Reflector will point the light down and to the sides. If it’s only slightly conical-mostly down. It will hit the body and what’s next? If you don’t paint it white the light will be absorbed and lost. If you do paint it white, it will be reflected. Which may or may not cause glare.
Its absolutely possible that this project won’t work as expected finally. Wouldn’t be the first of my ideas. You’ll never know if you don’t try.
The concept might be new to flashlights but not to lighting in general: its simply a portable uplight which I like most for house lighting. I’m using orange pearl Convoy S2+ reflectors which are not famous for throw, so a lot of the light leaves this reflectors already diffuse. I guess a printed conical reflector isn’t even required. 3d printed top surfaces are not even at all due to the nature of this technique.
Of course there is a light loss but I’m less concerned about the light hitting the body after reflection than about the light passing the reflector at the side. To address this point I’ve positioned the light modules as near as possible to the center of the body.
Regarding the glare: you won’t see the reflector bottom when the light is standing on the table since your eyes are above. But you might see into the reflectors of the light modules in the housing which I like to avoid. In my prototype below with the Q8 I solved this problem with a tube which holds the printed reflector and shields the Q8 reflector. For the contest entry I consider to position the light modules a bit deeper into the housing. Then I would loose some of the spill of course. I have to find the best compromise.
To test this concept you could make a simple experiment, hold a piece of white paper over a tail standing light in a proper distance.
Here the prototype images, I will take another picture with the light in operation when its dark. The reflector is printed of white filament without any coating. I’m using this prototype regularly as a working light on my workbench.
Prototype in operation:
Looks really good, though it’s quite a bit different optically. Both because the shims block light going sideways and because light that goes down towards the light hits reflector and has a chance of escaping up (though has a good chance of eventually hitting the shim as well).
If you’re not concerned about losses from the light hitting the body, I expect your light to work well. :+1:
Last weekend I wrote a new firmware for this light (from the scratch, as required ) and I’ m pretty satisfied with the outcome. It also includes the gimmick I announced in my first post, which hasn’t been realized in BLF before, AFAIK.
And I got some of the components but I’m still waiting for more parts I ordered in China. I should start with the printing within the next days since it will probably last several days for all components, even if everything works out well in the first attempt (what I don’t expect).
Btw. there is another board on the way, any idea what it is supposed to do?
Uhh… nope! :person_facepalming:
Got the boards this afternoon:
One more try?
That’s the spirit
RX TX? Maybe something with a transmitter and receiver setup?
Nope. I’m still a dummy. The one on the left looks like a driver, but I still don’t know what the “new” board is. :person_facepalming:
Populated but not tested yet:
Thijsco19, you are close.
Okay, it has a trace that looks like an antenna. So, it’s a wifi module? Bluetooth?
Say wha?
I always love to learn with these mods/builds
Dang, just noticed the 7135 I used for this build are not best. They need a minimum pwm value of 10 to light up the 7 XM-L2 in my test head. Fortunately I provided a 3rd channel (resistor) for (energy saving) ultra low moon with sleeping MCU. Firmware needs a fix though in order to allow a smooth transition from 1st channel (1x7135) to second channel (5x7135) and vice versa.
That is some awesome creativity :+1:
Be careful with that BLE module, I had one I was trying to hook up to my laptop (to rename and setup with AT commands) and I powered the board up from a li-ion battery (that wasn’t even full) and the module outputted a huge spike on the 5v line and killed my laptops USB circuitry. I looked it up and that computer had USB over-voltage protection to 13.5v so the pulse must of been higher than that!
It works fine in operation but the only way I configure them anymore (config requires AT commands over its UART) is by hooking them up threw a powered USB 3.0 hub to protect my [new] computer
Not good. Are you talking about exactly this module (WT51822-S4AT)? I know the NRF51 has a buck DC-DC converter on board but there must be a serious hardware flaw in the NRF chip to make this happen. How do you know it was an excess voltage spike?
Btw., I only reconfigured this module once with AT commands but it didn’t remember the new settings after power cycling. Have to try another module.
Edit:
Any special reason why you powered the module externally? I used a common USB serial adapter which supplies Vcc by itself.
Very cool.
