Folomov is a fast growing Chinese brand of innovative LED flashlight, chargers and batteries.
Official website: Folomov You can find many reviews about Folomov items in BLF. Welcome to have a try.
Unique design:
” EDC-C4 “:Amazon.com The shortest Micro USB rechargeable 18650 flashlight, With power bank function.
”KEY Charger”:Amazon.com Max 2A key chain charger for 18650/21700 18650S The shortest 18650 tactical flashlight. 900 lumens with Nicha 219D led.
No, the shortest 18650 flashlight with powerbank function is DQG Tiny 4th coupled with Folomov cell-powerbank, good 7 mm shorter than C4.
And actually I wouldn’t say that Tiny is superbly small.
Folomov, I love your lights and daily carry your EDC C4
We would love for you to please use the user interface developed here on BLF called Narsil or Anduril on all your lights, it is light years ahead of what you are using…!!!
Yes, and DQG is Micro USB rechargeable…as long as you put the right cell inside. That’s basically moving the charging circuit from the host to the cell, less convenient but it works.
With a regular 18650 cell that doesn’t feature a charging circuit Tiny is 12 mm shorter than EDC C4.
Heh C-K! I got one in today. Definite e-switch feel on the tail. Head assembly is one piece, no removable bezel, and the driver side looks weird - plastic piece surrounds the contact button, I assume to force button top cells, and no obvious way to take it apart. will get it down to the bench to see if I can take more apart. Surprised no one else got one - ordered this one from Amazon Prime, have another on order from BG with Martin's deal.
Agree - UI is weird, "unique" I guess you could call it.
I absolutely love the tint, beam pattern looks good except for some artifacts. The tint is a nice 4000K, maybe a little warmer, but nothing like ugly yellow CREE 3000K.
Nice to hear, Tom. I have one underway too (without deal) because of the nice looks, the tail e-switch and the unusual 219D led. According to Clemence 219D’s are very easy to dedome, but I’m not sure if you want this led even warmer.
Oh boy, on the stock 2600 cell @3.8V, turbo does ~600 lumens, but with a 4.08V BT 30Q, ouch!! Beam center starts turning blue and lots of heat, but modes work fine, so don't think there's a direct short or something with a 30Q in there. The driver appears to be in the tail on a 16.8 mm PCB with the small e-switch mounted in the middle - bad news for modding, unless there's some custom work, or something else to work around this design. On the DMM, I read 51 ohms between the brass button and the outer shell of the head - interesting... I'll upload pics now...
Maybe it’s just tweaked for the high resistance stock cell. I’l charge it up and see.
The black plastic may be a little unclear. Looks like tweezers could fit in slots around the brass button. I tried but could not budge anything. Maybe what I would try is drilling 2 holes in the plastic, then see if i can get some leverage with a needlenose or other tool. The head is one piece, least appears that way - mp removable bezel.
