I have shared the information about the extension tube+carrier on TLF and that it is yet to be clarified if the extension will fit and work with the original tube w/o carrier. Sofirn has meanwhile checked if availability on Amazon could be an additional option to their store on AliExpress. They replied back on TLF:
"the extension tube has to connnect with the BLF Q8's head, not original Q8 tube. I just got a notice, the group buy of extension tube will only be available in aliexpress store."
@BlueSwordM: Please add 3 extension tubes + carriers for me. Thank you! I wonder if a 12p configuration is still sort of "lightweight"...haha. :-D
This is what I got as a sample two weeks ago, I do not know if it is the final version. I have not have time to really dive into it, sorry about that. You need both the two new tube parts because they need to be completely hollow to fit the battery carriers. They are made for button tops because no reverse polarity protection goes wrong very easily with battery carriers. But as you can see it is easy enough to solder shallow brass buttons on the carriers if you want to use flat tops (and are not scared of battery shorts every now and then :smiling_imp: )
The system works very well and despite what Sofirn said this works with both my Sofirn Q8 and BLF Q8’s. But I have not checked resistances yet compared to the stock Q8 battery situation. I have the hope that the springs used are copper-alloy springs
two new battery tubes(with two battery carriers) for the BLF Q8 head. Since the threads are different between BLF Q8 and Sofirn Q8, we need to make the tubes sperately.
I'm not sure if I got this right: Two new tubes for the BLF Q8 head? I assume they just meant to say they are making two new tubes for BLF Q8 AND Sofirn Q8, i.e. one new tube for the Thorfire "BLF" version and one new tube for the Sofirn version. Is that correct?
I’m sorry but I still do not understand, I have to modify my Blf Q8 before I buy the tube? if not, there will be a lot more lm? and how will it be with the length of the turbo mode? Thanks.
@SebaZ74, you will only have the buy the BLF Q8 version of the tube to make it work.
If you have not bypassed the springs, you will be getting more lumens since the resistance will be 1/2, and the current to the LEDs will increase, and there will be more brightness.
High turbo brightness runtime will be increased by about 1,5-2x depending on what 18650s you use.
You take off the stock battery tube and put it in the closet. Then buy two new tubes and two carriers. Then you can use 8 batteries in it.
Correct BSM?
A single blast of turbo should last about the same amount of time as it does now, or maybe a bit less, before the thermal protection reduces output. It might be a bit brighter, but not much.
Total run time basically doubles when you double the number of batteries.
