I received my Sofirn Q8 from the GB
With a KD AR Lens my sphere shows a 330lm gain in turbo.
Measured at 5500lm and 680m with the AR Lens.
Not keen on soldering a set of high quality springs into my brand new Sofirn Q8, I decided to try an old fashioned spring bypass. Not from the top of the springs to the tailcap switch (which does not exist). Instead I put in four 20 AWG leads from the top of the springs to where the base plate is screwed onto the body. Four leads may seem a bit crowded but there is a lot of space between the springs. The eyes at the end go around the screws between base plate and body. This increased output from about 90 kCd to 92.8 kCd (30sec).
To compensate for the fact that the eyes on the leads add an extra mm distance between baseplate and body, I swopped the standard Ø2.5*4mm screws with longer ones from my spare parts can.
For obvious reasons (visibility) the picture above shows only one bypass.
Jason, “2D030L” is the pertinent labeling, the other is manufacturing codes… to the best of my knowledge. Insomuch as these 2 you show are indeed the same MOSFET.
Can someone confirm the size screws for the tail cap please
I read somewhere that they’re M2.5 x 5mm but Henk4U is saying 4mm??
This is the info I had in my notes……
Here’s all the screws below:
Q8 V2 Screw sizes
Q8 V1 Same Except
Edit: The above info is for the original Thorfire Q8.
Thank you, I’ve ordered the correct ones then.
Just finished bypassing the springs and now getting 5030 at 30 sec with 30Q’s … 300 lumen increase, not bad.
I was expecting more but I guess that’s the downside to XPL HI’s compared to the BLF Q8
My pleasure. Good increase too. :+1:
Oh yeah, I forgot to mention those screw sizes were for the original Thorfire Q8. But they should be the same for the Sofirn Q8. I added an edit to the post above to reflect this.
I wrote ‘standard Ø2.5*4mm screws’ which means that the lenght of the thread is 4mm. A bit short IMHO. But then again: I come from the world of powerplants. Everything under M6 is focussing on not shearing off bolts.
Don’t worry, the inner threads in the body stretch far enough for a few extra mm.
Just in case anyone is interested in results using Sofirn unprotected cells, NCR18650GA’s, and 30Q’s
Stock Q8
Sofirn cells - (4730) - on / (4440) 30 - sec
GA’s - (4820) - on / (4460) 30 - sec
30Q’s - (5020) - on / (4720) 30 - sec
Bypassed Q8
Sofirn cells - (4960) - on / (4620) 30 - sec
GA’s - not yet measured
30Q’s - (5440) - on / (5030) 30 - sec
I really like this Sofirn Q8. Nice pure white beam, no ugly tint shift. Shot taken with my Galaxy S9 camera. Pitch black outside, no street lights, no moon.
@ Funtastic… Thanks for the info, good results! :+1:
@ RobertB…. Great shot, I too love that beautiful white beam the Sofirn Q8 produces. Very nice indeed!! . :+1: . :+1:
When for a warmer version?
My “guess” is Sofirn will not offer a warmer version. The original Thorfire Q8 has that covered.
Is there anything else you’re doing to get such amazing output?
If I remember well, he is using an ULcp AR lens, which is more efficient that the stock one, along with BeCu springs bypassed, and a pure copper plate holding the springs in place.
I think he also replaced the FET with a slightly lower resistance one(not too sure though), and swapped the 18AWG power wires for 16AWG.
I looked through all his posts in the modding thread. The lens and copper spring disc didn’t do much. The spring bypass was about 1200. Brass screws about 300. These got it up to about 7000. I didn’t see a number broken out for the mcpcb wires.
The other mods he’s mentioned were XP-L2 emitters on Sinkpads and A20DP FET. That’s the parts, and there’s also the mods to the head.
Ah! The lens did actually boost the output by a nice margin. He actually gained about +/- 500 lumens from it in an XP-L2 build:
Thanks. Here’s the direct link to that comment.
Just contacted Sofirn through PM and bought another Q8 with a discount code. Code was for Amazon (US) and it was a few cents less than the group buy price.
Sofirn is actively promoting this version. You would do well to contact them directly.
