So i started this afternoon, it is now 3:28 AM here…
Pictures!
Without the wrapper it nearly slides in the tube, if both were perfectly round, which they’re not…
The Osrams are 3030 LEDs, which had to be reflowed onto the triple 3535 board.
Took some time, effort and cusses to get them all positioned decent enough.
Need a shelf for the LED board to sit on inside the tube.
20 x 20 x 1.5 mm heat spreader to make the shelf.
Must be soldered in place.
Needs holes for wires and 2 tiny screws.
Can you see the damage on the business end of the tube?
I dropped it on the concrete floor… :person_facepalming:
I’ll address it later. Maybe need some extra ring around there to make it a little more impact resistant…
Time to do the electrical bits.
These charger boards are quite okay.
I won’t need the protection circuit though.
Well, i bought 2 of those 20700’s almost a year ago now, but i haven’t got anything to use them in…
And then i found that, with a little persuasion, it can fit inside a 22mm diameter copper pipe when you remove the wrapper.
Triple board and optic also fit snugly in this size tube.
I could have used the Convoy S9 e-switch driver with USB charging port, but i didn’t like the idea of parasitic drain, so i used a reverse clicky set up in stead.
This takes up more space though, and it will be a bit more of a challenge to sort out the switch button.
And that will be the next part of the build:
Holes for the USB port, charging LED light and switch button.
Also have to widen the copper tube a tad to get the assembly in without too much force.
Lining the lot up properly will be a bit of a challenge too…
Looking great, Jerommel! Very cool setup so far, I like how you’ve got everything stacked tight and epoxied in place (JB Weld?). Interesting how you’ve trimmed down the charging circuit. Are the eliminated bits just for over/under voltage protection?
Well, let’s hope not that it will end like that… ^
I will update this evening / night with pics.
Had a bit of a set back, but that’s what you get when you build hastily and without proper planning up front…
