Nice work :+1:
How could I miss this thread, subscribed, and watching for further updates. I may be interested too.
Hereās a big batch of beamshots with various configurations at reasonably similar outputs. My personal preference is for the d-c fix because it isnāt too floody and maintains reasonable output and throw. With clear glass I measure 505 lumens and 5135 cd at turn-on, or 143.3m throw. With d-c fix it drops to 465 lumens and 2745 cd, or 104.8m throw. I also have some OEM frosted glass on the way to try, which I suspect will be somewhere between the frosted optic and d-c fix.
SC63w control shot:
LH351D:
219B w/clear glass (505 lumens):
219B w/d-c fix (465 lumens):
219B w/15 degree frosted optic (440 lumens):
219B w/frosted glass (465 lumens):
Now you must ask for credit to ZL since theyāre annoucing the LH351 version! Only saw this via our whatsapp chat, thought you havenāt post it here. I like the TIR optics for itās many options. Donāt close the bezel yet. You better make another sacrificial bezel from PEEK or any hard strong plastic for future lens change (I know you WILL do it soon).
Great job dude.
- Clemence
Thank you, that means a lot coming from you :student:
I just posted a small number of these for sale
Do we know the tint of these Hi CRI xhp35 Hi? Where do we buy A and D tinted NW XHP35HI emitters?
80 CRI XHP35 HIs are usually Easywhite (MacAdam ellipse step bins). The 45E bins from Arrow look quite neutral; I put that emitter in almost every XHP35 light that comes my way, and I think itās the one ZL uses for their HI models.
hi, Bob. i was wondering if you could please share a pic of your modified carving wedge or whatever bezel-removal tool you're using now. i'm curious about what it looks like and how wide it is.
i tried with a razor blade, but it's too weak and brittle. i'm considering grinding down a lock pick or a lock tension wrench because of the metal used (spring steel: fairly tough and seemingly not brittle).
i'm trying to get a sc700d open. will post pics if i manage to do it. :)
thanks!
Almost makes you want a J-shaped blade custom-sized to fit the bezel
Iām reminded of the hook-shaped blade on my grandfatherās knife - I was told it was to cut parachute lines easily.
ok, i ground down the handle end of a lockpick stamped from a single sheet (0.5mm spring steel).
my initial impression is the sc700 is probably more annoying to open than sc64. i'm able to slip my tool much deeper under the sc64 bezel, and it's much easier going. i didn't actually try to open up my sc64 since that's not my goal, but i think i could probably do it with the tool i made.
i tried to get the sc700 open, but i don't know if i actually made any progress. i might've lifted the bezel a little, but it's probably my imagination.
i wonder if the sc700 bezel tolerances are different, or if the oring is compressed more. or if the oring sits in a deeper retention channel, and the bezel is basically sitting right on a metal lip. maybe they wanted a positive stop for sc700 assembly.
i guess i could try pressing the glass in a vise or something in case the oring will give a little. will update if i learn anything else.
edit: this is a stubborn SOB. obviously breaking the glass to get into the light is admitting failure. i'm not there yet.
i think what i may do is use a pin vise to drill a small hole into the face of the bezel. that would give me a spot to insert a dental pick or something as a pry tool to lift up and get one spot started. with one spot lifted up a little, maybe then i could work the other tool around like how bob was doing it.
Sorry, I wasnāt subscribed to the thread so I didnāt receive notifications for new replies. Zebralight uses two styles of bezel. The SC64, H600, and SC53 series have the easy to open bezel, but the SC600, SC700, etc. require more effort because the bezel has no lip underneath.
For those lights, the tool need to be thin at the tip, but solid enough you can actually press down on the o-ring and force it under the edge of the bezel. It can also be helpful to gently tap it under, but you have to be careful about the angle and amount of force because itās easy to break the edge of the lens. Wood carving tool kits with a tool of the style shown in moridinās thread here are readily available on Amazon, but they typically need further grinding to refine and maintain the shape. You can also try something like a very thinly ground flat screwdriver, but it usually leaves more obvious cosmetic marks like the bezel shown in the photo above.
What LED are you planning to put in the SC700d?
thanks, bob. not an emitter swap but rather a host swap (or mod). zebralight thrower :)
i thought the tool i ground was pretty thin, and i even had a friend press quite hard into the lens next to the tool with the handle-end of a ball-point pen for extra oring compression pressure (the gorilla glass can seemingly take a decent amount of abuse). i'll try grinding a carving tool though. maybe mine was just too weak/flimsy to lift the bezel ring.
Iām curious how well thermal techniques could work. A small butane torch and a can of CO2 duster. Heat the aluminum body, then hit the lens/SS bezel with the cryo blast, maybe enough temperature differential could happen to shrink the ring and have it easily pry out. Maybe even keeping an ice cube on the lens while heating the head could help?
Iād try it myself but my ZL was stolen last year
Thermal stress on glass concerns me.
I figure the odds of damaging the lens with any method is high on these lights.
sorry to keep going a little off topic about sc700, but has anyone actually gotten one open before? or seen a report of someone succeeding with this specific series?
while observing with a microscope, i pressed as hard as i could near the bezel ring using a plastic rod but didn't see the lens/oring giving at all. doesn't necessarily mean anything, but it makes me wonder if the usual method doesn't work on this. i'm leaning towards trying to make a small hole in the bezel ring as a spot to start prying.
Haha, thanks - I was on mobile when I asked, so I wasnāt able to find and link this thread.
i just bought a new sc64c le to put a 519A 3500K dedome. first time taking one apart.
i ground down the handle of some metal spudger tool i had on my bench. you could probably make a tool out of almost any suitable piece of steel. just needs to be rigid enough to not flex in use. i worked it on an extra coarse whetstone and put a convex grind on it. the edge needs to be thin enough that you can fully insert the tool under the bezel. the edge radius should also roughly match the bezel radius so you get a decent contact area.
the red line in the image below shows how i flattened the edge profile on the right side (increased the profile radius). you can see the original radius to the left of it which was too narrow and didn't make enough contact.
after dialing in the blade geometry, the bezel came off very easily.
choil shot of the blade:
here's the driver removed. i added some test leads to test the circuit ex situ. spoiler: i didn't break it :)
i think it's interesting that the potting all came out with the pcb. i haven't seen a pic of this online before, so idk how common that is.
album link: https://imgur.com/a/XAKnZ2G
