OK So I still have some 95 CRI 3,000K massive
10+mm emitter
11.44 pad
on alu plate, looks like you can run wires right to pad so any substrate should work. I also have big massive alu heat sinks that were designed for them. (the (heatsink) finned thingys below only. I no longer have complete lights just emitters/mcpcb/heat sinks) heat sinks are 45mm across
I hear they run on about 30VDC but may run well on other voltages near this number, should be 1,000-1,250 lumens at those factory numbers
any interest?
would love to work with some one to build me some simple single mode drivers
not full lights just from the fins up. also have a few TIR and outer plastic 5 inch rim to hold TIR but many folks may want a more custom application
