GB 351D closed.
Good to hear that the 4000K/90CRI will be available again soon.
I’m still interested in another 10x, along with 5-10x of the 5000K 90CRI, too.
Just wondering if there’s a more definite ETA on the new batch of LH351D 4000K :slight_smile:
Do you have any news about the stock oft these LEDs?
I’m still interested!
Hi I ’ll get about 120pcs 4000k next week.
5000k are on the way, I think I ll get them at end of November or early December.
I also try to arrange a list in first post .
Привет, Андрей!
That's great news. Can you already estimate if and when the LH351D 3.000K 90CRI might become available, in case it's still the plan to sell them? Just asking as I would like to combine my order for 351D 5.000K 90CRI with the 3.000K 90CRI. ;-)
Большое спасибо!
Томас
5000k 90cri 100 pics
50% what does that mean? I also wish you can source some rosier tint bins. The current ones are all above the BBL and yellowish unless used with minus green filter. Samsung chromacity graph is completely off. The T6 and T7 bin is supposed to be below the BBL but actual is far above.
I think he meant 50/50 chance of getting a nicer tint bin. So no go this time.
I will try to test new batch of 351D by my simple specrophotometer and compare with other led
Got my 10 LH351B 2200K… never saw such a warm tint !
From left to right :
- LH351B 2200K
- LH351B 3000K
- SST20 3000K
- XM-L2 7A 3000K
- 219B 9080 4000K
- LH351D 4000K
  • XP-L HI 3D
That’s verry verry warm. Thanks for the pic.
And 5pcs 2200k please.
:+1:
My sectrophotometer said previous batch T=4080K Duv=0.0027 . New batch T=3930 Duv=0.004 . So new batch is more greenish and warmer.
OK
Any chance for CRI80 LH351D?
Man that’s unfortunate. Really wish there’s a way you can choose the tint bin from Samsung instead of receiving these random greenish ones. This emitter has so much potential. Thanks for testing.
Chiming in after slicing the dome off two more LH351D 4000K 90CRI leds to report that the slicing results are very consistent: the tint ends up around 3500K and below the BBL. Judged by eye it is an extremely good rosy tint.
For slicing, this time I used a brand new Wilkinson oldschool razorblade, in three slices: first the top of the dome, then close to the final height, then the last thin slice to just above the phosfor. No sanding.
These are measurements of the hotspot of my Convoy T2 now with sliced LH351D 4000K 90CRI. (FET driver, purple Efest 14500, 860lm at start, 710 lumen at 30 seconds) :
Thats great news!
Did you also measure before shaving?
The LH351D is usually rosy at high currents. At low currents is is usually yellow, above the BBL. Can you maybe measure one at different, fixed current with your power supply before and after shaving? Maybe also include the Luminus SST-20 4000K 95CRI. That would be really nice.
can I order 12 2200k?
I have never seen any measurements showing the LH351D being rosy. All the data I’ve seen shows it at above the BBL at high currents. Djozz’s shaved dome measurements are the first to show the LH351D 4000k can be made to go below the BBL.
Personally being a tint snob, I can’t stand the yellow green on the LH351D. It is similar to the Nichia 219C, which I never liked. Once you compare it with the E21A, 219B 9080 or Cree 5A or 5D tint, you will see how green the LH351D is.
