Not keen on soldering a set of high quality springs into my brand new Sofirn Q8, I decided to try an old fashioned spring bypass. Not from the top of the springs to the tailcap switch (which does not exist). Instead I put in four 20 AWG leads from the top of the springs to where the base plate is screwed onto the body. Four leads may seem a bit crowded but there is a lot of space between the springs. The eyes at the end go around the screws between base plate and body. This increased output from about 90 kCd to 92.8 kCd (30sec).
To compensate for the fact that the eyes on the leads add an extra mm distance between baseplate and body, I swopped the standard Ø2.5*4mm screws with longer ones from my spare parts can.
For obvious reasons (visibility) the picture above shows only one bypass.
Jason, “2D030L” is the pertinent labeling, the other is manufacturing codes… to the best of my knowledge. Insomuch as these 2 you show are indeed the same MOSFET.
Oh yeah, I forgot to mention those screw sizes were for the original Thorfire Q8. But they should be the same for the Sofirn Q8. I added an edit to the post above to reflect this.
I wrote ‘standard Ø2.5*4mm screws’ which means that the lenght of the thread is 4mm. A bit short IMHO. But then again: I come from the world of powerplants. Everything under M6 is focussing on not shearing off bolts.
Don’t worry, the inner threads in the body stretch far enough for a few extra mm.
I really like this Sofirn Q8. Nice pure white beam, no ugly tint shift. Shot taken with my Galaxy S9 camera. Pitch black outside, no street lights, no moon.
If I remember well, he is using an ULcp AR lens, which is more efficient that the stock one, along with BeCu springs bypassed, and a pure copper plate holding the springs in place.
I think he also replaced the FET with a slightly lower resistance one(not too sure though), and swapped the 18AWG power wires for 16AWG.
I looked through all his posts in the modding thread. The lens and copper spring disc didn’t do much. The spring bypass was about 1200. Brass screws about 300. These got it up to about 7000. I didn’t see a number broken out for the mcpcb wires.
The other mods he’s mentioned were XP-L2 emitters on Sinkpads and A20DP FET. That’s the parts, and there’s also the mods to the head.
Just contacted Sofirn through PM and bought another Q8 with a discount code. Code was for Amazon (US) and it was a few cents less than the group buy price.
