E-switch UI Development / FSM
Ah gotcha, I worked through the build-all.sh -> Build-85 and think I have a relative handle on things, at least for now. The ubuntu windows 10 plugin is stupid easy and set up after an “apt-get update”
Compiling works out of the box using your scripts after downloading a copy of the branch.
I think I initially overlooked it because im not familiar with the AVR-GCC options and flags, but is it the “-DFSM_${TARGET}_DRIVER” in (…/…/…/bin/build-85.sh “$UI” “-DFSM_${TARGET}_DRIVER”) what defines it? The lack of a space after the -D threw me off.
It just defines, that for example, FSM_BLF_Q8_DRIVER is defined.
In C, you can both check if a define exists and if it exists, test for values.
In that case, it just uses the define to test with #ifdef or #if defined(...)
Flashed my D4 with Andúril. Used 2018-09-07.EMASAR_D4.Hex
I am getting step down almost instantly. Not feeling any heat unless I keep double clicking to Max. I have tried several fully charged cells. So I am looking at the thermal config.
I 3 click from off to bat check, 2 click through sunset and beacon. I think I am ending up at TempCheck I am getting a 2-1 blink. I believe it means 69 Fahrenheit.
I click 4 times and get a stutter light. I click 22 times, stop, light stutters again and goes back to 2-1 to 2-3 binks, thinking 30+22= 55 celsius for 131 Fahrenheit.
Is this correct?
Edit- I am only holding Max for about 2-3 seconds, and then it steps down, another 2-3 seconds steps down again.
Do I need to set it much higher?
Ok, watching a video, Looks like I need to click 30 times, then 22 times.
Edit, still getting almost instant step down. From fresh cell.
I’d suggest doing about 20 clicks on the first step, to calibrate the sensor to room temperature. This is, of course, after the light has had a chance to settle to room temperature. Then about 20 clicks on the second step too, to set the ceiling to 50 C.
You could also try compiling with THERM_HARD_TURBO_DROP disabled, to make it less cautious about heat. But this risks having the opposite problem, overheating.
I need to rewrite the thermal regulation algorithm entirely at some point, but I’ve been avoiding it because it’s a huge pain to actually do.
I damaged the driver removing it. the little square thing by the R5 is gone
You accidentally removed a resistor from the driver and you’re wondering why the light is behaving weirdly?
LOL, didn’t know I removed a resistor at the time.
47r is back on. Now I need to get the switch out. Lost wire off switch.
Im still working on my own personal build of RampingIOS V3 (and Anduril) and wanted to alter the voltage calibration as its reading about ~.2V high until 3.6v, then consistently .1v high until LVP on both of my D4S.
Looking at the readme\config txts for SpaghettiMonster, fsm-adc.h and RampingIOSV3 and I only see references to VOLTAGE_LOW and VOLTAGE_FUDGE_FACTOR. The Fudge factor seems more oriented towards voltage drops over protection diodes though.
I found a tk-calibration.h file in the root of the ToyKeeper folder but I couldnt find an include or a define that would pull it. Is that the correct place to be altering the readings?
Edit: tk-calibration.h is also defined by tk-voltage.h/TK_VOLTAGE_H but im not finding a reference for that either.
Change voltage drop value, it should resolve the problem.
As in the fudge factor value? 0 -> –1 ?
Edit: it pulls from the D4 config to use a fudge factor of 5 for +.25v so im assuming its ~.05v per point, ill give “2” a whirl
I was adjusting the value in NarsilM firmware and it was named D1_DIODE, see here https://bitbucket.org/dmn/narsil/commits/b3d1004cf02540f899b8963de959d4b52f1df004#chg-NarsilMulti/Setups_3C1S.h
I don’t know how it is named in Anduril.
Yes, what you’re looking for is probably the VOLTAGE_FUDGE_FACTOR. It’s 0.05V per point. If the value you’re using is 5, and it’s reading 0.1V to 0.2V low, I’d suggest adding 3 to make it 8. This adds 0.15V to the values it uses.
The calibration stuff is mostly for older lights with a voltage divider on pin 7. But that’s not used on most newer lights.
Well, this went MUCH better than expected. Everything compiled super easy in the Linux subsystem for Windows, and I flashed using AVR-DUDESS using the fuses defined in TK’s flash scripts.
Anduril is so nice on the Q8, and IMO so much less confusing than Narsil. Especially when you can comment out almost anything you dont want, set defaults, and modify click counts to move states around.
Now I just gotta flash the D4S………That was a bit of a struggle, but hopefully some solid core wire will make that easier. Makes the light even better, voltage readings are spot on now.
I’m curious. What all did you change?
(if you have the repo checked out with bzr, you could use “bzr diff” to get a reminder of everything which is different)
Hi ToyKeeper,
Have you got any Idea as to why I cant use PB4 as Channel 0 in a 2-Ch driver?
I’m currently flashing a Astrolux S43.
If I only set CH1 to PB4 and CH2 to PB0 I can only use the FET channel.
But if I set a imaginary CH3 to PB1 everything works fine.
I suspect your comment “// Second PWM counter is … weird” has something to do with that…
hwdef-Astrolux_S43.h
cfg-astrolux-s43.h
That config as posted works.
But if I remove Ch3, Ch1 stops working.
Just fyi this was for a Q8 and 2xD4S
I set defaults for:
RAMP_DISCRETE_CEIL (MAX_1x7135) (default unless not defined)
default temp limit upped to 50C
altered Fudge Factor values to calibrate for my drivers
longer pause at moon level from power off
upped low voltage level to 3.1 so it will start stepping down earlier for lipo health
slightly lowered candle mode default brightness
static uint8_t candle_mode_brightness = 21 (was 24) Not sure if this is correct though
disabled all strobes and beacon (Just made goodnight ev_2clicks go to tempcheck state)
completely removed momentary (not really necessary, but didnt want to deal with the power cycle to leave “issue”)
Modified event handler to have a longer hold timeout for the q8 (I cant seem to press it as fast as other lights)
Ill be honest though, I had more tweaks done to RampingIOSV3, but Anduril is near perfect out of the box. I just wanted to make a few things easier to access for myself.
Yeah, it’s because I don’t have any drivers which work that way, and it assumes the two paired primary PWM pins will be used first, with the second timer channel as the extra or third PWM. The third channel runs at twice the speed, last I checked, which isn’t good for low modes. I’m not sure how to make it go slower; despite making a bunch of attiny firmware, I’m really not into the low-level aspects of programming, like virtually everything in the attiny reference manuals. So while we may have a nice API for building user interfaces, the underlying hardware support code is pretty clumsy.
Basically, the hardware abstraction for that is incomplete.
If you know anyone who enjoys the low-level bits and is willing to volunteer some time, it would be really helpful.
Yeah, after a glance at the datasheet, that should be fixable.
From the top of your head, do you know other HEW areas that would need fixes as well ?
I think I read about a problem with ADC readings a few pages before.
And of course, a full HW-abstraction layer would be the overall goal if support for the Tiny84 or Tiny1616 will be added.
But that would be a whole different story.
The ADC seems to be running in continuous mode, even though I don’t think I told it to. So I made the ADC interrupt bail out unless a flag was set by the WDT to allow it to run. I tried changing the ADC flags, but nothing I tried worked, so I went with the workaround instead.
FWIW, an easy way to test it is to remove the workaround and then trigger LVP. If it takes at least a few seconds per step, it’s working correctly. If it goes off almost immediately, the ADC is running too fast.
About PWM, I expect that fully abstracting the PWM channel setup will be messy because the pins aren’t entirely independent from each other and some combinations may require extra workarounds. It’s a lot easier to assume that only the first timer gets used when the driver has only one or two channels, which is what it does now.
There will also be a need to support other types of power channels, like on Lexel’s dual-linear-FET driver. And other ramping models, for tint ramping and such.
I’ll probably try to update the config mechanisms again to make it easier to pull in specific code at compile time based on the options chosen. What it’s doing now is inconvenient, and I get the feeling it’ll need to do a lot more of that sort of thing as the collection of supported hardware and software expands. But I’m not really a kernel programmer, even if I’m sorta acting as one, so this is all a little foreign to me. Maybe I should go read the Linux source for some ideas.
