JasonWW
(JasonWW)
October 12, 2018, 12:26am
3987
Yes, stock driver. It was one channel FET. It drew 10A, but output seemed a bit low.
The TA based driver is only in the S43 and is a 2 channel FET + 1 design.
Hopefully TA will answer back about it’s amp draw. He told me previously that the output is still around low 2000’s range. It can definitely be improved with spring bypasses.
Besides the Mateminco version being available in copper, it looks like it also gets a different 18650 battery tube with the finger grooves in it.
Lexels S42 review .
JasonWW
(JasonWW)
October 12, 2018, 4:22am
3988
Okay, Texas_Ace says about 10A is what can be expected with your typical high drain cell like a 30Q.
If you bypass the springs you might see 15A.
M4D_M4X
(M4D M4X)
October 15, 2018, 10:02pm
3989
Hey!
available again for members: (M4D M4X DEALS)
and you maybe see those posted elsewhere - always compare my prices ;) ...
shirnask
(shirnask)
October 17, 2018, 12:15am
3990
My Amutorch X9 3*SST40 came in today - Thanks Martin and Neal
M4D_M4X
(M4D M4X)
October 23, 2018, 10:33am
3991
Hello my dear friends!
IMALENT MS12 is available to preorder in NW!!
FOLLOW THIS LINK TO NEALSGADGETS.COM
-> ask me for the code to save $$$ before oprdering!
check my youtiube channel for some videos... https://www.youtube.com/user/sepp4646/
SKV89
(SKV89)
October 23, 2018, 3:26pm
3992
Holy cow how did you convince them? Are they going to release a NW version of the R90C too?
SKV89
(SKV89)
October 23, 2018, 3:27pm
3993
M4D_M4X
(M4D M4X)
October 24, 2018, 9:20am
3994
new deals: Fitorch P25 and Haikelite MT03 (new driver by TA)
today i received deals for two very interesting flashlights:
Members can find the deals here: M4D M4X deals
non members can contact me
(the links get you to the shop for more pictures and information)
Features:
3,000 Lumens maximum output with 4 XPG3 LEDs.
4 illumination levels (High, Medium, Low, & Ultra Low), Strobe, & SOS functions.
Powered by a 26350 2,000mAh Lithium-ion Micro USB port rechargeable battery.
High-strength aerospace aluminum body.
Mil-Spec hard anodized for extreme durability.
10° optical lens for high light transmittance.
Power detection and location beacon function.
Waterproof in accordance to IPX8
Inpact resistant to 2meters.
Package included:
1 x Fitorch P25 LED Flashlight
1 x 26350 battery
1 x USB Cable
1 x Lanyard
1 x O-Ring
1 x Holster
HaikeLite MT03 TA Devourer
Specification:
Product name:
HaikeLite MT03 TA Devourer XHP70.2 P2 21000LM CW/NW LED Flashlight
Brand:
HaikeLite
Model:
MT03 (New Driver)
Emitter Type:
XHP70.2
Emitter BIN:
Cool white,Neutral white
Material:
Aluminum Alloy body with HAIII Anodize black surface Finish
Battery Configurations:
4x High Drain >10A button top 18650
Switch Type:
Side electrical switch with big Transparent rubber boot
Switch Location:
body side of the flashlight
Max Output:
21000 Lumens
Lens:
Ultra Clear Double-sided AR coated Glass lens
(99% Light transmision )
Reflector:
Aluminium OP Reflector
Waterproof:
IPX8 Waterproof
Color:
Black,White(limited edition)
Weight:
620 Gram
Size:
130mm length x 72mm Head x 50mm body
Sillen
(Sillen)
October 24, 2018, 10:37am
3995
Nice. The price on your site for haikelite MT03 TA is a bit off
M4D_M4X
(M4D M4X)
October 24, 2018, 11:21am
3996
yeah - I will correct asap
atm I try to get the baby to make a nap ;)
What does this mean - (new driver by TA)?
I’m interested in Fitorch P25, but I can’t find any info on the user interface; the link to the manual at the Fitorch website is not working.
JasonWW
(JasonWW)
October 24, 2018, 12:24pm
3998
For the MT03?
Texas_Ace designed a new driver for the MT03 and MT09R. It is a FET driver and uses NarsilM v1.3.
Originally both of these lights used a Haikelite designed driver and UI, but it was under powered and lacked proper features.
M4D_M4X
(M4D M4X)
October 24, 2018, 12:27pm
3999
i ask fitorch for the manual
I discovered that Banggood also offers the "MT03 II" with a new switch and driver. So which one is the new/better one?
Edit: The TA-version seems to be a different one. The MT03 II can only do 12.000lm.
Texas_Ace
(Texas_Ace)
October 24, 2018, 1:01pm
4001
They made a new batch of MT03’s? Or is this still the old batch they are selling off? Last I heard they only have a few left and would be stopping production on them once they sold out.
BlueSwordM
(BlueSwordM)
October 24, 2018, 1:31pm
4002
1st MT03 XHP70s and buck driver to achieve 9000 CW lumens.
2nd MT03 XHP70.2s and slightly higher power buck driver for 12 000 CW lumens.
3rd MT03 XHP70.2s with 2S FET driver and NarsilM capable of 19k lumens without spring bypass.
JasonWW
(JasonWW)
October 24, 2018, 3:59pm
4003
You are looking at the older version with the Haikelite driver. It was rated at 12k lumen.
I think they called it the MT03 II because they upgraded the leds from 70 to 70.2.
saypat
(saypat)
October 24, 2018, 4:58pm
4004
would like Narsil on the Fitorch!
blueb8llz
(blueb8llz)
October 24, 2018, 8:22pm
4005
Is it possible to get a green mt03 TA?
JasonWW
(JasonWW)
October 24, 2018, 9:45pm
4006
They did a limited number of MT09R in different colors, but I don’t think they ever did that with the MT03.
