PM sent!
How the hell are you getting 28+Amps on a single 18650 light?
Bypassed everything plus super low vf LED. Each emitter is 4 dies so basically 16 LED. And of course you must use the highest drain 18650s (vtc5a, 20s, 25s, etc)
kiriba-ru,
Well, I don’t think there will be enough interest to make it viable, but I’ll express mine anyway:
I’d like a nice pill for Astrolux A01.
What are you planning to do with the A01? I have one, so if it’s interesting, I might want to get a pill too.
Planning is a too big word…
I have a copper A01 BLF edition. It is “that dim light”. Dim, heavy, not my taste at all. But a hefty copper host….would make a fine hot rod.
I’m contemplating 2 builds.
One that is tempting but too impractical: XHP50.2 K2 3C + 2*10250 Nukes + QTC.
The other that I might actually attempt: LH351D + 10440 + QTC.
Or maybe even less practical. May not fit. XHP50.2 6v+3s10180
I’m pretty sure neither the 2x 10250 nor the 3x 10180 will fit. Unless you know something that I don’t. :question:
EDIT: I wonder what it would be like if you put the OSRAM KW CSLNM1.TG “white flat” emitter in there. It’s a 3V emitter, and the current “throw king” according to the testing.
Dunno maybe it wouldn’t. But the stock driver is very thick. And I have a similar construction by CRX in a Thrunite host, so that was an obvious inspiration. 3s 10160 is an option too.
White Flat would need a SMO reflector to really perfofm. And bezel is quite thick. Though low Vf is interesting. Anyway, not for me, I want a pee light, ideally with 1000+ lm.
Just received two Copper P60 Quad shells. Excellent quality as always, awaiting parts to build with.
Yeah, dunno if I mentioned this when I got ’em, but the pills for S2+ triples came in perfectly, nice sturdy box to hold everything, and shiny! :laughing:
Just received my S2+ copper pills. Thanks!
Hi Kirill, do you offer Convoy C8/C8+ retaining rings?
Im sorry I cant find C8 pill ATM.
Does C8 rings interchangable with S2+?
Have you started a batch of copper S2+ full triple pills yet?
Sorry, dont see it reasonable since Hoop’s pills will be available soon.
Do you have a link to Hoop’s pills please?
Thank you kind sir.
