OSRAM KW CSLNM1.TG (1mm2) & Osram KW CSLPM1.TG (2mm2)
642 posts / 0 new
Barkuti
Barkuti's picture
Last seen: 17 min 53 sec ago
Jerommel wrote:
The LD25 is not (much) more expensive than an Astrolux DD driver, is it?
$4.40 at FastTech.
Jerommel wrote:
You can resistor mod it to 4 Amperes if you want (maybe more?).
It actually is much easier and all modes can be independently adjusted:
The current adjust point is a pinhole with annular ring where you can insert and momentarily solder a small wire to tap on negative/ground for adjusting. Be aware of the voltage drop in the power supply to driver path (wires and connections) when raising current to high levels, 0.2Ω in the path at 5A is a full volt. Increase supply voltage accordingly to see and tune higher values.
Cheers Party
ZozzV6
ZozzV6's picture
Last seen: 22 hours 56 min ago
Barkuti:
But the LD25 only capable 3A max and this led need 5A to reach it full potential.
Barkuti
Barkuti's picture
ZozzV6 wrote:
Barkuti:
Why? Did you tried to ramp its current up and did not succeeded?
ZozzV6
ZozzV6's picture
No I don’t have LD25. Just from fasttech data I thought it has a max limit at 3A.
Theodore41
Last seen: 58 min 58 sec ago
Geuzzz wrote:
Ok. I went into my cold shed for you guys and have some measurements.
I think I usually measure a bit lower than others around here and I measured some lights again to have a good(ish) reference.
I have a almost clear image of the die, but I feel it can be a tiny bit better focused.
I did not measure ampdraw, but I got best results using an old protected keeppower 18650. With better cells I got worse results. So it is indeed better to keep the amps down a bit.
D1s stock (5d) 115kcd
Souponfire thrower, fet dedomed xm-l2 205kcd
Cometa osram throw king 315kcd
!{width:95%}https://i.postimg.cc/qvML2yh6/20181029-205854.jpg!
Oh la laa.It is time to take out of the drawer my Cometa,which gives 164Kcd with the Z1 original lens…. Smile
Is there some special difficulty with the Cometa’s mod?
djozz
djozz's picture
Last seen: 15 min 6 sec ago
Quote:
Lack of regulation means the user needs to carefully consider and adjust lots of parameters to avoid overdriving emitters or just running them past their optimal points. This can mean tuning resistances for the whole chain of parts inside a flashlight.
All that careful consideration and adjusting described above I do for every driver not just DD ones, every flashlight build I try to give its own optimal configuration.
The LD25 can be a nice option too but has its own characterics, positives and negatives. It does not come in many sizes for example (i.e. I just reflowed a 15mm FET+1 driver with A6 firmware, working perfectly in a small EDC). Does it really go up to 5A?
Don’t get me wrong, I prefer current regulation for a lot of flashlight builds, but in many other situations DD is the way to go for me.
-X3-
-X3-'s picture
Last seen: 50 min 30 sec ago
Okay, I don’t have any numbers but here is my herd of throwers anyway :
From left to right :
  • Olight M3XS Black Flat
  • Cometa “White Flat”
  • Amutorch JM70 XP-L HI (tried a “White Flat” in there, but the TA FET driver on Turbo made it turn Blue/Purple… back to normal though after stepdown)
  • Emisar D1S Black Flat
  • Emsiar D1 Black Flat
  • Olight R20 “White Flat”
Now the beamshots, in the same order :
My impressions ? Well the Emisar are perfect for Black Flat because the head is insulated from ground, as well as the M3XS…
For the others, the “White Flat” is perfect !
Now the most impressive IMHO are the Cometa which turns into a white laser with this LED Silly and the R20 which really throws a strong beam with its tiny reflector… Oh and the beam is really clean, without artifacts.
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 26 min 24 sec ago
Good work! The Cometa looks awesome id be interested in the throw numbers if you bother taking any.
Where did every one buy the LEDs from? Any international friendly sources?
Theodore41
When you say “white flat”, you mean this new OSRAM KW CSLNM1.TG led?
-X3-
-X3-'s picture
Yup, the one LED4POWER sell on his website
Henk4U2
Henk4U2's picture
Last seen: 10 hours 36 min ago
Like here.
I always think long and hard before I say something really stupid.
Theodore41
Henk4U2 wrote:
Like “here.”:http://budgetlightforum.com/comment/1401200#comment-1401200
I see,thank you.
luminarium iaculator
luminarium iaculator's picture
Last seen: 2 days 4 hours ago
EasyB wrote:
Looks like a good LED, but it seems like it doesn’t beat the dedomed XPG2 by much in terms of throw in the examples above. E.g. the D80 and S8. I recently measured a dedomed XPG2 (new style) in an S2+ smooth reflector at 29kcd.
Is this an issue of improper focus or reflector imperfections or over/under driving? What are people’s understanding of this?
If driven to maximum Osram White Flat will beat good old xp-g2s42b from 20-30% and new production process XP-G2 emitters will be beaten for about 50% Beer
I don’t know for other but in B158B host I had 330 KCD with old dedomed XP-G2 S42B but now with Osram White Flat I have 430KCD so yes with B158 you will get close or brake 400KCD mark depends on modding techniques. Not sure for beam size(even under precoolimator)… I would also like to see more lumens from Osram Smile
Same happens with Mikos super reflector 15$ thrower (Supwildfire something) that should easily brake 400 kcd mark.
Yes… Really no doubt that OW is better than XP-G2 S42B but not in everything… 2B has larger die, and it is well suited for mentioned unregulated FET DD drivers since high current cell does not bothers him…
So why FET DD some people despize? Well it depends how you use flashlight… If you don’t have need for longer runtimes on turbo than real question is why not? Especially with older emitters like g2s42b Smile
But with OW i think it is nice thing to stay in regulation.
Modding is making something how you want it to be, not how it comes stock...
Old-Lumens
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 4 hours 24 min ago
Has anyone considered to put this one into the BLF GT or Astrolux MF04/Mateminco MT35+? It would be quite some laser beam. Big Smile
Nicolicous
Nicolicous's picture
Last seen: 7 min 54 sec ago
it will be tough time to focus the beam
Nico -.-
Jerommel
Jerommel's picture
Barkuti wrote:
$4.40 at FastTech.
Cheers Party
I think that’s the old version of the LD25.
2Q19
Geuzzz
Geuzzz's picture
Last seen: 5 min 56 sec ago
Played with the focus on my cometa today (removed the oring between the lens and the bezel, and turned the light not fully out) getting 360kcd out of it now.
Also hold the lens of my b158 in my hand in front of the cometa withiuy bezel trying to focus it and saw 390kcd. So with a good brinyte you should be able to go 400+.
Lfatman
Lfatman's picture
Last seen: 1 min 13 sec ago
560KCd in short Maxtoch SN6X-2X with 4A LD-2 driver.
Camo Warsun MX900 will be the next
Henk4U2
Henk4U2's picture
Ordered some White Flat’s on saturday, and they arrived tuesday. As always in good order (kudos Neven).
Took a C8 host, an X6/X5 driver, an XR reflector (Fasttech), a Canadian cent, and a 3535 centering gasket.
The cent I needed because the reflector is circa 1mm shorter than the original one and the gasket got a djozz-micro-mod to fit the 3030 emitter. Difference is I made it black with a felt tip pen.
Let’s start by saying that I followed the budget luxmeter comparison of djozz with great interest.
So my mindset was to take the results of my 1010B luxmeter only serious when used as relative values.
Nevertheless, the meter started out at 171kCd and slowly decreased to 130-ish kCd for the C8 + Osram.
Then I put my Olight MX2UT on the line, and it scored a pretty constant 119kCd on my luxmeter.
I know that the MX2UT is rated for much more, so the outcome of my C8 + Osram must be higher too
Below is a side by side comparison of the C8 (left) and the MX2UT with dedomed XM-L (right) on full blast.
Edit: the abnormal looking hotspots are caused by the paper I shine on. It is a bit wrinkled.
gchart
gchart's picture
Last seen: 2 hours 20 min ago
Henk4U2 wrote:
Took a C8 host, an X6/X5 driver, an XR reflector (Fasttech)…
I’m not familiar with that reflector. Is there an advantage over the stock C8 reflector?
DENGOH
DENGOH's picture
Last seen: 14 hours 19 min ago
Barkuti, thanks for pointing out LD25 driver. I think it is the most suitable and cheap too.
It is proven this LED will turn blue with DD driver using good cell.
I am wondering if we set the Cometa stock driver to its muggle mode that has half of Turbo as highest mode, will it be okay and not to driver it blue? I am not familiar with its stock driver.
cool i'll see you when you get there
nofearek9
nofearek9's picture
Last seen: 2 days 13 hours ago
wondering if it will survive with DD vtc6/30q on my couroui D01 with copper pill and 32mm copper pcb.
DENGOH
DENGOH's picture
Even if it survive, its output is lowered. So why take the risk.
Theodore41
Lfatman wrote:
560KCd in short Maxtoch SN6X-2X with 44 LD-2 driver.
Could we put this led in a Maxtoch 2X shooter?
djozz
djozz's picture
In theory, the X5/X6 muggle mode should not help because the led is still driven at the same very high current that the led can’t handle, with the PWM only switching it on/off fast. In practice, part of the why leds perform lower at too high current is heat, and that is reduced when the led is PWMed, so you will see an improvement (i.e. PWM-ing an angry blue overdriven led will in general improve the tint).
But much much better is reducing output by actually lowering the current.
DENGOH
DENGOH's picture
Thanks for explaining. I was hoping the PWM voltage going up and down fast that LED current can’t keep up and average out at lower level instead of pulsing let’s say 6A on the LED.
Henk4U2
Henk4U2's picture
The XR reflector is optimised to handle emitters with a smaller footprint and a smaller die.
Usually, emitters in de C8 have a 5050 footprint, like the good old XM-L(2).
djozz
djozz's picture
Unfortunately the switching of the leds themselves is extremely fast, but the capacitance of the circuitry has more influence on the switching speed. You can add a capacitor to smear out the PWM, but the needed value is so high that the capacitor will be too big to fit inside your flashlight. Below is something I found on The Internet, it is an answer to a similar question, it short, our PWM speeds are way too slow to smooth the PWM current inside the led:
Quote:
To address the question, first a distinction needs to be made between phosphor LEDs (#1) (e.g. white LEDs, possibly some green LEDs) and direct emission LEDs (e.g. most visible color LEDs, IR and UV LEDs).
Direct emission LEDs typically have a turn-on time in single-digit nanoseconds, longer for bigger LEDs. Turn-off times for these are in the tens of nanoseconds, a bit slower than turn-on. IR LEDs typically show the fastest transition times, for reasons given ahead.
Special purpose LEDs are available, whose junction and bond-wire geometries are designed specifically to permit 800 picosecond to 2 nanosecond pulses. For even shorter pulses, special purpose laser diodes, in many ways operationally similar to LEDs, work all the way down to 50 picosecond pulses.
As pointed out by @ConnorWolf in comments, there also exist a family of LED products with specialized optical beam shaping, that boast pulse widths of 500 to 1000 picoseconds.
Phosphor type LEDs have turn-on and turn-off times in the tens to hundreds of nanoseconds, appreciably slower than direct emission LEDs.
The dominant factors for rapid LED switching are not just the LED’s inherent emission transition times:
Inductance of the traces causes longer rise and fall times. Longer traces = slower transitions.
Junction capacitance of the LED itself is a factor(#2). For instance, these 5mm through-hole LEDs have a junction capacitance of 50 pF nominal. Smaller junctions e.g. 0602 SMD LEDs have correspondingly lower junction capacitance, and are in any case more likely to be used for screen backlights.
Parasitic capacitance (traces and support circuitry) plays an important role in increasing the RC time constant and thus slowing transitions.
Typical LED driving topologies e.g. low-side MOSFET switching, do not actively pull the voltage across the LED down when turning off, hence turn-off times are typically slower than turn-on.
As a result of the inductive and capacitive factors above, the higher the forward voltage of the LED, the longer the rise and fall times, due to the power source having to drive current harder to overcome these factors. Thus IR LEDs, with typically the lowest forward voltages, transition fastest.
Thus, in practice the limiting time constants for an implemented design can be in the hundreds of nanoseconds. This is largely due to external factors i.e. the driving circuit. Contrast this with the LED junction’s much shorter transition times.
To get an indication of the dominance of the driving circuit design as opposed to the LEDs themselves, see this recent US government RFI (April 2013), seeking circuit designs that can guarantee LED switching time in the 20 nanosecond range.
DENGOH
DENGOH's picture
LED get switched on really fast. Tough to make it works without risk destroying the LED.
Lux-Perpetua
Has anyone got an idea how to pimp this driver to 4 amps?
http://kaidomain.com/Flashlight-DIY-and-Tools/Circuit-Board-Driver-Board/P2500-20mm-3V-9V-2_8A-1-cell-or-2-cells-5-Mode-Driver-Circuit-Board
Maybe this one could be another alternative to the LD25, LD29 (Convoy L2 driver), Neven's LD4A and the Convoy Biscotti driver with stacked AMCs?
