraid of charging currents 2A (in your opinion), and at the same time for their 26650 they recommend currents in the area of ​​1A? In general, the Shockli 5500 is written about 0.5A …
It’s seems very hard to get any data sheet for these small company, rewrapped batteries. I would charge the Shockli 5500 and Aspire 4300 at 3A. I don’t care. Lol
You must be a very kind person, so you don’t feel sorry for the power from the network for these foreign batteries. But then, may I ask, why not 5A or not 10A, because it would be so much faster?
I have a Miboxer C4-12 charger. It only does 4 x 3A. I’ve had no issues with my blue and black Liitokala cells at 3A.
