You are suggesting a new BLF responsibility: if we want a consistent user interface delivered by the manufacturers, we must be around to tweak it for every new flashlight type that comes to the market. And for Narsil we=TomE, and his presence on the forum is limited at times, and for Anduril we=ToyKeeper who currently spends numerous hours on the forum and on firmware, but who knows when the moment comes that she will be discovered by a smart and visionary software company and be gone? So I do not see that maintenance of Anduril is neccessarily more future-proof than Narsil.
The best is if manufacturers who make use of BLF firmwares learn to make the changes themselves.
I think the best would be the next generation, e.g. a user-programmable version. A simple free software for all platforms (including Win/Linux/Android) and a programmer-cable like it’s developed at the moment from Lexel. And an opinion to program a light without desoldering the driver.
THAT would be my dream for the future!
It is a proof of concept.
It is slow and you can’t flash the µC while it is communicating. So it is more a thing to configure the lamp. A Russian flashlight manufacturer does it already. But the programming key is for flashing.
When i got the Sofirn Q8, there are 2 sheets of instructions, same as the BLF Q8. The one with the diagram/table/sort of flowchart thingy and the one with heckloads of words and sentences and some tables. Not sure what is meant by cheat sheet though……
I thought it might be prudent to mention that Sofirn was kind enough to help me out getting another Q8, this one is slated to become something quite different than was originally intended. I will, of course, keep y’all informed as this little plan of mine begins to unravel.
I use flashlights in a work and security frame of mind. I’ll say it again, when an intruder is coming through a window at 3AM, the at-start lumens is the critical moment. He’s not going to wait around looking at the light expecting it to stabilize in 30 or 40 seconds. And hence, turn on lumens. I also build complete monsters with massive current draw, the cells fall extremely fast so a 30 second read has many of my lights quite depleted. Like measuring a direct drive XM-L2 light on a 10440 cell.
I do include a 30s reading a good deal of the time, for those that have come to expect it.
Take my Meteor M43 for example, it has 4 cells in parallel and I’m using Samsung 25S cells with 2500mAh capacity, so that’s 10,000mAh on tap, but I’m hitting them with a 58.8A draw for nearly a 6C discharge rate. The cells don’t hold up long.
People don’t like to accept my numbers. Most people don’t take the time to modify a light like I do, while it’s not hard it can be time consuming to attend to all the minute details. My lightbox has matched or been lower (seldom higher) hundreds of factory ANSI readings. LITERALLY over 500 lights! So I don’t doubt my light box. Can’t stress enough though, every one of our light boxes is for our comparison use to mod lights with, none of them are going to directly compare to each other. I get very nearly identical readings as robo819 who has the first P-Trap box manxbuggy1 and rdrfronty built. I get very nearly identical readings to Richard at MTNElectronics, his box was also built by these 2 brothers. Tom E’s as well. But all of us have different multipliers as the boxes were built at different times, but calibrated with similar lights. (25 or more with quality ANSI numbers, most expensive lights from top names)
If I knew where there was a big expensive sphere to check against I’d drive up to TA’s and do side by side readings on his box then go check on a factory sphere, but I don’t know of such a piece of equipment anywhere in this area. Would like to do it, be great if someone came up with a big company that was willing to help us out.
I’ve heard all this so much for the past 4 years or so that I’m about ready to just say “It’s bright!” and leave it at that…
