Quick update, I got my hands on one of the lights I modded with the prebuilt driver you sent me Lexel, and I swapped an LH351D into it, and it still does the faint glow. Does it in the light, and set up by itself. So I think we’ve ruled out user error? Very odd.
Hope I don’t come off as upset, or demanding answers. It’s just a curious thing. I haven’t measured the standby current, but I’m not too worried about it.
I think I let speak pictures a bit, unfortunately only my phone camera I forgot there
bought a new shiney apartment, started to pack a lot stuff to move there fully till 31. Nov,
so thought I got enough time to get a few things done
Looks OK 2 minor things on to do list
maybe someone did a bad move when disconnecting washing or dish machine or so as I discovered water
getting worse
removing the dish machine to get below the kitchen part
You know woods color right?
finally below the dish machine I found black stuff that turned out be have been wood a long time ago
had to remove kitchen for further investigation
As I am not allowed as its house property not my apartment I had today first time a company here to replace the pipe
I finally got the permission to open the wall to get to the pipe before the workers come
Today also more bad news opened the wall next to the pipe and below the plaster was wood plate, looks now more like mold than wood
so bought heavy breathing protection mask for toxic stuff and started to open all up and removing the mold,
a company would charge me way too much likely and would handle it like asbest stuff
the only mobile picture I made today
with good camara I made a lot today but forgot it there
Wow, that is bad. I think over here apartment renters can’t work on things, the building owners have to do all work. At least it does not cost the renter money to fix.
Hard to say pipe fix is definitely house insurance
Water damage on walls maybe
Not sure if the last owners insurance will pay for the floor its obviously an old water damage which leaked over many years a bit and now got worse
The problem was made 1995 when the heating pipes were made new, some idiot drilled through the wall into the pipe and they put some glue stuff on the ceramic pipe instead installing a new segment
Oh god! We bought our more than 50 years old house two years ago and every time we touch something we found that the previous owners wanted to keep every cent they can on any job. I can feel your pain!
Hello, could lexel or someone help? I am building M2 Quad and my new 17mm FET driver from Lexel does not work.
I already checked,
leds are okay, no short (multimeter check, different driver)
resoldered wires on MCPCB
resoldered negative wire on driver
checked 7135 chips after I soldered spring, if there is no short (under hand magnifier)
pulled off driver, soldered to single MCPCB with led (led works), I connected a battery using crocodile clamps and wires to positive and ground
no response at all.
Then I checked driver again and found R1 connected to resistor?? besides and grounded. I have also another the same white version, which I haven´t use yet. I compared the resistors and they aren´t grounded. Does it matter and is this the problem?
