At full power? A few seconds. Have you used an Emisar D4? It’s a lot like that.
At a more practical power level? It should run indefinitely at several hundred lumens, depending on how you configure its thermal parameters.
Here’s an output graph from a few months ago, showing thermal ramp-down and then a relatively stable level:
That first minute is likely to ramp down faster than shown in the graph though. It was actually too hot during that first plateau, so I made it adjust down faster.
When started at the default ceiling level of 1100 lumens, the result looked more like this:
This test was 9 months ago though, and things have been updated since then. Mostly, it just shows a rough idea of what to expect when using a high mode which isn’t turbo. I think this test also had a lower temperature limit configured. The stable level depends on the user’s personal configuration and environmental conditions.
The list wasn’t updated yet! Member pepinfaxera will update it later and put your name there too!
The list will not be automatically updated on post#1, only later!!
EDIT: Thanks for the thermal stepdown explanation TK :+1:
I’m in for one . I like little triples .
The thermal response really depends on a lot of different things… so it’s hard to give concrete answers. I think it’ll probably ramp down very quickly on turbo though, in most cases. And at lower levels the response happens later and slower.
It’s largely based on predictions, so the rate of change has a huge effect on how the light reacts. If the temperature is rising very quickly, it’ll make a hard turn downward. But if it’s rising slowly at the same temperature, it’ll only make a gentle turn.
At full turbo though, there’s sort of an override which forces it down to a more sane level as soon as the prediction goes above the ceiling. So, expect it to only do turbo for a few seconds before it drops to the maximum regulated level of ~1100 lm *.
* Lumen numbers are from my cheap uncalibrated light box, and I suspect the real numbers may be a bit lower. I really should order some reference lights from maukka sometime, and build a proper integrating sphere.
It’s only been 3 days. I think the list gets updated every week or maybe every week and a half. No rush.
… and the list on the first page only gets updated, um, every few *cough* months.
I don’t have too many projects. What are you talking about? I’m not busy at all.
I have taken notes to update.
It’s bedtime (in Europe)
Then, pepinfaxera list will be updated.
It’s only been 3 days. I think the list gets updated every week or maybe every week and a half. Theres no rush to get the names on the list. :wink:
You are number No. # 1020 on: Interest List , Post # 4 , ” Page 1 , “:FW3A, a TLF/BLF EDC flashlight - SST-20 available, coupon codes public - #4 by FW3A_Team,
How many flashlights do you want in total? … x … units? .
You are number No. # 1425 on: Interest List , Post # 4 , ” Page 1 , “:FW3A, a TLF/BLF EDC flashlight - SST-20 available, coupon codes public - #4 by FW3A_Team,
You are number No. # 1515 on: pepinfaxera: Interest List: ”See #Post , Page 111 “:FW3A, a TLF/BLF EDC flashlight - SST-20 available, coupon codes public - #3305 by pepinfaxera
You are number No. # 1530 on: pepinfaxera: Interest List: See #Post , Page 111
You are number No. # 815 on: Interest List , Post # 4 , ” Page 1 , “:FW3A, a TLF/BLF EDC flashlight - SST-20 available, coupon codes public - #4 by FW3A_Team,
05:52 AM
Saturday, November 10, 2018
Coordinated Universal Time (UTC)
Updating this Request List.
Updated list : … In upgrade
Primary Interest List, (main): See Post # 4, Page 1 .
pepinfaxera: Interest List, duplicate: See # Post , Page 71 ,
Correcting: …
1125 - # Post . Bob_McBob
Apologies, I’m sorry.
Bob_McBob is #1038 and #1142,
Bob_McBob has requested three Flashlights “3”
    Moparguy is #1278, #1279, #1280 and #1281,
    Moparguy only asked for two flashlights, (request two flashlights) “2”. see: Post # 3547
    Dadpool is #385 and #1331, Dadpool only asked for a flashlight, (ask for a flashlight) “1”. see:
# Post lew123 - lew123 is #1337and #1493.
lew123 only requests a flashlight, # Post and # Post .
599 - -Post #1293 . Chinooker
Delete Post #599 . - Chinooker
1260 - # Post . manithree
1260 - # Post Delete manithree
Jambo is #310, #723, #724;
Request to delete one, (Remove one), #724
Request two flashlights, (only wants two flashlights), #310 and 723.
Page 1 Post # 4,
1092: Post #2769, Tom Tom
1093: Post #2769, Tom Tom
1092 Post #4950 Tom Tom Delete
1093 Post #4950 Tom Tom Delete
1357 : Post #3926, Hesh24
1358 : Post #3926, Hesh24
1358 : See # Post , . Hesh24, Delete 1358 .
Last requests : primary Interest List, (main): See Post # 4, Page 1 .
1502 - # Post . Sillen
1503 - # Post . Hexlord
New requests: Not updated in Post #4 page 1.
1504 - # Post . scalyman.
1505 - # Post . LGW
1506 - # Post . gottobegeek
1507 - # Post . sergey—neo
1508 - # Post . Nichia
1509 - # Post . Juls Boo
1510 - # Post . Jaded
1511 - # Post . idleprocess
1512 - # Post . idleprocess
1513 - # Post . sergey—neo
1514 - # Post . zapviii
1515 - # Post . gottawearshades
1516 - # Post odriewniffe
1517 - # Post . adam7027
1518 - # Post . adam7027
1519 - # Post . adam7027
1520 - # Post . WhitedragonBC
1521 - # Post . gtv4
1522 - # Post . theRealSammyG
1523 - # Post . theRealSammyG
1524 - # Post . Fiiish
1525 - # Post . lachesis
1526 - # Post . lachesis
1527 - # Post . Unloco
1528 - # Post . Unloco
1260 - # Post . manithree : Delete
1529 - # Post . mgracia85
1530 - # Post . jimmymke
1531 - # Post . McLight
1532 - # Post . gman7228
1533 - # Post . BadWolf
1534 - # Post . interval
1535 - # Post . Aleister
1536 - # Post . TheOnlyDocc
1537 - # Post . alchemi
1538 - # Post . bmansc
1539 - # Post . Sherbona
1540 - # Post . Sherbona
1541 - # Post . Cookster
1542 - # Post . Azza
1543 - # Post . DontWorryScro
1544 - # Post . stolikat
1545 - # Post . 10fold
1546 - # Post . 10fold
1547 - # Post . Tally-ho
1548 - # Post . Tally-ho
1549 - # Post . joechina
. . . . . . # Post . wishiwereaskibum
wishiwereaskibum wrote: I’m in for one if not too late!.
wishiwereaskibum is at numbers #665, #675 and #1165. : How many flashlights do you want in total? … x … units?
1550 - # Post . gehrmo
1551 - # Post . folg
1552 - # Post . MikeMacD
1553 - # Post . JaredM
1554 - # Post . JaredM
1555 - # Post . BrianButlerCPA
1556 - # Post . Marcello
1557 - # Post . Bogdan
1558 - # Post . Bogdan
1559 - # Post . Rsqweezy
1560 - # Post . whateatsrabbits
1561 - # Post . Rxich
1562 - # Post . LAB
1563 - # Post . Shadow.X1
1564 - # Post . NITEbiker
1565 - # Post . NITEbiker
1566 - # Post . SilentObserver
1567 - # Post . autoxer
1568 - # Post . srkfl
1569 - # Post . Archangel72
1570 - # Post . Archangel72
1571 - # Post . Light
1572 - # Post . DarkerInSol
1573 - # Post . DarkerInSol
1574 - # Post . DarkerInSol
1575 - # Post . nick779
1100 - See Post # 2807 ,
See # Post
1576 - # Post . Cpeng
1577 - # Post . Animisk
1578 - # Post . Animisk
1579 - # Post . PhantomPhoton
1580 - # Post . OrangePeel
1581 - # Post . OrangePeel
1582 - # Post . lightlight22
1583 - # Post . lightlight22
1584 - # Post . lightlight22
1585 - # Post . noetik
1586 - # Post . noetik
1586 - See # Post . noetik : Delete 1586
1586 - # Post . Finnno
1587 - # Post . nastynate
1588 - # Post . apt323
1589 - # Post . lfowner
1590 - # Post . lfowner
1591 - # Post . Jonandreadolan
1592 - # Post . lightlight22
1593 - # Post . MokrySedeS
1594 - # Post . MokrySedeS
1595 - # Post . Ziggie
1596 - # Post . offline
1597 - # Post . Dogue
1598 - # Post . Dogue
1599 - # Post . thisnameisvalid
1600 - # Post . lmcmann
1601 - # Post . lmcmann
1602 - # Post . timbo114
1603 - # Post . timbo114
1604 - # Post . hcanning
1605 - # Post . Sirawatka
1606 - # Post . southcovekayak
1607 - # Post . aswang
1608 - # Post . Bigoaktree
1609 - # Post . oceanfreak
1092 - # Post . Tom Tom Delete #1092
1093 - # Post . Tom Tom Delete #1093
1610 - # Post . tango
1611 - # Post . tvizk
1612 - # Post . P33
1613 - # Post . odriewniffe
1614 - # Post . elpaulo
1615 - # Post . elpaulo
1616 - # Post . EnlightenMe
1617 - # Post . Buzzy243
1618 - # Post . Buzzy243
1619 - # Post . Geoduck
1620 - # Post . Tumbleweed48
1621 - # Post . Deadsailor21
1622 - # Post . Deadsailor21
1623 - # Post . Greener
1624 - # Post . Greener
1625 - # Post . tundraotto
1626 - # Post . Rdubya18
1627 - # Post . x-ray
1628 - # Post . ispeedy
1629 - # Post . ispeedy
1630 - # Post . bts
1631 - # Post . lightboks
1632 - # Post . willc68
1633 - # Post . jaynick
1633 See # Post : . jaynick = #1023, #1237, #1238 and #1239
1633 - # Post . Dario
1634 - # Post . Lagittaja
1635 - # Post . antoninuspius
1636 -
1637 -
1638 -
1639 -
1640 -
1641 -
1642 -
1643 -
1644 -
1645 -
1646 -
1647 -
1648 -
1649 -
1650 -
NOTE: If I overlooked a post, PLEASE IM me and i’ll edit for correction.
In upgrade . . . In upgrade . . . In upgrade . . . In upgrade . . . In upgrade
Someone has the patience of a Saint to do THAT list! :+1:
Amen to that!! :+1:
A big ’thank you’ to pepinfaxera!! . :beer:
I agree…… good on ya pepin…… even tho I got off the list months back, still watchin the thread
Thanks to you.
And, excuse me, excuse me:
I’m not very communicative
Language problem. I don’t know English language.
Greetings .
This could be interesting, just to see how it pans out.
The Q8 had a similarly massive interest list, and, remarkably, a very high uptake from those on it.
Sufficient that it continues in production today.
Of course the first batch had a few niggling problems, but these were, I think, sorted out as well as could be hoped, thanks to swift feedback from BLF, The Miller’s determination, and Thorfire’s responsiveness in swiftly doing a little re-design and re-making a part (and replacing the production manager).
Due to serendipity I missed the first-batch problems.
The Miller had to take a chance on signing off the Q8 when he did, the team could have fannied on forever over the minutiae, it was very interesting technically, but there was a market window, beyond which interest would have slowly died, credibility been lost, reputational damage to BLF, loss of an interested supplier (Thorfire/Sofirn).
My suggestion: Build no more than say 50 in the first batch and sell them at a really good unrepeatable unmissable price. First come, first served. No warranty, but as much support as can be run from China with someone coordinating. We won’t get Wim, but is anyone else prepared to step-up ?
Make it clear that these are actually pre-production prototypes, and would best be bought by experienced people who are prepared for a few bumps and squeaks in exchange for a great price, and the opportunity to improve the thing, if necessary.
Then wait for feedback here. Give it at least two months. Then reflect, make any changes that seem sensible, and build the main run.
This is how we do things in Aerospace, typically A model, B model, C model (all internal development), P model (clients first sight of the thing, and chance to evaluate and complete qualification, not to be used in a serious situation, unless needs must), then full-scale ramp-up. But this should not be necessary for a simple torch.
Simply making only two pre-production prototypes, then sending them to only two people, most heavily involved (and least likely to be able to critique their own work neutrally), and who seem to have gone off-grid, does not seem to me the brightest of ideas.
I also suspect that there ought to be some final tuning of firmware, by the Goddess, to suit whatever emitter choices have actually been made (still unknown). When (and how, without a couple of P-models) is that going to happen ?
Your welcome pepinfaxera, our pleasure!! :+1:
Do not worry about what you call a “language problem”…. you are doing an amazing job. Especially since you do not know English!! . :slight_smile:
:beer:
Where do I sign up for those first 50 testers?! :smiley:
:+1:
