Low-cost copper pills, spacers, optics, drop-ins (Updated 23/10/2022))
S2+ single pills are ready.
They have slightly non-standart design (I was not 100% satisfied with current design custom rings, have developed new version that required pill changes) with deeper retaining ring thread. New rings are not ready yet, but you can use them with regular convoy rings or previous custom rings. Havent checked yet but I suppose even convoy rings will allow using 2-side 7135 drivers.
PM sent!
How the hell are you getting 28+Amps on a single 18650 light?
Bypassed everything plus super low vf LED. Each emitter is 4 dies so basically 16 LED. And of course you must use the highest drain 18650s (vtc5a, 20s, 25s, etc)
kiriba-ru,
Well, I don’t think there will be enough interest to make it viable, but I’ll express mine anyway:
I’d like a nice pill for Astrolux A01.
What are you planning to do with the A01? I have one, so if it’s interesting, I might want to get a pill too. :wink:
Planning is a too big word…
I have a copper A01 BLF edition. It is “that dim light”. Dim, heavy, not my taste at all. But a hefty copper host….would make a fine hot rod.
I’m contemplating 2 builds.
One that is tempting but too impractical: XHP50.2 K2 3C + 2*10250 Nukes + QTC.
The other that I might actually attempt: LH351D + 10440 + QTC.
Or maybe even less practical. May not fit. XHP50.2 6v+3s10180
I’m pretty sure neither the 2x 10250 nor the 3x 10180 will fit. Unless you know something that I don’t. :question:
EDIT: I wonder what it would be like if you put the OSRAM KW CSLNM1.TG “white flat” emitter in there. It’s a 3V emitter, and the current “throw king” according to the testing.
Dunno maybe it wouldn’t. But the stock driver is very thick. And I have a similar construction by CRX in a Thrunite host, so that was an obvious inspiration. 3s 10160 is an option too. :wink:
White Flat would need a SMO reflector to really perfofm. And bezel is quite thick. Though low Vf is interesting. Anyway, not for me, I want a pee light, ideally with 1000+ lm. :wink:
Just received two Copper P60 Quad shells. Excellent quality as always, awaiting parts to build with.
Yeah, dunno if I mentioned this when I got ’em, but the pills for S2+ triples came in perfectly, nice sturdy box to hold everything, and shiny! :laughing:
Just received my S2+ copper pills. Thanks!
Hi Kirill, do you offer Convoy C8/C8+ retaining rings?
Im sorry I cant find C8 pill ATM.
Does C8 rings interchangable with S2+?
Have you started a batch of copper S2+ full triple pills yet?
Sorry, dont see it reasonable since Hoop’s pills will be available soon.
Do you have a link to Hoop’s pills please?
