Even I don't like the captchas, I like the way you handled this spam issue: It will make our community even better!
Edit: This message didn't require captcha. Is it only once / session? Or even better: Once / user?
Thank you Mr. Admin!
Each member should receive a free calculator.
:bigsmile:
Whoo hoo! It is a never ending battle, but it sounds like we have a good approach in place.
Cool. Thanks for your work. :)
I suppose those text-based captchas should work for those with visual impairments as well, so that's good.
Thanks, sb!
Looks like a good plan!
Awesome, great work. Thanks again for keeping the best site on the net alive.
I'm glad the rash of spamming will finally be over :)
It seems a good solution. Thanks
Thanks!
Thanks!
Good job!
I have seen that the internal search engine also has a captcha now... any special reason for that?
Not only that, but the internal search engine CAPTCHA is way more complex and annoying than the "1st post after login" CAPTCHA.
Thanks sb. Much appreciated that you've chosen an approach that won't affect the BLF vibe.
It's mainly to prevent a malicious robot from hammering the server with search requests, which are fairly heavy on resources. I guess I could probably change that one to a math CAPTCHA.
To Admin/Mod
Job Well Done!
