Convoy S2+ flashlight is a powerful and cost-effective LED torch and used for many outdoor applications. It supports up to 1000 lumens output with the use of a 18650 Li-ion battery. Constant current circuit ensures constant output, with its ultra-long shooting function, its lighting range is about 50-100 meters. Moreover, it also has mode memory function, low voltage protection and battery reverse protection function.
Main Parameters:
Emitters: Cree XM-L2 U2
Lumens Range: 500-1000 lumens
Luminous Flux: 940 lumens
Circuitry: 2.1A
Color Temperature: 6500-7000K
Mode: Two kinds of mode - .three modes: low 5%-mid 50%-high100% and five modes: low 5%-mid 50%-high100%-Strobe-SOS
Power Source: 18650 battery
Beam Distance: 50-100m
Impact Resistance: 1.5m
Product Features:
● High Performance
Adopting XM-L2 LED light, with up to 1000lm high brightness and long service time, to light up your way in the dark.
● Two Group Modes Choice
Two kinds of mode group, group 1 (Low - Mid - High - Strobe - SOS) and group 2 (Low - Mid - High) to meet your different demands.
● Mode Memory Function
Convoy S2+ can memory the mode next time when turn on for more than three seconds. If less than 3 seconds, it will goes into next mode.
● Low Voltage Protection
When the voltage of battery is 2.9 - 3.1V, the flashlight flashes 2 times/sec with low brightness for alarm.
● Battery Reserve Protection
If your battery is reversed, it will not bright only, do worry about battery or circuit.
● Premium Material
Adopting high quality aluminum alloy material, durable and stable.
● Widely Applicable
Idea for cycling, hiking, camping, fishing, working, repairing and other outdoor activities.
Get this LED flashlight from GearVita for multiple use, it is perfect for working, outdoor camping, emergency, repairing, and daily use: https://gearvita.com/convoy-s2-led-flashlight-cree-xm-l2-u2.html
Related products:
https://gearvita.com/convoy-s3-xm-l2-led-flashlight.html
https://gearvita.com/convoy-t2-led-flashlight-320lumens.html
