M4D M4X deals - Astrolux WP1 and WP2 LEP
Hello my dear friends!
IMALENT MS12 is available to preorder in NW!!
FOLLOW THIS LINK TO NEALSGADGETS.COM
-> ask me for the code to save $$$ before oprdering!
check my youtiube channel for some videos... https://www.youtube.com/user/sepp4646/
Holy cow how did you convince them? Are they going to release a NW version of the R90C too?
new deals: Fitorch P25 and Haikelite MT03 (new driver by TA)
today i received deals for two very interesting flashlights:
Members can find the deals here: M4D M4X deals
non members can contact me
Fitorch P25
4x XPG3 LEDs with 3000LM
5 Modes IPX-8 Waterproof LED Flashlight
INCLUDED USB chargeable 26350 Li-ion Battery
(the links get you to the shop for more pictures and information)
Features:
  • 3,000 Lumens maximum output with 4 XPG3 LEDs.
  • 4 illumination levels (High, Medium, Low, & Ultra Low), Strobe, & SOS functions.
  • Powered by a 26350 2,000mAh Lithium-ion Micro USB port rechargeable battery.
  • High-strength aerospace aluminum body.
  • Mil-Spec hard anodized for extreme durability.
  • 10° optical lens for high light transmittance.
  • Power detection and location beacon function.
  • Waterproof in accordance to IPX8
  • Inpact resistant to 2meters.
Package included:
1 x Fitorch P25 LED Flashlight
1 x 26350 battery
1 x USB Cable
1 x Lanyard
1 x O-Ring
1 x Holster
HaikeLite MT03 TA Devourer
XHP70.2 P2 21000LM
CW/NW High Power LED Flashlight
Specification:
Product name: HaikeLite MT03 TA Devourer XHP70.2 P2 21000LM CW/NW LED Flashlight
Brand: HaikeLite
Model: MT03 (New Driver)
Emitter Type: XHP70.2
Emitter BIN: Cool white,Neutral white
Material: Aluminum Alloy body with HAIII Anodize black surface Finish
Battery Configurations: 4x High Drain >10A button top 18650
Switch Type: Side electrical switch with big Transparent rubber boot
Switch Location: body side of the flashlight
Max Output: 21000 Lumens
Lens: Ultra Clear Double-sided AR coated Glass lens
(99% Light transmision )
Reflector: Aluminium OP Reflector
Waterproof: IPX8 Waterproof
Color: Black,White(limited edition)
Weight: 620 Gram
Size: 130mm length x 72mm Head x 50mm body
Nice. The price on your site for haikelite MT03 TA is a bit off :wink:
yeah - I will correct asap
atm I try to get the baby to make a nap ;)
What does this mean - (new driver by TA)?
I’m interested in Fitorch P25, but I can’t find any info on the user interface; the link to the manual at the Fitorch website is not working.
For the MT03?
Texas_Ace designed a new driver for the MT03 and MT09R. It is a FET driver and uses NarsilM v1.3.
Originally both of these lights used a Haikelite designed driver and UI, but it was under powered and lacked proper features.
i ask fitorch for the manual
I discovered that Banggood also offers the "MT03 II" with a new switch and driver. So which one is the new/better one?
Edit: The TA-version seems to be a different one. The MT03 II can only do 12.000lm.
They made a new batch of MT03’s? Or is this still the old batch they are selling off? Last I heard they only have a few left and would be stopping production on them once they sold out.
1st MT03 XHP70s and buck driver to achieve 9000 CW lumens.
2nd MT03 XHP70.2s and slightly higher power buck driver for 12 000 CW lumens.
3rd MT03 XHP70.2s with 2S FET driver and NarsilM capable of 19k lumens without spring bypass.
You are looking at the older version with the Haikelite driver. It was rated at 12k lumen.
I think they called it the MT03 II because they upgraded the leds from 70 to 70.2.
would like Narsil on the Fitorch!
Is it possible to get a green mt03 TA?
They did a limited number of MT09R in different colors, but I don’t think they ever did that with the MT03.
for the output and UI, etc., at this price it’s a no brainer, seriously. I have the light, I paid $70 for it from Terry, the USA distributor, then sent it to TA for mods. It’s my best light!
I don’t think your answering his question.
Hello my dear frinds!
banggood listed the
Imalent MS12W
12 x XHP70 53000Lumens 8Modes
the code can be asked or found in my list:
M4D M4X deals
Hey my friends!
if you are in any way interested in the Fitorch P25 :
RECHECK the deal!! ;)
(not sure if it's a permanent price drop.. )
