What about a dental mirror to get a better pic?
Right, that would be helpful...if I had one. I guess I have to buy some more tools with the next flashsale. :-D
Um, I could of course be wrong, but I’ve modified hundreds of lights and it looks to me like the battery tube screws in and pushes against the driver. When you look at the design, with the side switch and all, how else could they get the driver in the head of the light? But of course, I don’t have the light in hand, only looking at a picture… but this picture looks to me like there’s a break between the head and tube.
Edit: The Rofis MR70 looks to be a one piece design (The MR50 also). The MR30 does not. Your picture showing inside the tube indicates the large driver is in contact with the end of the battery tube, virtually always assembled by putting the driver into the head and screwing the battery tube onto it.
The Rofis website shows a run time chart that indicates a 1 minute step down and then another stepdown at 7 minutes, thermal timed stepdowns I suppose. This is consistent with some of what you describe in your OP, but the other issue with a short spring and some cells not working, can’t be sure without getting a better look at the spring itself.
AFAIK the MR30 tube cannot be unscrewed but I might be wrong. I need to check this. As my skills to break a light are far better than those to repair it, I better keep my hands off the thought of unscrewing the tube with brute force. :-D
The two stepdowns are time-triggered, i.e. the turbo can be repeated again and again. Of course, the MR30 gets really hot as I have figured out with the fully charged Acebeam 20700 cell. But once the voltage is down to a certain value like 3.9V the light behaves strange and will not use the turbo like it did before.
So, there must be some contact problem here but I don’t know where to look for except for the driver spring I can‘t reach. I cannot imagine that Rofis intended to operate the MR30 with long protected cells only, though.
Anyway, I greatly appreciate all your help! :-)
The head and tube should come apart its just loctite in place and will be hard to open.
I have the MR50 model and there is similar annoying problem. Even with fresh battery and cleaned contacts, the turbo most of time drops to low/medium mode after few seconds. On rare occasions it stays in turbo for a while, but then there is again the same problem. No idea how to fix it, I strongly suspect the driver to be faulty.
I unscrewed the bezel and tube on my MR30 by using water pump pliers and rubber strips to avoid scratches. It came apart easily. The switch on my light failed after two weeks and Banggood sent a replacement unit.
For those having short turbo runtimes, try and clean all possible electrical contact points… Springs, battery terminals etc. I had such a problem with my MR70 and after cleaning it the turbo runtimes returned back to normal. I heard from JasonWW that the boost drivers are very sensitive to resistance and any dirt would increase the resistance of the total electrical circuit.
This is the response I got from Rofis customer service upon my kind request for assistance to resolve the issues I have with my MR30. It clearly points out that their boost driver is of poor quality not capable to ensure the turbo level below 3.85V (more than 50% capacity left) and that – in contradiction to their advertisement on the packaging – the MR30 only works with 21700 with protection circuit. From other MR30 owners I have heard their flashlight‘s turbo level works until cell voltage drops down to 3.5V and that unprotected 21700 batteries work just fine.
Hello, thank you for your feedback.
Our MR30 uses a 21700 battery with a protective plate.
If you are not working with a battery with a protective plate,
you need to consider the compatibility of the protective plate with the flashlight.
Regarding the trubo, the battery needs to be implemented at 3.85V.
Below this voltage, the flashlight will not run trubo or shut down.
If you have any suggestions, we will optimize the circuit, thank you~
ROFIS Service Team
OA:No. 2990 Songbai Road, Shiyan, Bao’an District, Shenzhen.
Tel.: +86-755-82552272
Website:www.rofislight.com
ROFIS Technology Co., Ltd.
Bottom line: So far so bad for the 5 year warranty that is worthless! No help from Rofis to resolve clearly obvious flaws on my MR30 but a cocky last phrase to encourage me suggesting ideas for a better boost driver.
This will be my second (along with the MR70) and my last Rofis flashlight.
I will test my MR30 and see at what cell voltage it stops running on turbo. This sounds very suspect… The 3.5v users reported, is it resting voltage? What about voltage sag??
I reviewed the MR50 and also noticed very aggressive step downs almost instantly after activating turbo - but that light has a ‘button’ as the positive contact, and there’s still plenty of compression on the spring, so that might not be the cause. Maybe it’s the cell itself?
I checked it with another long, protected 20700 Acebeam battery and the same happened there. I cannot tell for sure if there‘s any room for compression left on the positive side (driver spring) when looking on my pictures. The spring looks collapsed/fused and partially covered within some black residue. FWIW, it does not look like it should look like. As the tube is glued to the head I cannot unscrew it just like that. Moreover, it would void the warranty...well, what warranty do they mean if this just a „hollow promise“?
Meanwhile, Banggood has asked me to do another video, showing that the MR30 will not work with unprotected 21700 batteries. I will provide this video asap, hoping they will help me on this matter.
Started noticing very slight stepdowns at 3.67 V. And what I mean by that is:
Double click, goes to turbo and after about 5 seconds it drops to what looks like 1100 - 1200 lumens. And at the 1min mark, it drops to the 750 lumens high mode which I can clearly see.
I guess the closer the cell will get to 3.5 V the bigger the output drop will be from turbo after a few seconds before returning to the 750 lumens high mode.
Make sure your springs, battery terminals and the connections where the tube and tale cap meets are clean. I have found the grease on the threads goes very runny when the light gets hot, and then ends up going on the end of the tube because I loosen the tail cap to lockout the light. I clean it regularly to avoid extra circuit resistance….
Your light might be defective though. My 1st MR30 had a switch failure within the 1st 12 days of usage but Banggood replaced it. As for the MR70 I only get about 7 - 8 turbo runs before it starts with the same throttling effect in turbo. I am almost convinced it is voltage sag that is causing this. I am still looking for a 26650 for the lowest possible voltage sag to prove this. And I wonder how other single 26650 XHP70/70.2 lights perform, like the Lumintop ODF30 and Olight R50 Pro Seeker??
Any ideas what to do with my other MR30 shelf ornament? :arrow_right:
MR30 driver images
https://photos.app.goo.gl/7GuJvaaAfckRbV1S7
https://photos.app.goo.gl/vwND1exGX52frkuf8
Your flashlight is 100% defective. I was out and tested. I repeatedly turned on the turbo mode. Many minutes until shutdown. The torch was very hot. After removal, the battery was 3.7 volts. Voltage without load. When the turbo power was drawn, the voltage had to drop a lot. For a moment I waited until the voltage stood at 3.75 volts. The torch was in the turbo mode again. I believe that up to a voltage of 3.5 volts at load, the turbo mode is working. If your lamp turns off at 3.85 volts, it is defective.
Mine MR50 has probably the same issue. Turbo drops immediately even with full battery, there must be something with the driver.
Thank you guys for your feedback! I'm glad I was proven right with my assumption.
I asked my friend again and he says it was the resting voltage when he took out the battery and measured its voltage before activating the turbo again. BTW, his MR30 is - after maybe two weeks of usage - dead now as the side switch will not work anymore. It's still clicking and the battery indicator still works but the flashlight cannot be turned on anymore.
Exactly what happened to my 1st unit. Let him claim it from Banggood. He will have to submit a video… I believe it’s a problem on a lot of MR30 lights and Rofis has to own up for their defective products. I certainly won’t buy another light from them again.
Exactly what happened to my 1st unit. Let him claim it from Banggood. He will have to submit a video... I believe it's a problem on a lot of MR30 lights and Rofis has to own up for their defective products. I certainly won't buy another light from them again.
Yeah, that's what he's doing right now. Rofis did not help him either only asking for more videos that prove that the MR30 cannot be turned on anymore. In the end they probably refuse to help him just as they did with me. If this is what they call customer service they can K.M.A..
MR30 driver images
Thanks for sharing those pictures! FWIW, my driver spring looks very much different to yours.
Contacting Rofis directly is a dead end. I also tried that. They don’t want to help because they are probably afraid to admit their products are defective. Banggood will sort them out! I’m selling mu other Rofis lights and will replace them with Olights. At least they have proper customer service and quality.
