Do not just think, but I know it. High charging currents have come up with for those who have little time, but a lot of money. In addition, changing batteries to others requires not only new costs, but also a lot of time for rework. The situation becomes more complicated even when the battery is not factory-made, but self-made.
For the sake of interest, you can ask questions to manufacturers Shockli, Golisi and many others (if they answer you at all). Ask them why 18650 is not afraid of charging currents 2A (in your opinion), and at the same time for their 26650 they recommend currents in the area of 1A? In general, the Shockli 5500 is written about 0.5A …
It’s seems very hard to get any data sheet for these small company, rewrapped batteries. I would charge the Shockli 5500 and Aspire 4300 at 3A. I don’t care. Lol
You must be a very kind person, so you don’t feel sorry for the power from the network for these foreign batteries. But then, may I ask, why not 5A or not 10A, because it would be so much faster?
Probably not C8-12, but C4-12? If it is a 4-slot device, then it has the ability to change the charging currents in this way:
for nickel: 0.1А / 0.2А / 0.3А / 0.4А / 0.5А / 0.6А / 0.7А / 0.8А / 0.9А / 1.0А and AUTO
for lithium: 0.1А / 0.2А / 0.3А / 0.5А / 0.8А / 1.0А / 1.5А / 2.0А / 2.5А / 3.0А and AUTO
So, most likely, you simply use the “auto” mode or the device after each new connection to the outlet always does it on its own, but you do not switch to manual mode to independently select charging currents.
I manually set each cell to 3A. Sometimes it may go to 2.1A or 2.4A, etc… so I confirm 3A or else set it manually. I have no idea why you would assume I dont.
Edit: Oh, I see. You thought I was saying that charger only had one charge rate. My point was it only goes up to 3A.
My normal powerful discharge device is my modded Convoy L6 which drives a pair of them to 17A on turbo. I use it nightly at work.
FWIW my Black and Gold Lii-50A have been fine. All of them check test slightly over 5000mAh.
I never charge at more than 2A. None of my 26650 lights are especially demanding. (Convoy L6, Convoy BD06, Emisar D4S with 219c) The Emisar firmware limits turbo to 80%. I’ve run the D4s to thermal step-down several times and haven’t noticed any problems with the battery. The L6 draws 5A on high. The BD06 (7135 * 8) is only 2.8A on high.
Recent check of my last unused Black and Gold. It was sitting for about 10 months before the capacity test.
That is the official Power Long Battery page for the cell Shockli is rewrapping, and it says the following:
Charge current. Standard 0.5C (≈2.75A for a 5500mAh cell), max 1C (≈5.5A for a 5500mAh cell)
These recommendations you hear of maybe are just recommendations for Joe/Jane Sixpack (uneducated people who know no better). Shockli and his advices can suck my… bird.
Are you talking about “Chinese amps” - 17A or about familiar amps for all other countries? (I wonder how many parallel drivers in your lantern is 7135?)
This is already in the past, but earlier it was possible to find a small Chinese hand-held radio tape recorder, which was written about the power of its 1000W-2500W speakers … (lol)
And it is very good that you do not know :innocent:
Actually, these are not recommendations of the manufacturer and, moreover, in no way a guide for careful use with a long resource. This is just a guarantee that with such operation its batteries will not explode. Understand, if you took the place of PLB or some other manufacturer who needs sales, then you yourself would have written on your batteries and not such a nonsense. Moreover, the higher currents you give to your batteries, the faster you will come to the store to buy again - the main thing is sales and the money received, which allow you to survive and feed your children.
By the way, Shockli told you that his “5500” is from PLB or is it all just someone guesses on the forum?
Before choosing elements for a future battery, I dreamed of taking the batteries from Shockli (black version 5500). When the scenario “14S-3P” is 42 pieces, that is, it could be decent money. However, something went wrong and, unfortunately, it was just before my order that Shockli removed the discounts on this black model and on the black 21700, and when I asked to make an exception, then the seller from his store (woman) sent me to the choice of green “5250”, which I consider a real failure, and not the progress of Shockli. Interestingly, after my choice of batteries from another seller, Shockli returned the previous discounts on the model “5500”, so, apparently, It was not my fate to buy batteries from Shockli “and get a higher capacity (approximately 16.5Ah instead of 12Ah or even 11Ah with Golisi)
Nobody asked you about 18650 to listen to any advice on them. I do not need these 18650s, and I have already told you all this many times (I even showed a graphic picture), so it was your own decision to waste your time in vain.
Indeed, there are too many other things in life to spend on studying batteries. However, I asked where you got the information that the Shockli-5500 are items from PLB? Why, for example, is it not a PAC?
I suspect that if it was possible to communicate to ali-express as on a forum (write more than 1-2 times reviews), the list of exploded elements continued to grow. In this case, most likely, this is due to its IMAX charger, whose form of charging currents is very wrong. These elements of LiitoKala-5000 turned out to be especially sensitive to this. I personally never liked IMAX, especially because it causes a significant increase in the temperature of the batteries during charging (their chemistry just boils inside). In addition, this customer chose a charging current of 0.5C (with such current forms as IMAX - 2.5A - this is very much). The shape of the IMAX current is more like a stabilized power supply, rather than a pulse current of a normal charger.
However, it is not only in this example. Look carefully at other reviews, where some people who understand this will soon write about the utter unreliability of these LiitoKala-5000 (and many other versions of it too). That is, for some time they work quite normally, and then suddenly quickly lose their characteristics.
There’s no way to “communicate” on aliexpress. They always call you to vote for an article you’ve bought or to write a “review”, but if you’re writing straightforward and something you’ve bought is a POS (I really mean the article, not shipping or something else), the article you’ve wrote never is published or the article-number is deleted, but the article from this seller is published under a new article-number so that no one’s able to read your review.
The whole aliexpress voting- and review-system is buyer-scam.
I understand your frustration, but let me point out some advices:
You do not have to give feedback for a just received article. Close the give feedback page which automatically opens when you confirm receipt. You have a one month window to submit feedback.
Oh. In this case it was a wall charger. I’ve bought two of them, on usage they went so hot just near to firing up. So yes I was able to give a feedback next day or so. The charger called “Xenain” is in fact a dangerous peace of shit.
After that I’ve sent one of them to HKJ for testing and tear down. Maybe he’s writing a test once in a time.
So see this as a warning from Xenain 4-port wall charger Ke-Ke-QC-04.
