if I recall reading it, someone did a ‘reset’ and it fixed some problem like yours. Or default? Worth a try. Best!
- is default reset
Appreciate the thought but I can’t get to number eight if I can’t get to configure mode. Probably just re-flash the driver with STAR or something.
Just the usual problems with the X5/X6 driver, when driving an LED hard.
With a clickie switch interrupting the power, and totally inadequate decoupling or holdup of the MCU, plus the FET/LED switching spikes it was always a recipe for disaster.
Once the memory is corrupted, it’s toast, unless you re-flash it. A shame, because it could have easily been possible to detect that the non-volatile memory had become corrupted, and re-set it.
And even if you can re-flash, the same thing could happen again, at any time.
There are simple hardware mods that can fix all of this, if you are handy with a soldering iron.
See my post over in the other thread.
The centering ring may not put pressure on the MCPCB (or only via the wires / solder joints). If you wiggle on the leads from the driver side, check for movement of the emitter.
Mine also had some lead particles from soldering under the MCPCB and consequently dents. I recommend cleaning everything.
Man, just one T18 thread is enough. Now two threads to look for info.
Of course anyone can start a thread, just that you mentioned T18 original thread.
Ah….
Thanks for the incisive tech talk. Btw what are those simple hardware mods from your perspective?
PS…In light of what Tom Tom has said here and reflecting on what others have experienced I’m glad now that I didn’t have time to mess around with the UI modes. I kinda had a hunch to wait and see if others got consistent results before I started choosing this and that mode configuration of the apparent 8 modes available.
So here’s just a copy and paste of my post # 676 of T18’s thread for those that just wanna stock simple reliable light that works every time in a way that’s expected……
“Ok. So again how come apparently I’m getting #7 of the BG erroneous list?
Getting it by……
Tail cap unscrewed half turn (Or even 1/4 turn unscrewed. Whatever floats yer boat. Extra unscrewing to say half is extra insurance of it not coming on accidentally during for instance rigorous activities.)
Screw tail cap in. Tail cap lights blue.
Full click to on. Get moonlight.
Half click (momentary press actually is a better term IMO) 6 times to turbo.
Then again this may not be # 7 of BG bad list to begin with but is part of the corrected modes? This is all confused up me thinks.
IDK….
PS…Oh and if I continue to half turn or so tail cap after it goes into turbo it strobes, half turn again appears as a beacon, half turn again stuttering strobe, half turn again back to moonlight, half turn again right back to turbo.
Now if I do a half turn screwed in without the tail cap blue lit, I get moonlight, then unscrew half turn, then screw in half turn again, I get right to turbo.
I like to keep this kind of flash while in a jacket pocket for example with tail cap disengaged at all times btw. Just me. The main reason is that I like moonlight to come on first especially on new moons. So with this arrangement without messin’ around with the clicky (and it making noise) and using the tail cap instead it goes right to turbo which is what I want for throwing and mega flooding.
Also I now have the option if I want to “ramp up” the increases that can now be done with silent momentary presses. Likewise momentary switching to get ramping decrease right back to moonlight and ramp up gradually to turbo again. IMO the true forte of this rig is immediate full power when ya want/need it. Finesse when ya don’t. Standard desires, right? The tail is your friend. Kinda like a twisty zoomie. No pussin’ around.” :laughing:
Lumens is lumens. Lumens make money. So follow the money.
No, because I don’t have it yet due to Canada post deciding they don’t wanna work anymore.
Do ya have the Post #? That’s a big thread to sift through.
Here ya go:
Hey, it’s not THAT bad. But it’s clearly a point where the Jaxman is a better design. Its retaining disc doesn’t have that shoulder (though depending on the MCPCB thickness it may still bottom out on the perimeter of the pill). [image] That’s the old Jax version 1 in kikkoman’s pic, I’m reasonably sure, that pic was before they realized that the black round thing called the limitation ring was needed that keeps the LED center cover from sitting on the LED, that was added to the build in 2…
YMMV if your centering is of the older type (alu). May have different dimensions.
18650 adaptor is junk it is way too small . Instead I rolled up cardboard round an18650 cut to size and shoved it in the body . Just making sure the battery canslide up and down . On th body I added lots of small orange rubber bands it adds grip and running two thinrubbernands in every other groove gets rid of some of the head wobble... looks cool all up and down the body too ... 3 minute 3 cent mods
Thanks, Kikko. Nice work and the pics are appreciated.
18650 adaptor is junk it is way too small . Instead I rolled up cardboard round an18650 cut to size and shoved it in the body . Just making sure the battery canslide up and down . On th body I added lots of small orange rubber bands it adds grip and running two thinrubbernands in every other groove gets rid of some of the head wobble… looks cool all up and down the body too … 3 minute 3 cent mods
I bet it does look cool. I’ll have to scout around for some bands to give it a go.
PS. Since I tend to be a 26650 junkie, I sometimes Glad Bag those loose fitting adapters like what came with the Cometa. Othertimes I vacillate between the 26650’s and 18650’s but don’t wanna mess with a semi-perma sleeve like you did so I just wrap the 18650 with two appropriate sized o-rings (top and bottom portions) and that’s my quick and dirty Magiver adaptor solution to loose fitting sleeves - which indeed suck bananas. Now the Cometa adapter works as it should.
Here’s what I use……
https://www.harborfreight.com/397-piece-metric-o-ring-assortment-67580.html
Specifically for most of my 18650’s I use the #112 size outta this great bargain of a kit. When ya slide the o-ring batt into the adaptor the top O-ring will tend to slide to about mid-point of the batt. The bottom o-ring will pretty much stay put as you installed it. Either way ya now got plenty of support in the adaptor with the batt nicely snug (yet still removable) and pretty much centered as it should be.
You can go with the SAE kit too and just find the o-ring that fits your batt best.
A must kit to have IMO for lots of other applications. The organization of the o-rings is great, the quality box, decent quality nitrile-grade rings, and of course the ridiculous low price is absurd. You’ll wonder how you ever went through your flash life without one. :laughing:
Little tiny ones like the size of a pinky ring. Somehow ended up with a bag of 500? Black and orange is a nice combo . I put two in every orher groove and twisted them together tightly to make sure thay were the same thickness all the way around . Then for fun i just filled all groves on the light witha rubber band
The driver runs seven modes up from moon with quick half clicks ... or from moon a longer half click reverses the order and takes you straight to turbo , next long click is strobe, next long click is a battery checker . And the next long half click is a bike flasher. I think thats the default setting and no memory starts in moon mode . Overall I like them just like they are . Maybe turning on memory so it starts in the mode you turned it off in .
Half clicks up and long clicks reverse the order . I really like these drivers
“I really like these drivers.”
Yep me too. :heart_eyes:
No GD crenalations to poke my nutz or tear up my pockets.
Pockets? What, do you wear clown-pants or something? These things are huge, even bigger’n C8s.
Jacket or vest pockets mostly butt i’ve been known to walk up to a pretty gal intentionally with one in my right pants pocket (I lean right anyway……)
Lot’s a times you almost run outta pockets when you’re messing around with all your various flash collection permutations, ya know?
Fully collapsed these things are longer than C8’s? :question:
“Is that a Cometa in your pocket, or are you just on fire?”
Not anymore. Got a shot of penicillin.
